Sable won't start
smithpm
07-07-2006, 07:19 AM
My son has a 93 Mercury Sable(3.8l) and it will not start. There was no fuel goin to the engine so i got a new fuel pump put in and it still will not start. the engine is strong and it trys to start( it cranks but it wont start). The car just recently had a oil change, a new fuel pump, a new alternator, a new distributor cap, and rotor button. Any idea what the problem could be????
reekor
07-07-2006, 10:19 PM
Check the fuel pump relay.
mikeypooh1
07-11-2006, 03:45 AM
I have the same problem. I put in the new pump and still no fuel pressure or no pump turning on. It may be the pump relay then. Where is it? Is there also a fuel pump fuse? I have the 1994 sable 3.8.
Thanks
Mike
KimMG
07-11-2006, 04:44 AM
Make sure you have power going to the fuel pump. There is an inertia switch located in the trunk, check to see if it is closed.
awanstradinginc
07-22-2006, 12:24 AM
check fuel injectors and filter
mikeypooh1
07-22-2006, 05:39 AM
I found out the problem. It was in the wiring. the connector near the the radiator was bad. Thanks for everything.
