Oil pan gasket replacement?
e_a_olson
07-14-2004, 01:05 PM
How easy is an oil pan gasket replacement? What are the steps involved? Drain the engine, drop the pan, clean the pan and block, replace the gasket?
sierrap615
07-14-2004, 01:16 PM
yikes, i looking in my hanyes and its much more than that. buy a hanyes manual if you are going to do this. you need to remove the downpipe, crank pulley, engine mount, and expose the flywheel
e_a_olson
07-14-2004, 02:19 PM
Sounds like fun. How much was the Haynes?
emailer33
07-14-2004, 04:37 PM
http://www.amazon.com/exec/obidos/tg/detail/-/1563923335/qid=1089837399/sr=8-1/ref=sr_8_xs_ap_i1_xgl14/104-0852471-8583916?v=glance&s=books&n=507846
new price is $20
used books, $6
sierrap615
07-14-2004, 11:30 PM
check autozone or other part stores, i think mine was 17.99
e_a_olson
07-16-2004, 10:42 AM
I thought I lost my manual, but I found it last night. What do I need to do to the engine mount? It sounds like I have to pry it out of the way or something. What tools do I need to complete this job? I've just got a ratchet set, a torque wrench, a hydraulic floor jack, and 4 jack stands.
emailer33
07-16-2004, 04:51 PM
just read the manual, it will tell you all the steps and you can decide.
e_a_olson
07-17-2004, 09:52 AM
RTFM, thanks for the advice. :rolleyes:
bobenhotep
07-17-2004, 02:44 PM
ive taken the oil pan off of a 94 sl1. you have to take off all kinds of stuff, and turn the oil pan just right to get it out from under the car. i didnt use regular rtv, but used the gray stuff from the saturn place. there is more to it than the book says...
e_a_olson
07-20-2004, 09:41 AM
Ok, what is 'regular rtv', and do you know what steps were not listed in the manual. This info would be most helpful. Thanks.
sierrap615
07-21-2004, 01:17 AM
RTV = Room Temperature Vulcanization, or basicly, gasket in a tube. saturn sells it, or you can pick it up at any auto store. i use Permatex Ultra Black Gasket Maker (PN 598B or 598BR) be sure you get the sensor safe stuff.
