Subaru Impreza -
jfluca
10-19-2007, 07:05 PM
Hello,
This is my sixth Model car and I tried to do a tribute to Richard Burns...
The Chassis after application of Primer, Black and Matte Base Aluminum Extra fine ..
http://i31.photobucket.com/albums/c353/jfluca/IMG_3882.jpg
http://i31.photobucket.com/albums/c353/jfluca/IMG_3886.jpg
The body follows the same coating system ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_3887.jpg
http://i31.photobucket.com/albums/c353/jfluca/IMG_3889.jpg
After dry and washed, the final color is applied ... Blue Mica I needed import because it found the exact color here in Brazil ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_3891.jpg
http://i31.photobucket.com/albums/c353/jfluca/IMG_3894.jpg
http://i31.photobucket.com/albums/c353/jfluca/IMG_3899.jpg
http://i31.photobucket.com/albums/c353/jfluca/IMG_3900.jpg
http://i31.photobucket.com/albums/c353/jfluca/IMG_3902.jpg
The wheels were Alclad Gold and the aspect is fantastic ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_3913.jpg
Testing in the car ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_3918.jpg
Then put more photos of the continuation of the assembly ..
Greetings!
Luca.
jfluca
10-19-2007, 07:24 PM
According to the update ...
I spent many hours looking for good references on the car and every step in the assembly was a reference to my side ...
Let the glass ... Note that the masks are wrong and some adjustments are needed .. It used to Mask Tape Tamiya...
http://i31.photobucket.com/albums/c353/jfluca/IMG_3921.jpg
http://i31.photobucket.com/albums/c353/jfluca/IMG_3922.jpg
http://i31.photobucket.com/albums/c353/jfluca/IMG_3924.jpg
After made the mask, painted with black matte and then applied varnish.
http://i31.photobucket.com/albums/c353/jfluca/IMG_3926.jpg
Then I started painting parts of the Chassis following the references of the car
http://i31.photobucket.com/albums/c353/jfluca/IMG_3931.jpg
http://i31.photobucket.com/albums/c353/jfluca/IMG_3932.jpg
Parts of the engine and Subaru AWD system
http://i31.photobucket.com/albums/c353/jfluca/IMG_3935.jpg
Enjoy!
Luca.
rallymaster
10-19-2007, 09:46 PM
Wow, wonderfull paint work, very clean ! :thumbsup:
stevenoble
10-20-2007, 04:59 AM
Really nice work so far.I like how you undercoated with the silver base before you applied the blue,good idea.The detail painting on the engine parts looks great.What paints did you use for the engine? They look incredibly smooth.Alclad maybe? Keep the updates coming.
jfluca
10-20-2007, 08:13 AM
For the Motor used the same extra Aluminum Thin Polyester, but the base was black synthetic brilliant, with a brightness that achieve stronger and better aspect.
Luca.
jfluca
10-20-2007, 08:20 AM
The exhaust pipe and the bars for protection, I used to alclad aspect of Chromed.
http://i31.photobucket.com/albums/c353/jfluca/IMG_3938.jpg
http://i31.photobucket.com/albums/c353/jfluca/IMG_3948.jpg
Began to put the Decals in glasses ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_3959.jpg
http://i31.photobucket.com/albums/c353/jfluca/IMG_3962.jpg
And the set of detail arrived
http://i31.photobucket.com/albums/c353/jfluca/IMG_3967.jpg
Then ... Going to the brake discs .... Compared with and without the PE's
http://i31.photobucket.com/albums/c353/jfluca/IMG_3971.jpg
http://i31.photobucket.com/albums/c353/jfluca/IMG_3972.jpg
Robi J
10-20-2007, 10:45 AM
Hei Luca, very very clean job and very nice photos !!!
Robi :)
Aoc13
10-20-2007, 12:04 PM
love the work so far the paint work is outstandingly smooth :D what model subaru is it.
SeanyG
10-21-2007, 01:50 PM
Luca - great stuff so far, very clean and your spray work is excellent. The alclad colours look excellent too. I will add you to the tribute list - I take it is the 1999 Imprezza at the Tour de Corse Rally?
jfluca
10-22-2007, 03:57 PM
The Pre assembly is very important ...
