Help!!! 2002 brake lights screwed up
erichandtwalla
03-29-2004, 11:33 AM
My rear window brake light works but the tail lights do not. have eliminated the bulbs and fuses, don't know where else to look. Please help. Is there a switch or relay that may need to be replaced and if so, where is it?
DRW1000
03-29-2004, 12:14 PM
Would that not still be covered under warranty?
rodeo02
03-29-2004, 12:21 PM
Like DRW- says, hopefully you are not over 36Kmi, in which case should be under warranty. Do you have a trailer hitch / trailer wiring? These can cause issues due to poor or corroded connections.
G/luck
Joel
erichandtwalla
03-29-2004, 12:28 PM
G/luck
Joel
Vehicle has 37,000 miles. I called, but they wont cover it. Do not have a trailer hitch.
ModMech
03-29-2004, 01:22 PM
If the 3rd light works, then the brake light switch and fuse are good. Sounds like the LCM (Lighting Control Module).
My manuals are at work, I can pull up the diagrams later and see if there are any other likely posibilities.
erichandtwalla
03-29-2004, 05:25 PM
Thanks, where would the LCM be found? Please advise
