97 mercury sable accessory
dluxx28
11-13-2005, 03:39 PM
Can someone tell me where I can find the accessory ignition wire, remote, or power ant. wire in this car?
burrelld
11-17-2005, 12:52 AM
If you wish to do any work on the car or plan to keep it for awhile, invest in BOTH the Chilton and Haynes manuals for that model and year of car. Haynes has many pictures and instructions that Chilton doesn't have, and vice-versa.
One part of the power antenna wire is found at the base of the power antenna while the other end is found behind the radio in the dash panel. In the fuse box, located inside of the engine compartment, you'll also find fuses for all accessaries.
Normally, when something stops working on my automobiles, I check all of the fuses first. If I replace a burned out fuse and the new replacement fuse burns out too, then there is a more serious problem, such as worn out wiring insulation causing a short, or burned out electrical motors or switches, etc.
