97 Sable
maniacmike
06-11-2007, 05:04 PM
Compresser went out on girfriends Sable and broke the belt. Does this car have the one big belt that runs everything? Can she run it without the compressor or not?
reekor
06-13-2007, 03:43 AM
Yes it only has one belt. if you can turn the compressor pully by hand while the key is off then replace the belt and disconnect the compressor clutch power harness. If not you might need to find a shorter belt to bypass the compressor.
