saturn sc1 2001 intake question
stupidquestions
07-24-2007, 08:08 AM
if i just remove the stock air intake and throw some aluminum pipe with modified air filter and run it down to the wheel well will it work like a cold are intake???
yaz4real
07-24-2007, 10:29 AM
There is an air temperature sensor you need to be concerned with when you decide on this experiment.
There is little advantage to coverting the stock system to any aftermarket or invented system. Good Luck.
stupidquestions
07-25-2007, 12:53 AM
just wonderin.... how important is the air temp sensor
yaz4real
07-25-2007, 05:11 AM
For your reading enjoyment
http://www.saturnfans.com/forums/showthread.php?t=102439&highlight=IAT
stupidquestions
07-25-2007, 06:31 AM
well thank ya.... another question..... why do both of my saturns have leaks??? i unknowingly had them washed..... i drove one and friend drove the other... i had some water come in but my other car was soaked....any reliable fixes short of redoin the whole weather guard and door seals?
yaz4real
07-25-2007, 11:50 AM
Do you have sunroofs?
If so, the drains are clogged..
