A/C stoped blowing cold air
tinky022
05-30-2004, 03:50 PM
2000 Sl2 -- I turned my car off the other day with the A/C working fine, but when I started it back up it was no longer blowing cold. I replaced the fuse but that was no help. I've never had a problem befoer. Any ideas ?? anything would be appreciated
Lucas1
05-30-2004, 04:56 PM
check and see if the ac clutch is turning with the AC on. it probably will not. if not you should check the ac pressure switch, its near the battery, has a 2 wire connector going to it. rodents love to chew those wires for some reason......if that is ok, then youre probably just low on freon, if the system sees no pressure, it wont turn on the ac clutch to prevent damage to the system.
tinky022
05-30-2004, 05:42 PM
thanks for the info I checked that and it seems to be intact... I will check to see if its fully charged .. thanks again for the help
