Low servo repair: transmission slip problem solve
northern piper
02-28-2013, 01:56 PM
Hi
Below is my repair of the low servo on the transmission, an AX4S, which is on many windstars. My van is a 2000, 3.8, that had 190,000 km, at initial symptom occurence.
Symptoms: on driving from a stop the transmission slips when approaching the change to 2nd gear. This slip is most evident when driving up hill, and at the transition between 1st and 2nd gear, the RPM will quickly jump while the transmission appears to be in neutral. 2nd gear eventually engages and the same symptoms may appear at the transition from 2nd to 3rd gear.
Repairs to correct symptoms: Initially I dropped the pan, replaced the filter, did a full transmission fluid change as detailed elsewhere on this forum. I also added, on the advice of the Ford service dept, 2 bottles of AT-205 which is an anti-slip product. The fluid I used for the change was MerconV as suggested. There was no noticeable change in the transmission performance.
Following this unsuccessful repair I pulled the low servo cover off. Approximately 1/2 litre of transmission fluid spilled out which I was prepared for. This fluid was discarded. See post # 6 below for suggested method for servo cap removal. On removal of the servo cover the gasket beneath the cover was ripped and the parts beneath it are pictured below.
http://www.automotiveforums.com/vbulletin/attachment.php?attachmentid=48247&d=1361641585
As you can see, the e-clip which fills the grove between the spring and the piston was missing. This meant it was floating around somewhere in the transmission, which was not good of course. As luck would have it, I managed to find the bits of broken e-clip within the housing of the servo on the transmission body.
http://www.automotiveforums.com/vbulletin/attachment.php?attachmentid=48248&d=1361641585
Carefully "puzzling" the parts, I was relieved to see it was complete, and nothing should be floating around the transmission.
Buying just this e-clip was difficult as it isn't a standard e-clip, but one that is thicker. I ended up purchasing a whole kit of parts which included:
piston, pin, replacement e-clip (which looks simply like a regular washer cut in half) servo spring, 3 rubber o-rings. Below is the kit (minus the piston and large servo spring).
http://www.automotiveforums.com/vbulletin/attachment.php?attachmentid=48272&stc=1&d=1362080164
The spring pictured above is the original spring and retainer. The pin as shipped is slightly longer than the original pin. This kit covers several different transmissions and therefore needs to be machined down. I carefully measured between the grove at the top of the OEM pin to the pointed end, then ground down the new pin at the pointed end to match. (I did leave 0.2mm longer as I've heard that the oem pin is slightly too short and reasoned as well that some wear likely would have occurred. This extra length has worked out fine). The 3 rubber o-rings were installed, the spring, retainer and new e-clip (split washer) installed, the new piston installed. The original e-clip from the old pin was removed and re-used for placement on the top of the piston on the new pin. This is per the instructions on the new pin kit and as they don't provide a new e-clip, I had no choice. Note the e-clip that breaks frequently (I've learned thru discussion) is that e-clip that is mid shaft on the pin, not the one on the top of the piston.
Here is a pdf link of the info that comes with the kit, along with installation instructions and part numbers.
48271
You'll note on the instructions it says to measure travel of the piston by drilling a hole in a spare servo cap and measure with a caliper. Well, as I didn't have a "spare servo cap", I was unwilling to do this of course. As I said earlier, measuring the length of pin and adding a very small amount worked out fine.
Not included in the kit are the servo cap gasket, the rubber o-ring which is within the cap, and the rubber o-ring which runs around the perimeter of the piston. I replaced all of these as well.
Once everything was all assembled, I carefully inserted the assembled piston, new large spring (discarded the large OEM spring) into the transmission. I placed the cap on and used 12Ounce's suggestion of longer bolts. The bolt size on my transmission is 20 mm long, M6 x 1.0. I bought 3 sets (20, 25, 30mm) and used them to incrementally tighten the cap back on. I did not lower the sub frame. I have a 2 post lift which allowed me to stand beneath the van and work on the servo which was nice. It also (I'm thinking) caused the suspension to sag a bit allowing access, although it is tight.
Once the cap was back on, I filled with about 1.5 litres of mercon V. I started the van and went through the gears, things seemed ok. Took it for a drive and must say it shifts "better than new". The new longer spring (the 96995A as per the diagram) while the longer spring leads to smoother shifts vs the OEM one. I can confirm this.
The van is now back and on the road, my wife says "better than ever" which is great to hear. Total cost for this repair was around $150.
Any questions or things that aren't clear, please post and I'll explain better.
My bottom line, if your van is high mileage and is slipping, this is not a bad DIY job that could easily save you some big coin.
np
48271
np
phil-l
03-01-2013, 08:16 AM
Piper -
Wow!
Thanks for sharing your very clear pictures and write-up. This is very useful!
My transmission has never been opened (except for filter replacement), but I'm considering doing this as a preventive item.
After reading many Windstar transmission horror stories, it's great to see that - with care - these transmissions really can be dependable, long-term runners.
Wow!
northern piper
03-01-2013, 08:31 AM
no problem Phil...we're all in this together eh?
If I look back on the day the trans slip started, it's pretty easy to see what happened. The day was very cold (-34 degrees Celsius). My wife took the van from our driveway, without warming the van up, to drop kids at school, then back home. Total trip was probably 3 miles. Knowing that the e-clip was original, the freezing cold temp, the block on the motor just as cold, cold trans fluid,... little wonder that the clip shattered.
Since posting my write-up I also learned that the pin and new e-clip package is an aftermarket "fix" for frequently breaking e-clips. Funny as I haven't heard a lot of folks complaining about e-clips breaking but possibly they're just not opening the low servo and finding it, instead just having the trans replaced... which is huge bucks of course.
Choosing to remove that e-clip before it breaks I feel is a good idea. If I wasn't lucky enough to find the 4 pieces, then it WOULD mean tearing the whole trans apart.
If I'd known how weak this e-clip was a month ago, I'd have replaced it as a maintenance procedure, as it wasn't too bad a job now that I've completed it. Granted, I had to do a lot of digging to find out which parts and numbers, picking peoples brains for help, but that being said, it's no more difficult than lots of windstar repairs we tackle.
