2000 impala explosion
carol6399
12-19-2008, 12:13 PM
hey my impala died and i thot it was the battery well my husband was charging it turned the key and the whole top of my motor exploded parts all over the street just glad no one was injured, called GMC they dont seem to concerned but i am just hopeing:disappoin it dont happen to anyone else if it cost to much to fix i will get another car love my impala but i have heard so many thing i my go to ford but ive allways owned a chevy. if anyone knows if this has happened to anyone else please let me know.
maxwedge
12-19-2008, 12:17 PM
Welcome to AF, what engine and what exploded, lots of pertinent info missing.
j cAT
12-19-2008, 02:23 PM
this will occur if too much starting fluid is sprayed into the air intake.... 2 seconds of spray max...
this occurs often this time of year....
cailou1
12-19-2008, 08:59 PM
wow dejavu... I too have a 2000 impala ls 3.8l 130000 km. It was -40 for a couple of days and the car would not start. Left it for a couple days. Turned the key and boom. My car burned!!! Fire department spent 15 minutes putting out the out of control fire. I dont know what to do. No fire insurance. You know I can see paying to fix things that go wrong, but its rediculous to have your car burn to the ground. Any law suits out there?
Carwhiz
12-20-2008, 07:41 AM
Assuming you have a 3.8L engine, a leaking fuel pressure regualtor (FPR) is most likely the culprit of your explosion. Your FPR leaked beyond it's diaphram which caused fuel to be sucked into the vaccum line directly into the upper intake manifold. Durring excessive cranking due to the battery being low on charge along with a mis-timed ignition causes a backfire inside the engine. The excessive pressure escapes though the weakest point in the engine which is the upper intake manifold due to it's plastic components. Is this a lawsuit with GM? not a chance. If anything it would be a lawsuit with your mechanic for not catching your FPR for leaking(part of normal GM 3.8L inspections). For this explosion to happen the FPR must be leaking excessively. Solution to problem: MOST LIKELY, all that is needed if a replacement FPR along with upper intake manifold and gaskets. Thankfully nobody was injured!!
crazy Jim
12-21-2008, 08:17 AM
I wonder if it was just the battery that blew and not the entire upper intake cause she mentioned charging and that process will allow some explosive gasses to be released from the battery. I've seen this happen on many occasions. I've never even heard of the intake blowing off the engine except for NOS injected race cars.
maxwedge
12-21-2008, 08:33 AM
Well all this is mute as the OP has not clarified his issue as requested!
dbhoudini1
12-26-2010, 08:35 AM
I, too, am a victim of the exploding intake manifold. On Dec 13, 2010, my 16 year old daughter told me that her car wouldn't start(2000 Chevy Impala LS)(3.8 Liter engine, 155,000 miles). It had been below freezing for a few days and so I thought that the battery was dead, or at least weak. On December 15th in my attempt to jump the car, when I first turned the key, I just heard a clicking noise, so I figured it needed a minute or so to charge. In the second attempt, there was a huge explosion!! I got out of the car to see that the plastic intake manifold had exploded. I am going to have it repaired, but am somewhat fearful that it may happen again.
j cAT
12-26-2010, 03:16 PM
the fuel is injected directly into the cylinders. with low battery power it would be possible to flood engine because of a poor/no spark condition..backfire can occur...then ....
If starting fluid or gas was placed into the intake then,,, it is very common for the intake to explode.
with a weak drained , cold battery jump requires 20 minutes to put some charge into the dead,cold battery ..this is because the battery does not charge when it is cold , very well..when the battery warms up then it can charge.
also the battery jumper cables made today are cheap chinese crap !
I have pure copper jumper clamps, with 2/0 wire soldered to the pure copper clamps..the clamps alone back 40 yrs ago cost 15.00...
today probably 100.oo if you could find a set.
jumpers like this ,,,not much waiting is required...
dbhoudini1
12-27-2010, 01:11 PM
well, I didn't use any starter fluid, all I did was the normal jump start procedure........never had any explosions in the past
j cAT
12-27-2010, 01:33 PM
must be the injectors flooded the engine with liquid fuel . no spark because of the low voltage. when the spark did get to the plugs the vapors in the intake caused the explosion..
If the throttle pedal was fully depressed when the start attempt was made, before turning the key this would not of occured.
starting fluid it the biggest cause of this .with your case it can still occur with a flooded engine..start proceedure is pedal to floor and then crank .
dbhoudini1
12-28-2010, 09:33 AM
well,I don't normally step on the accelerator when starting my car, but I will remember to do so in the future
j cAT
12-28-2010, 03:28 PM
when starting normal just turn key...
if the engine does not start hold throttle pedal to floor then crank..keep pedal to floor , as you cycle the ignition on /off this will keep vapor level in the intake at a safe level..if it does blow it will release pressure out the air filter..
