2000 Mercury Sable LS Premium Wagon
pvachon
01-07-2006, 05:26 PM
My Auto Headlight lamp, Dash lights, and Tail lights fuse keeps blowing. I replaced the fuse three times and every time I turn on the lights it blows! Does anyone have any suggestions or has had similar problems?
Thanks
kam300m
01-19-2006, 08:54 PM
It sounds to me like you have a bad ground, You could also not be putting the right amp fuse in it, check the cover of the fuse panel to see which fuse is right for it. could also be the relay that those are connected too. I would check all of the headlights and taillights to see if they are grounded correctly, I hope this helps!
Kalvin
Banjoman10
02-13-2006, 09:17 AM
It's a short circuit. That's what a fuse is for; to protect the wiiring from a meltdown (or even fire) in case of a short. Now the trick part is to find where the short is, and for that you need a VOMeter and the knowhow how (and where) to use it. Once the short is located, it's (usually) an easy fix.
