Problems after Isolator bolt fix
cabron1
11-02-2006, 03:02 PM
I did not have the CEL on ( 2000 Windstar, 3.8 ) but since it was pinging and I had poor gas milage I decided to do the Isolator bolt fix.
It went smooth. The lower intake manifold was filled with oil to the point I could not see the isolator bolts. Any way, I completed all the steps, and put the beast back together.
As soon as I started the engine, I noticed it was idling poorly; jumping from 400 rpm to 1300 rpm. A few days latter, the CEL came on. I get the infamous 171/174 codes.
What you suggest. Could it be a vacuum leak.
Thanks for your help
phil-l
11-02-2006, 07:34 PM
I also did the isolator bolt fix on my 2000 3.8. Like you, I didn't have a CEL - but lots of pinging.
Yes, it could be a vacuum leak. Are you sure the fittings on the back side of the manifold are firmly in place?
If you spend some hood-up time listening to the engine, can you hear any new, unfamiliar sounds? Hissing or whistling sounds are what we're hoping to find.
DRW1000
11-03-2006, 02:09 PM
Normally the 171/174 together indicate an intake leak on both banks. As suggested by Phil-1 look for a loose or disconnected vacuum hose etc.
Are you confident that the rubber port seals were installed correctly upon reassembly? Perhaps you accidently knocked off a hose somewhere else.
MrCreosote
11-03-2006, 03:53 PM
There is the infamous 90 degree 1/4" nipple that blows off the intake every time you start the engine and it coughs just once.
It is in the middle of intake, in the front, there is a 180 deg bend of 1/8" black Tygon tubing connected to it.
When this pops off, your engine idle will oscillate noticeably when the engine is cold. This is a massive vacuum leak.
rodeo02
11-03-2006, 08:02 PM
Yep, thats the fuel pressure regulator vacuum stub. Found that one out the other day.:icon16: I did a DIY de-carbing service just before my oil change. Idled the van and sprayed carb cleaner thru the PCV and throttle body and sprayed thru the FPB stub. Took her for a spin and had the horrible RPM oscillation at idle. Got home. popped the hood and found I forgot to reconnect the FPR line to the intake!
Joel
cabron1
11-04-2006, 09:10 AM
Found the problem,
It was a vacuum hose that I didn't connect.
Man, what a difference. No ping, more power, more responsive.
It been years since the van worked this well.
Thanks
