leak in the oil pan...
nemets88
03-13-2006, 09:09 AM
i have a very small oil leak seeping through the gasket in my oil pan. Would buying something like and STP Stop Leak, or some other product along those lines help stop the leak? This leak is very small, i have to add a quart about every month or two so it's really not bad. but would one of these products work or would it be a waste of my couple dollars?
e_powers
03-13-2006, 09:24 AM
i have a very small oil leak seeping through the gasket in my oil pan. Would buying something like and STP Stop Leak, or some other product along those lines help stop the leak? This leak is very small, i have to add a quart about every month or two so it's really not bad. but would one of these products work or would it be a waste of my couple dollars?most likly not. most of these products just makes the gasket swell to get it to quit leaking. eventually it wears off and the leak is larger. so they are mere bandaids.
it is best to replace.
flybynight
07-13-2006, 02:24 AM
hey i myself had this same problem very common in all ford cars to have that leaky oilpan gasket, particularly the 93s. anyway its kinda costly to get it replaced because you have to take off part of the exhaust includding the cat section in order to get the pan out once you get it disconnected..... its a giant pain... i spent a day and a half changing mine.. and the biggest trick of all is getting the new gasket to seal properly because they don't make a rubber gasket for those its actually a jelly that goes around the edges.... hence its hard to make it seal..... good luck to you!
