2000 Impala Heater not working
jayjay09
12-06-2009, 12:46 PM
I have a 2000 3.4 Impala my heater doesn't come on till the car gets warmed up and only if I'm going 65 mph or over, but if I turn the fan on it goes cold. Also fan blower doesn't come on except if it's on high. Even then it blows cold air.
Airjer_
12-06-2009, 04:51 PM
Does the temp gauge read normal?
is the check engine light on?
Is the coolant full?
The fan only working on high is likely a bad blower motor resistor
jayjay09
12-06-2009, 10:09 PM
The coolant is full. The temp gauge reads high sometimes and the low coolant light comes on when it goes high.The check engine light is not on.
Iflylow
12-11-2009, 11:39 AM
Sounds like you have air in the system. Bleed it out and see if that helps.