I'd suggest if people haven't done this upgrade, I'd be seriously considering doing it.
Hopefully my pictures and write up will help those that tackle the job.
phil-l
03-01-2013, 08:40 AM
Yes, I suspect most people just head to a shop - which will likely tell them that the tranny needs to be replaced/rebuilt.
phil-l
03-01-2013, 08:50 AM
Piper -
As I'm reading more closely...
How difficult was it to take the servo cover off originally - with the OEM bolts? Is there anything special to do in order to prevent things from flying out?
Where did you purchase parts? Did you get the servo kit from the same place you got the gaskets?
Thanks!
Thanks!
northern piper
03-01-2013, 09:10 AM
the servo cover comes off easily. I should edit my original post but what I did was loosen the first bolt, insert one which was 2 cm longer, then loosen the second, insert a 2 cm longer bolt, then the third bolt 2 cm longer bolt. That let me gradually ease the cap off without having the spring shoot the piston out. Installing was just the reverse, except I started with the longest 3 bolts, then removed one of them, inserted a 1 cm shorter bolt, (then 2nd then 3rd) then finished with the OEM bolts. It was a bit tedious in doing this but really made the cap slip on perfectly. The new piston with o-rings means for a tight tolerance and if the cap goes on slightly cock-eyed you risk breaking the bolts. When the cap is squarely aligned, the bolts really tighten quite effortlessly. I don't know what sort of torque I used in the final tightening; couldn't find a value for that anywhere, but they weren't very tight when I undid them. "Just tight enough" is what I did... then check for leaks.
I got all my parts from a place called KingOMatic as I'm in Canada. It's here. http://www.kingomatic.com/ProductsMain
but I understand they come from the place I refer to in the instruction pdf file called Sonnax. Here is their "where to buy" page. http://www.sonnax.com/where-to-buy
It seems these parts are readily available, which is nice.
phil-l
03-01-2013, 10:30 AM
Piper -
Thanks for the clarification! I suspected you did something like that - but your confirmation goes a long way toward completing a job like this with confidence.
northern piper
03-04-2013, 06:38 PM
Just because it was bugging me not knowing I looked for the torque spec for the servo cover. I couldn't find the value for the lower servo (the one I've done this write up about) but did find that the overdrive cover (which looks identical) has a bolt spec of 10 Nm or 89 Lb-in (yes "inch" pounds..) so anyone doing this repair, there's your setting.
As a follow up, I put the van on the hoist this weekend. Everything was dry, no leaks and the transmission continues to function very well. Here's hoping that continues.
phil-l
03-05-2013, 07:51 AM
Piper -
Thanks for the updated info.
Yes, watch those "inch-pounds". Some people on this board got messed up on that issue for the isolator bolt fix.
Congrats - I'm pleased your repair is working out well!
scubacat
03-06-2013, 07:24 PM
All thanks to the haynes manual for that typo.
scubacat
03-06-2013, 07:25 PM
The original e-clip from the old pin was removed and re-used to hold the piston on the new pin. This is per the instructions on the new pin kit and as they don't provide a new e-clip, I had no choice.
What do you mean by this? Isn't the e-clip the thing that broke into 4 pieces (or am I missing the point entirely??)
northern piper
03-07-2013, 07:08 AM
good catch scubacat... I wasn't particularly clear on that part. I've edited the posting.
The e-clip that I am referring to is the one that sits on the top of the piston. From what I've learned, it's the mid shaft e-clip that breaks frequently. 12Ounce I think had this happen IIRC. Anyway, the retrofit with new parts asks you to use the old e-clip from the top of the piston on the new pin. It fits perfectly, which was a relief of course.
Here's a pic. It's kinda dark but you can see how the e-clip (the OEM one) fits into the new pin before inserting into the housing of the trans.
48308
48308
12Ounce
03-07-2013, 07:34 AM
When I had my clip break, it was very early-on and I suppose not enough clips had broken to trigger the update kit being designed. Therefore, when I went to Ford for a replacement clip ... I got just that: a replacement clip of the same design. Many miles later I replaced my tranny with a Ford reman, which I still drive.
I may now pull the low-servo to see if it has been upgraded on the reman.
scubacat
03-07-2013, 08:47 PM
I have a 2002 with an AX4N. I don't see any sort of repair kit for it so hopefully this won't be an issue for us. This is still some good info though as it's nice to know about serviceable transmission parts just for reference.
BTW - I picked up a junkyard OEM right CV axle that appears to be in amazingly great shape (and also seems to not be a rebuilt one meaning it would actually work) that wouldn't quite fit.................... because it's an AX4S axle that is identical other than being exactly 1.5" longer. Anyone in the Atlanta area is welcome to drop by and pick it up. It's currently doing a nice job holding down the floor in the garage.
mdare35
07-16-2013, 02:09 PM
Thanks for the write up! I'm having this similar problem with my 2000 windstar w/ 169K. I took it to a tranny shop that I have had good results with in the past on two other cars but this time the owner's helper noticed the ABS light on, cleared the codes before he drove it and then didn't feel any shift problems and thought they were some how related. I think the only reason he didn't feel anything is because when the tranny is cold it usually shifts ok. I think the only relation to the ABS is heat. THe ABS light will never come on during cold winter days. So I'm going to take my van back by the shop with some of this info in hand and see if he'll humor me and swap out this servo. I should do it myself and then go tell him I did it but I have a busy schedule this week before I leave for vacation next week...oh yea and I feel lazy!
If I do change it myself I'll probably buy the parts from here
http://www.transmissionpartsusa.com/
One think I do not see in their list of parts or in any of your pics is an o-ring called out as item 7 on this exploded assembly view
http://ww2.justanswer.com/uploads/tracker40/2012-09-03_135530_223.pdf
IS there an o-ring in the groove around the edge of that piston?
phil-l
07-16-2013, 03:06 PM
mdare35 -
Your ABS light is almost certainly unrelated to the transmission issue.