Then before pasting all parts of the AWD Subaru System must verify that Fittings are correct not to have problems
with the alignment of the wheels at the end of the assembly ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_3975.jpg
Panel of the car without the carbon fiber that will be applied ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_3977.jpg
Here the banks on a comparison with and without carbon fiber ...
For protection and brightness used Future applied directly to the Spray Pen.
http://i31.photobucket.com/albums/c353/jfluca/IMG_3979.jpg
The panel color correct ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_3987.jpg
Hard assembled and suspension that is thread.
http://i31.photobucket.com/albums/c353/jfluca/IMG_3990.jpg
Again ... We will mount a Pre assembly ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_3991.jpg
And it seems that everything is correct ... We will see more forward as will be ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_3994.jpg
The inside of the doors painted faithfully following the references of the car ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_3998.jpg
Cylinder of chemical powder ..
http://i31.photobucket.com/albums/c353/jfluca/IMG_4007.jpg
I confess that I do not know to what use this piece in the car .. I believe that any tank ...
But really do not know what is ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_4010.jpg
Scope added embedded in the wheels and suspension system for testing of alignment ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_4013.jpg
Car aligned ... Then I left for the release of other PE's ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_4024.jpg
We then from the detail of the interior of the car ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_4034.jpg
PE's of pedals and foot rest, and added the manta thermal protection of the floor.
http://i31.photobucket.com/albums/c353/jfluca/IMG_4037.jpg
Part of the power of the system for telemetry of the car (black board)
http://i31.photobucket.com/albums/c353/jfluca/IMG_4039.jpg
PE's added on the cover of the thread of suspension
http://i31.photobucket.com/albums/c353/jfluca/IMG_4053.jpg
Test plug the STA ..
http://i31.photobucket.com/albums/c353/jfluca/IMG_4055.jpg
Carbon Fiber applied on the side of the STA ..
http://i31.photobucket.com/albums/c353/jfluca/IMG_4099.jpg
To do the wiring for power and data distribution of telemetry,
i used cables of Mr. Model (Brazilian Model) and a small bracelet in expiral (looks like a little Spring) that the cables will linguetta ..
http://i31.photobucket.com/albums/c353/jfluca/IMG_4105.jpg
Work done ... I spent the cable inside the blue for "spring" and the Pulled giving this final aspect ..
This process needs to be done, because the cables of telemetry have this expiral throughout your back ....
http://i31.photobucket.com/albums/c353/jfluca/IMG_4106.jpg
Cable added to telemetry system ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_4110.jpg
Following the detail ... There are two parallel cables that are arrested for "rings" and go next to the driver ...
To do this, they used "springs" and cables of Mr. Model .. Just cut into small rings and unite the cables with him ..
http://i31.photobucket.com/albums/c353/jfluca/IMG_4111.jpg
With a toothpick is easier to do so ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_4114.jpg
Cables ready ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_4115.jpg
Appearance end inside the car ..
http://i31.photobucket.com/albums/c353/jfluca/IMG_4117.jpg
Detailing further the telemetry system ...
http://i31.photobucket.com/albums/c353/jfluca/IMG_4118.jpg
So... staff ... For today is just ... Then put more detailed pictures of the interior of the car ...
Embrace!
Luca.
jfluca
10-22-2007, 04:01 PM
SeanyG
Thanks for the words and follow the assembly of the car.
Yes, this is the car piloted by Richard Burns in 1999.
SeanyG
10-22-2007, 04:05 PM
Im guessing Luca is using one of those online translators :lol:
Great progress Luca - your work is very clean and tidy, great decal application on the seats too.
stevenoble
10-22-2007, 04:06 PM
Beautiful work on this build.Very nice detailing and an ultra clean finish throughout,really good.
billypee
10-22-2007, 04:17 PM
Super work on this Sub Luca. The metal effects you achieve with the Alclad paints is amazing. I love the attention to detail on the wiring too.
Thanks,
Bill
jfluca
10-22-2007, 04:22 PM
SeanyG,
A many words, Yes! Sorry! :grinyes: :naughty:
godfather23
10-23-2007, 04:05 AM
Looking very good to me. The wiring process is something to remember! Great Stuff!
