94 Saturn SL Idle probs
BOZZZ
11-01-2007, 05:10 PM
I have a 94 saturn wiith the 1.9 in it. On the tech 1 it has a code of 34 witch is Map sensor but it also come up with 2 Eng Info Flags 53 ESC Max Value and 76 TPS vs MAP. It will idle at 3000 then idle fine can drive it for a while then it just will buck a little like it's running out of gas then die and not want to start unless you pump the pedal some, but still won't run just idles up and down some. Cools down then will start and idle at 3000 I'm new to Saturns so any help would be appreciated.