The '00 Windstar (and other years) ABS modules are notorious for errors related to the electronic portion of the ABS controller. I replaced the electronic portion of my ABS controller - and have had no further problems. Note that it's now possible for the ABS electronic module to be repaired (a service that wasn't available when replaced my module; search for "windstar abs repair service" on eBay to start your research). It's important to note that it is possible to replace the electronics portion of the ABS module without breaking into the hydraulic portion, though it's very difficult to successfully remove the appropriate fasteners if your module is corroded.
I can't comment on your o-ring question, but Piper will probably have further info.
mdare35
07-16-2013, 03:40 PM
Yea I like the transmission guy I go to but that makes me wonder about him. As far as ABS I've seen on ebay a guy that rebuilds the units for like 50 bucks. So if I decide it has to have working ABS in warm weather and get really bored I might lay on my back under the windstar some afternoon pulling the unit off so I can send it for repair. My guess is that won't happen!
phil-l
07-16-2013, 04:29 PM
I don't have experience with the Windstar ABS guy on eBay - but a friend use a similar service for a different car, with good results. I would have tried the service, had it been there when I had the problem.
The real challenge to this job is the 4 bolts that attach the electronic portion of the module to the hydraulic portion. The fasteners have Torx heads, so use the right tools. The fasteners themselves are steel - and the hydraulic unit is aluminum, so some corrosion is practically guaranteed. If you can remove them without damaging anything, you're home free. Reassemble with anti-seize compound!
mdare35
07-16-2013, 05:29 PM
I just stopped by the transmission shop and that guy is very hesitant to to this because or age and mileage...the vans that is, ha ha. And he still thinks there is some relation between the ABS and tranny...that really seems strange, almost like he's old school mechanical and doesn't understand all these electronic gadgets?
So I think I'll order the parts and give it a whirl. Might be a couple of weeks as I assume it will take a few days for the parts to arrive and I'm going to the beach next week so sometime after that.
I'll keep you posted.
mdare35
07-17-2013, 07:01 AM
On the morning commute it made 2 good 1-2 shifts with in 3 miles of my house, the third and fourth 1-2 shift after about 4 miles, bam! ABS light was off the whole trip which is only about 5 miles for me. It would have probably come on too if I had a longer drive.
northern piper
07-17-2013, 07:34 AM
to answer mdare35's question about the piston, yes, there's a rubber o-ring which sits in the groove of the piston. On the pdf that you posted it looks like #6, which on the diagram is just a tiny bit smaller than the #7 which is the ring that goes inside the cap. On the very first post I did on this topic I show a really big picture of the piston top. The groove you see there is for the ring (I removed it for clarity but should likely have left it in the shot.)
