Front subframe mound captive nut access??
milo66
10-26-2005, 07:58 PM
I have a failed subframe mount on the driver side, front mount of my 1995 Sable. THe subframe is hanging an inch or so low to that side and a massive clunk is apparent when I accelerate from a stop. I was removing the bolt that goes thru the mount, subframe and into the body rail above. I got a few turns successfully, then the captive nut in the hollow body rail started to spin, now I can't remove the bolt! What is the method to access the nut so as to put a wrench on it? This is the area below the battery, which I will be exploring soon!!! Any tips?
burgandi12
11-24-2005, 04:45 AM
Actually, this is not a tip (sorry), i'm just a semi-car-illiterate girl who had a similar problem on the passenger side of my 94. While getting new tires at Just Tires, i somehow schmoosed the mechanic into fixing that same massive clunk for free. Appently, the subframe weld cracked and he rewelded it. But the weld must have failed (or it was a crap job to begin with) because the clunk came back. Since you apparently know what you're dealing with, could you suggest a more permanent solution????
burrelld
11-24-2005, 02:10 PM
As the previous message stated, you'll have to have the nut welded in place. Or, if you have access to the area, just remove the factory nut and install your own.
