2000 Windstar VSS splice location
rodtill
06-30-2008, 09:24 PM
Does anyone know the best location to access the speed sensor pulse? VSS in heated area. Need to splice VSS wire but not near the exhaust. Any suggestions?
CoachKarl
07-01-2008, 01:12 AM
Welcome Rodtill,
Elaborate on your symptoms. When mine went bad (twice) The car ran, but shifted at the wrong speeds.
Yeah, I can reach the wires going to that thing by leaning waaaay over the trans, but how do you expect to verify the pulse without spinning by hand?
This isn't a rhetorical question, I'd love to be able to do this without having to pull the blasted thing first.
Karl
Karl
notstupid
07-04-2008, 05:22 PM
You can access the output of the VSS at the cruise control servo which is situated under the air filter. If you probe the dark green/white wire, that should give you a pulse signal from the VSS. But like CoachKarl said, the thing has to be spining for any pulse output.
Notstupid
Notstupid
