Fan problem
MJon
08-22-2003, 08:12 PM
I have a 1992 SC. My fan won't kick in. I hot wired it and it works. I checked the relay and it's ok. The book indicates it's a bad PCM ... does anyone have any othe ideas or know where I can get a good used PCM?
sierrap615
08-27-2003, 01:03 AM
first, see if it works when the A/C is on
smoka_9
08-27-2003, 11:49 AM
If it is the PCM try 6thplanetusedparts.com.
whiteknight
09-22-2003, 12:08 AM
Have you checked the temp. sending unit for the PCM If it hasn't been change it may be cracked and shorted out & not sending any data to the PCM so the PCM thinks it cold. This is only about a 15 buck part and change in 5 mins. without draining no collant. Good Luck. :2cents:
SATURN_N_CAMARO
10-09-2003, 12:04 AM
on my 96 i ran a hot wire to a switch and then to the fan w/ a ground goin to the fan ground to.... disconected the factory plug, now i can turn my fan on when ever to keep the motor cooler ....ALSO TURN IT ON WHEN YOUR A/C IS ON
