P0128
dbrawner
11-25-2007, 12:38 PM
Hey everyone i have an 03 impala with the 3.4 engine and my check engine light comes on but only when it real cold i flushed the radiator a few weeks back and the temp stays real low on the highway but when its cold is the only time it stays really low causeing the light to pop so i am gonna change my thermostat but there is a pipe from the exhaust that runs behind it what would be the easiest way to remove it do i need to take that pipe off
Iflylow
11-25-2007, 03:07 PM
I've heard it can be done without removing the exhaust crossover, but save your self some time and trouble, and remove it. It's easy to remove and reinstall, and makes the T-stat job go a lot quicker.
Also, try using some punctuation. I had to read your post 3 times to figure out what you were trying to say!
maxwedge
11-25-2007, 06:59 PM
Correct, reasonable grammar is expected on the forum, thanks.
dbrawner
11-26-2007, 06:11 AM
Sorry about the punctuation. And so it would be easier to take the pipe off? Alright thank you for the help
maxwedge
11-26-2007, 03:10 PM
Yes, just be careful in order to facilitate reinstallation.
Iflylow
11-26-2007, 05:41 PM
A little WD40 on the bolts will help, but expect to smell it a little the first time the exhaust gets hot.