The only caution I'll add is that my trans is a 2000 so there might have been some mild changes though I didn't see anything indicating that when I bought the parts.
mdare35
07-17-2013, 08:50 AM
OK that makes sense as transmission parts usa has a cover o-ring (item Number 7 on the pdf and their item 29261)
I just don't see a listing for a piston o-ring. Does one come with the piston or did you just reuse the old one?
northern piper
07-17-2013, 09:10 AM
no, the piston doesn't include the o-ring (or at least my kit didn't) I'd for sure order a new one. The old o-ring was slightly larger, likely due to typical wear and needed replacement. I'd suggest you replace all those soft parts when you're doing this repair.
If you can't find a number post here and I'll find it.
northern piper
07-17-2013, 09:32 AM
http://www.automotiveforums.com/vbulletin/data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAALAAAAC8CAYAAAD YdSQlAAAB1WlUWHRYTUw6Y29tLmFkb2JlLnhtcAAAAAAAPHg6e G1wbWV0YSB4bWxuczp4PSJhZG9iZTpuczptZXRhLyIgeDp4bXB 0az0iWE1QIENvcmUgNS4xLjIiPgogICA8cmRmOlJERiB4bWxuc zpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmR mLXN5bnRheC1ucyMiPgogICAgICA8cmRmOkRlc2NyaXB0aW9uI HJkZjphYm91dD0iIgogICAgICAgICAgICB4bWxuczp0aWZmPSJ odHRwOi8vbnMuYWRvYmUuY29tL3RpZmYvMS4wLyI+CiAgICAgI CAgIDx0aWZmOkNvbXByZXNzaW9uPjE8L3RpZmY6Q29tcHJlc3N pb24+CiAgICAgICAgIDx0aWZmOlBob3RvbWV0cmljSW50ZXJwc mV0YXRpb24+MjwvdGlmZjpQaG90b21ldHJpY0ludGVycHJldGF 0aW9uPgogICAgICAgICA8dGlmZjpPcmllbnRhdGlvbj4xPC90a WZmOk9yaWVudGF0aW9uPgogICAgICA8L3JkZjpEZXNjcmlwdGl vbj4KICAgPC9yZGY6UkRGPgo8L3g6eG1wbWV0YT4K5JKPKQAAQ ABJREFUeAHt3XmMJVUVBvCH0+77vmvjgigqIooKIsOAjigoggi KG4rKxEQjxj800bQbiYkxiokSIwYVUXQQUIkKCDMquOEIKuJOu +/7vlu/w3xt0fbA0NOv3+t59ybVVXXvuWe73z116la96h2e8Yxn/GevvfYa3P3udx/8/e9/H/z73/8e/Otf/6rN+dTU1OC6173u4G9/+9vgpz/96eAPf/jD4EY3utHgtre97eAWt7jF4NrXvvbgd7/73eCPf/xjHa9atap42O+www6Df/7zn7V3fq1rXWtgr0/a8P7LX/4y+MUvfjG4wQ1uMPjtb387+OUvfzlQtF3vetcrfuhvfvObD+56 17sONm3aNPjzn/88+P3vfz+48Y1vPLjJTW4yuOc971n7f/zjH0V/wxvesOyhN5uc40d/hR7/+c9/io892fSj71//+tfqy3a8+QMfezT42eiEj01hB/ns0xff0ODvWEFDDh58rP42t7lN2aKPTbn1rW9dvNDzA/6/+c1vBj/5yU8GP//5zwfXuc515vQmk43k0gfPyMk+45px0J9P6ME+fehJJzrER47R2 usbP7BBid3Xv/71iwadNps25/jCCd3xoied2WUf/9JF2ze+8Y0aBxhbv379YO3atUXzmc98ZrBmzZrBbrvtVrpM7bH HHoOb3exmBQbGpFDUplAAYH70ox/V/o53vGMBVj1hhKY4Zrh67TYKZvAYpY4R+KPXxmnqbnrTmxYrTuK QtDMQ+AwcJ1x++eWD293udoO99967BgovcuNc+/SNHnS65S1vWXxCb3D/9Kc/lQ7a6aIfEOMXwFNKvU29LQOIPz4KwOOdAdSWgaSTLXIcs1FACA 8DztfO6XD7299+Th8+MlZk/+pXv6p2/W36xV772Ecn8skMkAHdmIRGuz540AX/8NQn/Pp8+EV/AUS7c7T6OTdebGAjewBVG0CqQ6s/f6Oz5Vzd97///cKCSfykJz2pghr569atKx+g1WfVc5/73BnGYarSnnGEAVMG1CBTRL1okSjVjyyZpZzGiBjgHB8TRJ1Cl i10DDZAd7jDHQb3uMc9qr7vdA7Sjsell15a4DULb3WrW9XspjP 5rgRkoY09jsmx50g6cEZmvX4BVQas314Kb/4TffnJhk6fnGevXnHOV/RPNIrdaPo+og9a7QbaRl/68T/9cyXBy7n+dGe3frElvNXxDTp+yZUyfqC7utgBvOj0YWv84VgJX SaZCYtGPT30c84O5/QxZs7Dw16bQl72ken83ve+d01edfyQvnyU8SVnimM1mkkcEmYc