1999 Windstar lights bright and dim
ozarksman
02-06-2004, 02:13 PM
Hi,
I noticed the other evening that my 1999 Windstar lights, headlights and interior, sort of pulsed from normal to dim, back and forth. A few miles back, 2,000 or so I put a new rebuilt alternator on, $189.00 worth; do you suppose that the alternator is bad already or could it be something else? Any suggestions would be greatlyl appriciated!
randkell
11-24-2005, 01:32 PM
Hi,
My 1999 ford windstar is doing the same, I have recently replaced the alternator and checked the battery connections. Have you resolved your problem
LeSabre97mint
11-24-2005, 02:56 PM
Hello
Is the brightness relitive to your engine speed? How about the load you have on your electrical system? It could be a bad ground....somewhere...
Six years old is old enough to have corroded wiring or corroded ground locations.
Regards
Dan
Hello
Regards
Dan
wiswind
11-24-2005, 03:45 PM
I had a Motorcraft rebuilt alternator (about that same price) burn out in less than a month.
By burn out....I mean the side of the case melted....molten alluminum.... I believe that the windings went out. The alluminum heatsink on the regulator was fine....but the case over the alternator windings was melted.
So....yes, a "new" alternator can fail.
There is a fue for the alternator in the engine compartement Power Distribution box (also contains relays). It is "T" and is 15 amp....it is a little mini fuse....This is on my '96.
The Black with orange strip wire that connects to the alternator stud connects to fusable links "A" and "B" and from there to the positive battery terminal.
The other thing that I would do is consider the battery.....anything over 5 years is old.
I bought a battery from Autozone, 1000 Cranking amps, 850 Cold Cranking Amps (CCA)....and the price was resonable.
Sometimes the 2 items (alternator and battery) fail together. A bad battery can place a load onto the alternator.
12Ounce
11-24-2005, 04:17 PM
You may want to hook up a elect pigtail into the cigar lighter. (Radio Shack can sell you some plug hardware.) To this you hook up a voltmeter, inside the cabin, and watch for voltage fluctuations. The cigar lighter is fuse protected, but other than that is "hot at all times" ... right off the battery plus buss.
The headlights, on the other hand, are fed thru "switched power relays".
I kinda expect you will find your problem in the alternator ... but it's not a slam-dunk.
randkell
11-25-2005, 12:51 PM
Hello
Regards
Dan
It is not reletive to the engine speed, driving at a constant speed the inside lights, headlights and heater fan fluctuate at the same time. I am going to hook up my voltmeter with a full load and watch it for volt loss. I may have a new alternator that is going bad.
Regards
Dan
randkell
11-25-2005, 05:53 PM
I Checked with the volt meter, sitting idle it was drawing 14 volts, as I turned on the lights, radio and heater it dropped to 12 volts. When I accelerated it went up to 14 volts and as I took my foot off the gas it dropped back down to 12 volts again.
wiswind
11-25-2005, 06:20 PM
Sounds LOW.
You can have the alternator tested at most auto parts stores. Might be the way to go.
randkell
11-26-2005, 11:33 AM
Sounds LOW.
The alternator checked out good but they replaced it anyway. The new alternator resolved the problem. It appears it was not charging at low RPM. Thanks for the help!!
