igntion sticking
2005chevimpala
12-27-2009, 02:55 PM
anyone know what to do the the ignition,my key won't turn sometimes and is stiff,spryed grease inside the chamber but no difference
maxwedge
12-27-2009, 03:27 PM
And the year of the car is? What is pictured? If so the key cylinder itself could be binding or the actual ign. switch could be the issue, to correct this the column/switch assy. should be disassembled to get the the heart of the matter.
2005chevimpala
12-27-2009, 04:16 PM
And the year of the car is? What is pictured? If so the key cylinder itself could be binding or the actual ign. switch could be the issue, to correct this the column/switch assy. should be disassembled to get the the heart of the matter. 2005 impala,you mean take it out and take it apart?,will the computer get fooled up or anti theft programs lock me out after
maxwedge
12-27-2009, 06:46 PM
The pk3 will not be affected by this unless you tore up some wires, I would get a good manual for this or subscribe to alldata.com, or look at repair info at autozone.com, if this is a 1st time.
j cAT
12-28-2009, 09:02 AM
go to the dealership and have them make a new key.
2005chevimpala
12-28-2009, 01:15 PM
go to the dealership and have them make a new key. that won't work either,i just took out the spare that was only used a few times and was still sticking,i took the cover off and sprayed rust check in the slot and all around the outside of the chamber,works very good now,thanks guys