RgjDbQRJGyjKKaKxSJxzNBiic6zeMQXiaHWhsScXrX0ulz/72c8qCog0LpfoGM8JwEAuXR/ykIcUiOliU/BiXHTCV39GK/RQRycFLQcHdNr0teHVH3xt6myxo5h0f9ThyV7+xA/fRKM+v/ThW/LtbfrrqwgK+kin8AIS/NCw37krCZ8Yp0Rf/fEMqNirXyYBnuxQ1OtHtna2mhz8xR59+S199IsP9CUbnbGJHc4 zHnR1zifaFXv2qLfhgVfO+3t2oaUfPdjkODQB8qqjjz56BnMCd fjxj3/stIxjIIMYyJDMOpcvl2+gC3j00Z+SMTQKMwKddo5RnIfOMcXiL PzlwXJceS/l6aD/l7/85TLapY4RHKDE2eFlT656ziALMPCJE0Krvzr80bHZ3hadc54Jg V5/hZ0255kk6tkTXvxLZ/pmw1vRD9iBwXH6AJS68MFb6pR7AVcfPH79618XTxMbKGwGWxsf 4JexxL8PhPidHvGBY33Iw0M9Pvb8oKjP+KrHk130RUNOfBY90P Tr8I8+6tmJV3xJDrn4xi+yAuehnQISsxpofvCDH5Qi97///cvZmEapAIRhHMi5mBBgcChDwRiVPSUIT8nMTF/15KBXRF68DIpNFCZLdMkEsndDSbY2/fWxOVfvOE7ElzxAZkecQl/O1dZ3GnoFXzzQZ/DUObapVxwnmjkGIDwTnfBwzjbtzm3RUdoU0GrXj43qTDh+UOio jxteubEJCcTAj7+xdGyQ9SVDH8exL3XoFf7AM7agU4wTOzLuAS xebNWGV4p2tHyqb/qlnd8iM/3IjDx20qPv3+AJnY1tCjv5Sd9Vu++++4wTs1dKwJkaCLOnGMZo KK4u0VA9ZYHcsT4U0McWITEiimvDx3lfYfWRi6+I5TJ6wQUXFP joZrXhbne72+Aud7nLXERjKIehpSO5jAQCBS+840TtNsWAkIlG u02JD1KXPtnTXT98lfAJWOxjJ8cDGz0NhMHnQ7wdk2Vzzo/0ZofNuLh77w+advX8Tm/H+LtS2RyTo92Epiu++NOhv8UeuuaYPY71UeimoFEXm+3xTN/YEd/EP3xBHzzTBz91dDGxbejV4UOOfniljq0KHvqhmxKVnEjkEXK2h hiAaRyW6IaBDUPAcRzj8VDs+/WOlRhBZt949ersyRSFDLLlPVcEgxJwhhd+jLQxWJR2LD/U3zEZopU++rONUwyugXeMji1xeJxmb8tA0i2F3erxw8tef7wcK 3wAoNrZFtA5jzw8+J5v1bsHoCsb9MfPuQ0v9WwyWfU1XkCrzaY P+XwXe8i1WcHRRndj6phN0Z+sFHzYHhq89COb7vGLdnXsy5iiV fDFX7tiTBT9FfVoMunwR2+c4FLBny7po56v4r8pjtExjjfbMUW gM6foQFhoMM5gUhadDS9OZZx2W9opgYc2TtcWAODnGC0aYMUrg yf60JFu9Ok7Sr1+nOOYHvoZQOmHPo7JRKdNwYeN5DpGp68S/rGRzvRKYYsNP8Vx9HL5pr82+ij6o8kx22z0Mnhoyadb9EKrno7 40d8VSaRyjNaEJYMNdI4MvBV91Stsy0SWLkpD9AVs/bSzN33xZLMNHuz52B4tmxT0dLYPQPEhW7069GSwI/wiT50NfaKwcysP7ANmfcnTx4aWL8iZMhMdYKwQiJhwDlYyyByK Vjv6/jE6jBV02uNQ55RC75hwijEaTfg4p6BZpr9BshmEtKF1LJp873v fm+tvIOhFDhmcLuWgE/214eXY5lgbOei1k4O/utSzh470Sj35/ARI4aE/utiMPqCikyDgnGwy9LfXFr7q+B0POrFJCR1Z7DJJ6KAfX+GJjz 09FO19ffR1jlf4mzTkoI19ztHioy7FeWTS07EJwI9ydDpFd3rp m8nFT9qcK3glKLqikEcvPFLwIIdNZGnHx4SPP+ynCHcQhxLESc 4px9gYh3mQH6baXPYoYVVC4XiOiKMoEXCgBz5GmCBkZADjuFxC 9EcXJ6PHB31mJhr6oqMz/ugNLOdYLckgz5dj8ir6J6rpq/CJgp/jOJnddFYf30QHvqMHWptin3p8HNOTz6QBIk2AKpXQjp89fcmhH z50y5jwg3qgAF7HCvqkUvrgwf+O3Xw7D9hc2X74wx8WPX4K+zK 2aMmMHuEXPfjVMR2iL1rHGSdt8Ql/G0N84Igchc76GAMlvjd2VqPwRI8nfvzEJjavuvOd7zzDoRpsAS 6ncCyHham6OFc9WucUssdUYZSChtLqHVME8BTKMEydggdDFPSM oyCDHeNJBproJILQmV6MxksfG9429fo7jsy040MWPgBFt76ucS S++msjT3FOlwwI3UIf+8nTrqBFQ6a+Bgt4DQb5/MSfQEUP+0Qpl3xFX/LRkiUa4ZGBZ6c2dNr5NGOrPzvIo582fnPZRktX/dE4p699vw4P5/E7Oejoyaf8Q3c82MrO+EIdmkwegAVK/lFPF3bEZ5kEZNKRnWShRYOv/apddtllhlNUEE5pipmtOjjGLCDFkDLooxzFHatH7zzGMBgf7Y7 tM/jprz0bHugih24xilOUgIjB+mWvnw1/WwZCf8f6pT46G2B9MtFElfgBb+dsQiOy5ZweeGagohdacjhaf3 t95Zxf/epXKyhEF8uWn/70pwsQ8nUpEdl8vdNOO9XVA421XwNowC+++OKKmq5iZCkZVMdk 4c9mm+IcX/qbGGzNGNIxY+uYf1LU64tWGx428tgNdMBLL7RkK3hohxsAFQij TxcwC1v6qIczAMVTP3zSX52NbBsedIkMx6se8YhHzAAABxlMAx thAJYBolwGBx2GhNljZEOTekpQPrNKX47jAAMcR+OhcJQ+6OiA JnvytMXI1JPZHyS6RndynYtS6hIJ7TkWf/YFuOTSRT15aY8e2tWTSRf608Oxkjo80Snkoxf1ANQlEYCsYbt0 s9kl8jvf+U6twdMVjYHFDw0ZlgwNMrCkjQw64Yu/wj8BDTvJV/Bim3PjwybjoL9jtIAUwGRc41t7dtj4C53XCfCjk3bH+pGFHzxZ o8bX5gaSDfqhz1iidx7sOE+J3vZ0ZRufkaO4Mk155qySo3bccc c65hwMdQgAdVJHMEe7jGBAWW0GDh8OItC5vU3RjxI2TuC4LAmp