new member-93 saturn help please
rickr_ohio
10-19-2005, 08:38 PM
First, thanks for any help in advance. The car is a 93, I believe SL. It's my son's and not real sure of the model. 4 door with sohc throttle body fuel injection, if that helps.
Died on him the day before yesterday. By the time I got there, about an hour to pick him up, the car started. I drove it home, but after about a mile it started spitting and sputtering. I kept pumping the gas, and it would surge and I got most of the way home. Died again. Waited about 20 minutes and it restarted.
Because he doesn't take real good care of it, the first thing I did was change fuel filter, air filter, plugs, wires, oil and filter. Car started and ran good. Took it for a test drive. Ran good for about five miles and started doing the same thing. Got it home and checked the error codes. I'm having a little trouble understanding the flashes. After the 3 code 12's I get 3 flashes, a pause, and 4 more. Is that error code 34?
I cleaned and tested the coil pack. 8500 ohms resistance. If I clear the error codes, the car will start and run real good for a couple minutes, then start to die. If I pump and fiddle with the gas and keep it running until the service engine soon light comes on, it will run good until I shut it off. Then it won't start again unless I unhook the battery. Does anyone have any idea what to check?
Thanks,
Rick
Thanks,
Rick
sierrap615
10-19-2005, 09:43 PM
code 34 relates to the map sensor - http://www.differentracing.com/tech_articles/dtc/34.html
can you please double check the code? this is not a very common code for saturns(32 is, 35 isn't rare ether)
check the connectior to the map sensor. the map sensor will be connented via a vacuum line to the throttle body.
shaner123
10-19-2005, 10:11 PM
come to think of it i used to own a dodge that had very simular symptions, it just ran like crap, didnt want to start, all sorts of stuff, i got a new map sensor i think was quite cheep, 50 bucks or somthing, and it fied all problems
if a little water or somthing gets into that it messes it all up
rickr_ohio
10-19-2005, 10:12 PM
Thanks,
Rick
I reset the system and ran it until I got the error code again like 7 times this evening. Always the same code. 3 flashes, pause, 4 flashes. Would the map sensor cause these symptoms?
Thanks,
Rick
Thanks,
Rick
Thanks,
Rick
ASE_Tek0312
10-28-2005, 02:22 PM
It sure would there buddy. I was workin on a 97 lumina and left the MAP sensor unplugged. The engine had a miss until i plugged it in. Just one question for you though. Did you buy that TBI car so your son wouldnt get any speeding tickets?
stevestar99
11-01-2005, 08:29 PM
Not sure, but it sounds like a bad fuel pump. Never had a bad one on my SL 1, but other cars that I've had a bad pump on, start up great, run a little while and then crap out. Let it sit, starts great, runs a few minutes and dies.
rickr_ohio
11-02-2005, 05:35 AM
It was the map sensor. Replaced it and haven't had a problem in over a week. Thanks for the help.
Rick
Rick
domesticdisturbans
11-06-2005, 07:30 PM
a buddy r u in ohio and what part ???
rickr_ohio
11-07-2005, 05:38 AM
Yea, Southeast. Why?
