click and crack in my steering 05 impala,just started 3 days ago
2005chevimpala
06-15-2009, 06:36 PM
anyone know when i am stopped and turn my wheel to the left just beforte she is turned all the way to the left she gives a big crack and little crack when turning to the right,had some listen to it with the hood up when turning the wheel but seems to travel right acroos the whole front of the car,the last time i had a click like that was in one om my other impalas but was not as loud,it was the ball joint clickin,is it possible this ball joint is now gone dry as they are not greaseable,can someone give me some ideas,my steering seems stiff to,even with a new belt on
oldblu65
06-16-2009, 01:29 AM
Have you had your intermediate steering shaft checked ?
2005chevimpala
06-16-2009, 03:30 AM
it was greased up 2 years ago,i don't feel any knocking when driving and if it wat the shaft then should'nt i feel the crack and vibration up through the steering wheel? when turning left to right while parked
bhoyer
01-10-2010, 10:28 AM
Is the intermediate steering shaft a typical problem? I have a clunk coming from my 2007 Impala also when turning?
2005chevimpala
01-10-2010, 01:18 PM
Is the intermediate steering shaft a typical problem? I have a clunk coming from my 2007 Impala also when turning? the shafts are bad on all impalas from 2000-2005 and need to be replaced or re greased,not sure about the 06's and up.
HeMi101
01-11-2010, 03:13 AM
Im pretty sure even the 06+ are affected by the bad Intermed. shafts, although knock on wood both our 07 and 09 hasn't made a single noise yet.
bhoyer
01-11-2010, 08:48 AM
Thanks for the information. Is this something the average backyard mechanic can do, or does it require removing something majior to get to it?
mp1642
01-14-2010, 05:45 PM
FYI: Make sure the steering wheel does not move during the intermediate shaft replacement of you will be forced to take it to the dealer to correct.
Otherwise this repair is not too hard
gene5118
01-25-2010, 11:26 AM
I had a click in my 2004 steering, wasn't a crack just a small click when turning. I pulled back the boots on the steering knuckles ( one under the dash and one behind drivers side wheel). Take driver side wheel off to do this. Pull boots back and put some white lithium grease on them. No more click
05ImpalaSS
01-31-2010, 12:18 PM
Posted by a guy in impala forums
to fix the clunk, click, thud in your steering you should keep the Intermediate steering shaft lubed.
http://colinkraft.com/shaft.php (http://colinkraft.com/shaft.php)
