96 sable couple of problems
manip1
01-08-2008, 11:01 AM
I am having problems with heat. Before I had to have the car at about 3 rpm's to get heat. Now the temp gauge runs high, and everytime I shut off the car it makes a gurgling sound from the resevoir. I have replaced the thermostat and flushed the radiator(in which there was a lot of gunk in there). I checked the oil to make sure it wasn't milky so I know it isn't a craked block. Any suggestions
Also when I am driving and come to a stop in won't shift into 1st gear. Unless I rev up the engine. Any help would be great thanks!
65comet
01-08-2008, 05:57 PM
If you have the vulcan engine it most likely is the water pump. The Taurus forum has lots of threads about the vanes wearing out to nothing.
