2001 Windstar ABS Codes
Sheera224
05-09-2006, 12:16 PM
My ABS light sometimes goes on while I'm driving; Ford gave me the codes for $100 but no real explaination of what's wrong or needs fixing, only that it would cost another $1300.
Please tell me what the codes mean:
C1185
C1194
C1198
C1220
C1214
C1235
C1236
C1246
C1250
C1446
Failed HCU and ECU
Thanks,
Sheera :banghead:
C1185
C1194
C1198
C1220
C1214
C1235
C1236
C1246
C1250
C1446
Failed HCU and ECU
Thanks,
Sheera :banghead:
frostie
05-09-2006, 06:48 PM
Here are explanations of some of your codes:
C1185 ABS Power Relay Output Circuit Failure
C1198 ABS Inlet Valve Coil LF Circuit Failure
C1194 ABS Outlet Valve Coil LF Circuit Failure
C1246 ABS Outlet Valve Coil RR Circuit Failure
C1250 ABS Inlet Valve Coil LR Circuit Failure
C1214 ABS Inlet Valve Coil RF Circuit Failure
You can Google the rest.
I would say your ECU is bad, but I am not sure about your HCU. Maybe one of the other guys on this forum can help.
DRW1000
05-09-2006, 08:56 PM
I would aslo rule out a voltage problem. Seems like a catastrophic failure and that makes be think that there is one single point of failure
