1998 3.8L Windstar won't start. Please Help!
danoly30
03-07-2007, 03:57 PM
Hi,
I drove my windstar for shopping, park for 2 hours, when I'm done shopping, it won't start. It crank, but the engine just didn't start. I tried several times. I know the motor starter and battery are OK because it crank. Gas is about 1/3 full capacity. I checked all the fuse under the hood, and they are OK. Do you have any idea what wrong with my car ?
DRW1000
03-07-2007, 07:39 PM
That isn't much to go on but if an engine cranks well but will not start then it can usually be traced to an ignitioon problem or a fuel delivery problem.
danoly30
03-07-2007, 08:30 PM
So, there are two posibilities. How do you pinpoint easily, whether it is ignition or fuel delivery?.
DRW1000
03-08-2007, 06:46 AM
There are two COMMON possibilities.
For ignition you can purchase an inexpensive spark tester. You disconnect one spark plg wire at the plug and using this tester you look for a spark while a helper cranks the engine - Be aware that this is high voltage.
For fuel you can check the pressure at the fuel line schraeder valve which is under the hood. I would be careful though as fuel will squirt out if pressurized.
danoly30
03-08-2007, 07:30 AM
Thanks DRW1000,
I will try those today.
DRW1000
03-08-2007, 08:19 PM
Thanks DRW1000,
Post back with what you find out.
danoly30
03-08-2007, 08:38 PM
OK,
I bought a spark tester. I only tried the front cables, as it is accesible. All of them gave a spark. So I guess the ignition sysytem was OK? I didn't tried the fuel system though 'cause I am not sure how to do it. Can you give me more detail explanation? Do I need a fuel pressure gauge? It seemed pricey.
Thanks.
Thanks.
thscott
03-12-2007, 01:11 PM
OK,
Thanks.
I had a similar problem recently which was caused by a faulty electric fuel pump and bad wiring to the fuel pump. The fuel pump is a motor located inside the gasoline tank.
Normally when you turn the ignition to start you will/can hear the motor running.
I suspect with your no-start condition you don't hear the motor running.
Thanks.
danoly30
03-13-2007, 08:22 AM
Yes, it was the fuel pump. We replaced it with a new one yesterday. Now the engine run. But, the fuel gauge stuck above full. Any idea?
wiswind
03-15-2007, 08:48 PM
The fuel pick-up arm, with the "sock" filter floats up and down with the level of the fuel in the tank.
On this arm is a sensor that gives the fuel gauge the level of the fuel in the tank, based upon the position of the pick-up arm.
It is possible that the fuel level sensor is not connected.
