Overheat-newbee here
Weberoso3TC
02-01-2008, 02:00 PM
1995 SS cooling fans not activating. Hot wired both fans and they work. Found broken temp. sensor and replaced with no luck. All fuses in working order. Help please:banghead:
RaeRae1
02-01-2008, 02:10 PM
Have you followed the wires to make sure there is not a fusable link inline somewhere?
Iflylow
02-03-2008, 03:18 PM
Welcome to AF!
The B-Body Impalas are normally included in the Caprice forum. You may have better luck posting there, as most people here have the W-body cars.
j cAT
02-04-2008, 12:34 AM
one fan normally operate only when a/c on if a/c on both fans operate if a/c gas pressures high. also fans will only come on if engine temp increases to i think 230deg f approx.. so normally no fans are on if a/c off and engine temp 180deg f.......pcm controls fans though relays in fuse panel