Q0cHxxyl4BWe2sjR5tg+tGmLfupt6UsXTmKLeiVOw9NGvkFgTw qaXNJd+tCwAz8yRREyHZPlGC/1+ilsUA8wCh+L4hdddFH5DzitbfMHv+uPnxeWHN/3vvctnYHeub70etCDHlQ0XnpBjz/93IcYN2OEHm0Gnu18r040jkzjaGIAGdCxUeEPG9vYox+/mzBeK8APgMkWjW3q2Z8bMjbR2QbU9nQgC286K3j3S8bOnh3GhR/53n0b/9BjyjorhpygBCAcn8HMoDOYgRTBLAOmP6P1pZB6fQIyfCnBkfg ylPKO8USrnzoKKvra9GNEDOBI9ejwcx7D8InBnMq5+JPDPvxt+ nOy4xRy9FeHXjuZZCTa0VEbGRlM5+rx1J8u6PmDDngAB/rLLrus0gSTX7owPT1dA21Q2aO/1IDM+NGNHroEjej7rW99q3TFn+6inNcAyLSZKOQam3vd616lH7 0BK1cncvGnK19lfNBEn/iZHLYCHl/ipbCX7XjY8Da+/KevfiIvutBHDh764tsv6hT9M2b24ccXwMtH9TIPYkab5RRgDGW iHBCYsYzleO/kEqKPSxiF0GYwCaKcAWGs+oCDLA4PYAy2gh5tZBpwNJREQ55zh vQBw1kKHelhM3AKXvqqi8PxUI+H49ipP2DRs+9Y7c5Da68vPRQ DZGMzO9lgghtA/mSH/iIlcDqX16LhR3zoo5+CB13IoAu75c/4q1fwRgec2owNOnLwpWMmDZve9a53De50pzvVq6exHY/4EQ29nNtiqxtbEV0f8viCDsadvnS3wQy6pCF0VY8XoDk2Bvb4x C7nCt3RpjjHgx4p9EOfgEWWujkAUwhwCdDZ5lgB0iz7qGeIy87 Xvva1elImrzGIBOuDF4UVszyKqicUqNDFaaGNo7Q5JkuJ4zIJ7 PUlLzITVcjiDPts+tvwjS76ZbAcczQAoMEfffqjAwgOtdHXFhr 9gInO6k2qDDTQpuAtCHiySF/5rrVqfkHfv6wbC74zYPrQiWz16MgUiYDJJZX++NLzgQ984ODcc 8+tR+4A7SbQWHU37BUN+U5/+uJHvjEhwzgqZLGfXvRmFz+h1Yft+rNVO3u045u+6jO51aeodx 7Q2jtXrwQXOQ8e2crP6tHQY0rnOEQlQzCjHIMoZdNRPUO8Eeay cNhhh5Xi2hjCeRTWz8D1ZzbFCLbhbcMvgIoRZKHRlhIg6+PYHo 2CTl+6q+NgW2560k4Ox4YmOqhjU+gBxoYHvtrl6voZzDiO8xL9 tcV39GMD20W9Sy65pGzkE20AJXrQR7648847lxx9coVzY6e/96Lvc5/71Ph86UtfqrHRj01kmgAi++zsbMmkk3ZypHqCDpA//OEPrwgJ6MaKDgDHbud0Z6+x709KqYRJRDc8AcjmnF9E8YCZLyI/+qHDL+BXr2Qc2ICG7ND2ceCYfnxhj54+GTvjMkUhFQpGHK0jYp uCRu7DQE6ggKjLAMpxFmcDrzwsaQVnck6cXsy6P5wXEJJlQ2OP t02JI/BAb6LF0do4mEzHHGCLo+nOFjpqt0UOHoks+Orn3FVFH/LsOY3DcjlmPzr1bMCbEw0cufopBs2E+O53v1ttfEYm4OrDVjQm iqU1gAVkdjvnb/ytTliJ4Fu2Rk8y2EJHwEHLXlHYpABc9zYmhGM0dDNO9GBT7Adw BUj0Dy1+xhY/9LGBXIUubECPzjG7+BNvdBkXfLXxk3p2ZkzYwA/64aWd/VIjdHiRT29LcIno9urK4xzAwOwx1YixQTMYBui8886rqDI9PV3 1ogKlDDBaSgIvWiXKMpDCmRA5piAasjkg5/pyUPaZZPgojMKDbvo6JxN/jki9fnQiAw0dOYkcGzq2atcfT3QcTr5Jyx4Tx12vfWy1146eXP R48xs/Ah6/ARDe5NEfHRrFa6z0pRdaQQEd+XTiE7wNJjq60hG9KAqQbCADnV QBjVRCfxMGL/SuiNroTYZjIEgAQEev1NOP79hkb9LSnRy8+d1k1E5PdQoeJo6i Tl862qPXjkcAa+9egV5o+Ii/4Epe/fWvf73O8TCJ0PCvY2XVAQccMEMZjsHMFgGEGSBKGshEI7SUllM 9+tGPrijkZz5+iBfQUED/KEOYfpzHaYyxx4d8MhVGo7NRVnuUprj+9FDMSEaSw0COI08RsQ yGOrw5HwAVclOH3uApAQN90NMBeNy4AgFe9KYTP4VOX3V090rq N7/5zTkn66doQ0N/Po0N+NAz0dlxQMGXBlBUDgjoSw+AMtjoDSZdFTbOdimFc+320V Mf/dXHr3yrjiz1kY1XxsSenuTihQbgRGd8tJNDF+1o+U/B0zm6+JQtsYdOs52+fOJ+gJ/ogj9b5O5SJWNvM3ZojBmZBWAVmAcwFCFA1Nm4cWPlcZwELGhEC wDFwKz/4he/WAMdAWgoDVj2DMaToyjASDLtFXScoC79AirtZLvUMQgtowEBPb 6cox5Y9AcOdcDGDg6xp6+Nnmg514YvncnxrrHclW5sswExJzu2 gsC5Ugc89RcJpQH0IYvf9KeHgaET2+nDF8752zk/AoZlscj3FI5d+goc7BUs8OCX2Egnl348bPqwhXxt9AEyvqJPcm Y+4B982O0cLZsCEH43JgGn/vRDz2bjIUhEJ3aTI5pKxdCjQ09/srRnPNTxj358h49JbFzohrd248q/xkx//BT86T2F2OYkswZz+ZtLnA4G1BZgADB6ytgwMxjhQSiFGBCgc5D 2FLIMBv4GivMZaTD1Vwy2PgAjCqJxjq+NscDlUs7ReKnDF3/9bRyqHyfQg85s1IdTHNMBT3YAwec+97mauG6SDIp+eKLx8AEYX MYNpHRhtgOMOoBBQwf+0od/5aR+xwcgX/nKV+qSzl7Fnn4AArAikb2BpQtf7rrrroPPfvazpQc7jIFCX/mzwee7j370ozUe5KOf7tI9evDBvvvuW75Nri8gBTD44NsHLf70 Ip+OfMBPbCKL7xTjxUb79AdM57CRzVixiX/Qp0idXE3Ro+FDBX9t0YEeGdfgbQoR5SjGaExEA6EbaA2SBXh30 