Blower Settings Not Working
emsp80
12-30-2004, 08:49 PM
I have a 2000 3.4L impala. Recently 3 of the 5 blower settings for heat and A.C went out. 1,2 and 5. Does anybody know why? Fuses seem to be alright and working . Please Help!?!? :confused:
jhuckaby
12-30-2004, 09:16 PM
I had a similar problem, fan would not work on setting 1, but would work on 2-5. Dealership replaced blower fan resistor that had shorted out. Not sure how much it cost, was covered under warranty.
bbeaven
12-31-2004, 03:50 PM
my 1 and 2 dont work. is there a TSB on this?? i know its a common problem, and if tehre is a TSB im thinking there might be a way to get them to fix it for free, or discounted.
bermis519
12-31-2004, 11:14 PM
I had mine replaced also, it wasn't a bad fix but I paid 78.57 to have it done...took them about a half hour to do it.
mike
jhuckaby
01-03-2005, 06:40 PM
Have not been able to locate a TSB on this.
84fiero123
01-03-2005, 08:02 PM
it should be close to the fan housing under the hood just follow all the wires coming from the fan and you should find anouther plug going into the ac housing at least thats where they used to be in the 80s and 90s
MI2600
01-10-2005, 11:10 PM
Before you go spending $$ at a dealership, I would check the 4-connector plug on the heater motor. Gms are/were famous for corrosion on these connectors. Remove it, clean the terminals and apply some dielectric grease. You might be surprised.
