2007 Impala door/warning chime will not shut off
Black_Blade
07-23-2014, 01:10 PM
Has anybody had this chime go off on them and not shut down? Well, it will stop when you stop the car, but as soon as rolling again, it returns steady. I can maybe find a wire to disconnect, but is it some underlying issue?
Apparently the sound comes through the speakers now, not a separate chime, so not so easy to just snip a wire to shut it up.
Tech II
07-23-2014, 08:14 PM
Chances are you have a bad door ajar switch....a professional scan tool, like a Tech II, would be able to detect which one is causing the problem....
Black_Blade
08-01-2014, 12:33 PM
Update: Turns out the battery had a seriously low level of charge, I put the battery on charger overnight and it took care of the issue. Although now it just dings every now and then when ABS light blinks on. (ABS is such a pita)
I have a OTC Genisys Evo, running 4.0 software at the moment. Still a newb at using a scanner though, and making the most of all it can tell me.