57aGQjCOQWg9I+BhEaIvRKjHaszIOqAxmBSLoVyzvGmB/4UpR8ncErkAqFLtYInoBoMEUk/7SKK2Utf9pHPRrRk0yERA2/OcuMkHeIDdRkIckwQg44nAEV/k1Q9ELkv8KkCk+7zn/982UN3gwIgwIOOrSIlntrpi5/AEVv4ybF+JhJ98c1YaUMjWpEP+GTSGS0Zcl82CkYmBV768xm57 LDxEXr6KICo6GMsyDE2aLRlLO0Bkg/QKfQyZsaBHgE6G/HQRk5kka0eL232xhk92/jF4oAJTha+dCjfGXQniM0OCos+GJnZOu3YPdURaXTIDQNHKJhF uL0NHeDFkfjjx2GMBKJcgp0zmBExgJM4GW/6ocFLf7zx0sapNm02UQE9hzGcLfrgF93Q688eA2tiojEx2Xbmm WeWPHIyUPYKm0QKAObIRGD82GOfCSdK8yPe9NGuTWAAHrrRid7 sBkxAwtugo6UDO/mGbuygP935RD91rk5sSb3+0X+2uzKgtZmUUiS6mOh85arB/3RkZ2yNz+Jv5yYJPgG1cWQDG9nBJzbgU0d3uLK3ocEvgNZXvb2 ijX0mA5vpoo1ssmCC7uqdo51yk5B8g2M5gUHT3aXHpVFndQQBr QHkOOcZHAo5N4DoKYLWgKijOGdRBi3BHIFOP4qp08e5Nrw5Q+R CZwbKP+kKOPhwpGgZGc4dK3hwJEegJVtdf6JwLt04Q94JCGg4i I1xoL508R0KaQCwidb8RGfr4qtXrx4cd9xx9bQLOMhR7EUQgAy f2Oc8daIyGWyLD/mCv+kpcusnoBhgvg3IBR52689v9A6I9OU/9PqiM55AniBBjj78pNBJIS9A0d85PdhkPMljP54BmGP80Nuzxd jys37q+Q0vejmmh3Z00UU/vOiFhiztdGObYoym5ExmJYUCZMoAtkF66EMfWoPrco3G5ZFTDD ahBBCmL4EBhDrKcqj6XG4pDZTq8ekDOkZQFI1odL/73a9ovEao73Q3sfBFyxg0+GdwyFHopdAjEwQdJ+LPgZwiUrqUW 0H5whe+MDd41bn7E/B7n2DPPfeswSeDo014aRYA08ck41ygc8kGNHQK2XQCfrLxtadP dLLnF3YZNNEG36QFVjjwMz5ZwnOON34mMPnkuBrhxX782GxzTi 46QAZ+kZVvtemLHk+88cUn+rLFcdIgMvWhLx5ojU8mBznqbOTS XX+y+CK608E4KOjYrk5KhwfdjZdi0sSuKd9F43gARQQQFs4xYQ hgfPvb3y6wAZWo7HLLmS6RjKQIpgzhFIbgRVl8bGgobpAYrQ5d HEaW2c0gylEewA2EenIBQ5s6euLPMQaTwewQ/fA28KKZSKNwsEKmY7wDYOdAiBc7DA59TUrpE5Cyt2Z8R6PNJgK SxV8uz94c0xc/9fZ01c8gkB0/8QWbyXQZZ3cAZs9P9D/nnHMGn/zkJwePfOQjy04rIcbDuLix40tgoY8+ZLgRIpftAg6Z5Bsr/gGUBCjnJiK/Rjd+ok+ummTQF2+TEj3e7MdTManV6WM8clUgF1+2amcTm7Xra/zJNhb0tkevONc/NNlr09cYT1EKc8VAiHgc705ZFNEJYRTEkAIYMET7PvvsU07FB4 ApoT6XBv3RMjhOzmXMQBswk0Mfyp999tnFx0wGNM7k6Nkun+ME fFd3l2x5H1nRH8jwRc94zgQoBQ3ZZOlvQMimE3vcAFnTVtDga7 DCn5PxUOfKxB/0NbhebVTYyHf64JnBRhe/qVPogoYsG3+i4Su6KWxG43VLvnCDJxdG56bOWNFDoQe53WcSKh jhzz/85wqbR/t0NGFyFeMrk89EpQc7oxNd6OXqhE7QMHH4Fg1/qFfsM1YmDz/wM9vZEd6OyTCp6cz/+KClP5n4013KCA/GnB+0RQb9+akWYjE3a7wdRTgHiTqioEIQBwC7GzvKmvEGw3bhh RfOAY7BASnBBEVhSqijsD0jM7AMFUXJT0qjnyhrLwKTb+DId6w vgBrEDDoe6MngCPqgtaELLUdoI5fj6MKZjrWpx8OAmQj6uwJIO UwSDieHrfiI1hxOJ3zI4Xx8+Bdw8OMvvBT9+UTRxjZ92GBvAzY TzeoG8LJXH2DO5ThXBkHAwOtjQgpAltKMK158RC/+c+W1t812gcFavhSJbPz5gM6ufuSQwU720TvnfKOoYyt/GFubc7zoT74++qtPH3bzvTa6kAmo6vV1TIY2fdUZI3rV2L7kJS +ZMbMIQUQQQBKCkMMxd4xRAIiesZbWHONBmAEHeDdXPkii4IUH IwnmHHuTAi3FKIO3y6NUIIAyAYADcNDZtHEqucDgnAygAha6qq dPnO9cPTpytNGDzerwsqmnE0cGvJxp4AEYSJT0s8cHf3l6AE4n bS6VfMp2UU49oLJX4V+DTjf0aO1d5l1uXRVPOOGEehpHTxHMRL EddNBBNdAmvbGY7u4PgJwOfEF/e+mhgMM2IHbsamWv8K8AlvHVh038QX+FbOChN3+wh0/wpK82dc7RqEOHB77G37l9/M5ufI2ZcQovNAG8vtFLvRI+5K16//vfP6OzwmlmuNmrIBBtOBmNdufekDIQ6kU5gnNZcawwzoBxDrAC RZyCr2NRhHKMBEyAZpBn+XQgiz6cziH6aedgJSBxTi4ecRxA0U EbMOqnP1nAEh6czZGKQdBHXw60N8h0YUt8weEKnuQCkKjr923u D0w6xV4UtGcnYEk/+NFgkEe2dnITBEyS888/v1IHNC984QvLVyY2nfSxIoKfwdRfX238TWfH/GPc0IjKZOCn3uQwfvzFH2yjE//El3Q2CfgCPXvRaO/rT5Y2fhYc+FY73vyLJ9/Tw5b+2vWxNzFhAr06dtATb9jBD2+8+D+61OuUj3rUo+aig7s+D rGsRChiTMxQr+VxBIMCWE4gjFMpQhhlOErEoqzLP8UNMkc5Rie HMyicpA8A4w0wuZThQwbjFIAICCMzzsKX0xUDaqO3CWQScCx7D CR+jvU1yGy0mQTaycePLHLQGWh91NvwZA8b6cj5ZNi0oWePeu0 