windstar missfiring on 1st and 3rd cylinders
norm12
11-03-2004, 09:59 PM
I have a 2000 ford windstar 3.8L. It is missing at idle and accel. I took it to my shop and he has replace all the plugs, wires, coil pack and three injectors with no change. What else can be causing the miss. There are no code that he can see. Please help me with this my wife is about to kill me if she does not get her van back soon!!!!!!!!!!!!!
justatech
11-03-2004, 10:04 PM
how many miles on the engine...
norm12
11-03-2004, 10:23 PM
73,000 miles
justatech
11-03-2004, 10:26 PM
check the intake gaskets these are bad about leaking also have your mechanic load the engine until it begins to miss then unplug the egr valve, if the miss goes away then the egr passages will need to be cleaned
justatech
11-03-2004, 10:30 PM
also decarbon the engine..could help
DRW1000
11-04-2004, 07:33 AM
Of course you can also disconnect the vacuum control to your EGR valve yourself and drive the vehicle to see if the problem clears up.