irwkJeFZxDIiBiF/ojR+/P+ABDyhb6Q6Qhx56aAGaLLrlnsEg648P/ck0SYwf+7XTgU3sdMynZDvmdxOQXerpZ2wCRna4CsAE2Qpb+IO eNnwVMvSnM1208Z+Cns/1JVdxjr8xo098Ckdk6aMNL8UxGexFy+YCsAESVQlniL1oAlycT fkoDYwuK86j4GyXQzkHWA4DAoMGbJzpBevcfTIogwuwJgzFKMR x+pokBs25tsxoRunDCPQmDqczhMPVGRA86MNBbCETD/SOXX7RmygBLZ3ozn7HZODNDnwDAsfsts8go+FsNAaPHHz4lR6x WX6qzk0ZENLJYAGdc232bABY/pObvvnNb677AkAi0+bGi46W92ogO13pzV52sR2dOgPOTvS2gIv O9ORrADKO7nvQmGD0gwv3Q2gFGnv60lt7bM+58TIh+If/2K7QS1/17KSz/nyJhwJn9MEDxsjhA+OecbHHBw8ypzBMARyMbau7u3wEjhUdHXM iBxNAuAGyUdbgGSSgByL5rFzYub4iAmUt4QCRPpzNSY5FdU7nQ EqaEIpcmoPNdPQcyTHo6Bj5aEwYehhAgMxg6Gu1AF9FPdvZxRn 0Ev2A0IDjq00hC612dXRNX3z4IZOWzYl86IBDygA0dAISkxkve vKlAaO3AaNLbp71AQYTgr/lt3SjI2ACO/7o1IvK9oKMH43yEzl40jvApTv7ApwAUpqkHmjcBx177LEVTOgd X+NlLGM/ENIHjeBCDl8HZI7pyEZ+NEb2+ijhwx5+xI8OaOCBj5yzK3YANH lkTEUZe1sKY23zCxoDwHkplFAI4QTCCcm/L9BGOYNlbxIwNNGE8oyUUuDBWZTjSBPCe8gGlXEGkyH4AIg6hj LSuXZOAii6mvkmpj42s9xePfnksDNOw1c7/fTnaPapR6sOrU0/tADgfRHy1dHfpNIHqICPT/A0kEBupYWtAGrgFXrSCw9ywod8QCRTH+3RG7+MB9uB/FOf+lRF0NiNlz70sdGD3+gUuwDCONCHflIvber5jA4ZG6A0EV0 92Q8L2skx7raMDT21kUU/QcX4qMffJEKLDx3RsVMfGx/gH+CjVc+GGoOZrhC8tUVnxR4DSjiO0+Msg0p4Bo5AYGCAwXVss AywPQCrx0dBL3qfddZZ5VTvLDAkUZVTOZxsRjkmm2PIdIwfZ9L RXbfISI6CRl8bWdEXH87UH1/y6ISXY4UMjtfPhodIgc4DB68+5gpl4uHjipMBo5P0KHf+wJSBp CPZ+OrHx8mXyQZ2+vEfGr4DLDq4KQYsfdCEzjjQLSBlqzZ00cW EZwOZjq0u0cMxGhOIjjarLVIYBT2+aMigBxqFverQsJHuuRrRn R/p4Jjf7fVV71g/djo3sYAYT7zs2XDFImSJ27o/GOtsY6Cy0D51nLVQSbs2RiqMx1eh5Omnn17rmGbu9PR0pSKAxH kijToTwM2RYqA4014fTjUAIpRzDqG/DV0cFZvINzEy2Oht6vHiMPxSz+lkubIo0hvpkpUI0Z2O8kf3AJ ay0AEbefg4B2IDAzwimjZ2kWXjB5PAlUgffnPFMUFszoGYTrlM m+jkmHDxP6DQFyDYRz+y+CWXfL7FhzxA4iO2i+T2+tGH39CxHQ 90Nm1k0AmtNnRka1ennTzjrL86wQRP/dCTpQ8aNvG9Ovz4SsGPP1bNdKVqrsEfgjCz5fgadF+QlIJKeHp rSx7GCFEJOERRhvmFgohsMOSOjFEfpxo8x5m1oof0BJANKFkGM JMFLV4AkwFmFzrn4a1OP/QczrEGWs7paRX9REEgRqcNiOTyBgo9+/Czp5+8HHAMFBr9DLJ2BQ8AtVdvE72BhW65v8BbmzrAIEPBM4V9 9GGHCaHwiZt1YNCPbSZxbKSXyUVHVy8+I1s9nchVl40MPtZfcU 4XvlTnmE505cPoRwfANqFSR8+AXT98A3T96bEoAJdmm/8Qsq0l4M3ezYd3AKQQnMYgxtszgvOA1sACp/pcenOpM8guWSK0vNymTxwFbCINB+GtP954meUcH9CoEy1t0QPA 1Iuy9LVqAwAewQdMaDja4Iu0BkfUzKXQYGjHB5DIFI2AGI8Ald 54AImBtNeXfuQ7Z7eJi4eCj3q86cy21Jtkoj3Z/MOfdBJpQwvoeJEj/XHs3gVPvGNXgod6dfrb+CJ2kmuCqKczG+BGXz5hm7EqQHb6qlP I1g9fbfroiweakleUI/7TnwQUNOPlSpxgIBmeGeyc4S7L2oGYoxhlsPRHw6EcIzqKSpzB aMd4TXeXaQDTbuDxNDBk62t5Ch3H4QcAiYqARS69Xc45H63VEj rYr+5WcYDDBMFbVCMT4PSPza4mJil5Ug+RET+gog86vNmnOKeL c7bgm4nCRhv6RGK+C4gNuMnm5lg/vqIb+WxEl4ChP/l4KezFC12fli5ojAV/2+MLeNHTZMCXniYnHfGyR2/ymTx8hYaOiv50Co06NPrhT+41zoExGUahjMEBHumDzaUXoBjA+ YzjfM61UM8Q9PoySDrBQA4zwNq9scVBjm0iiXYR1+DhlUFQz8H AA2Rk0slmUKIjGnX0Ugw0sNKVjvgCNh1NDrqYCAbYyzYimRRot rvhQmtT9KFXclB9gJnsyLdnM13JYhP5dKYve9QrbKUnvWOXt9n oqo93JMgGJgAC6gCXH/XlV/KASl3W0E004OJbcunjHD2d2Cqw0IUsVzxttgCTjuxxVeJLAcbk kFrxnfGXIuFBHhrj70qoD5u3OYWgxFIWzuRsa8VmPccAAeeaxW 5Q3BjFMQGAmySXYQNhgAy+AZzuop6B4EQOBhBOwYujgI7TtHMu sOmncC599FPwUTIRpAX6kOXxt37O6UqvRDo8DFpAByQGC41BJh sP8lx5DBBa/NhjMtGBfBvAaMOHb+wDXnIU9OrZBnxSBje7wMivJ5100qD7Mmn ZEl/pR3806vC0d05PsgGJj5wHuMYCYDOZyNZHu7ZMdHVsZq9jm8Jud MbdZHO/YjORyWQ/GnKB1riZTOjHJgJTNIa4lEoROMtAMoqB2tEZFHsGcZpjg+Xxq3 4cpM6NFYM5EA+ONSBAIpIASpxmAGzo8CTPcZytDegBz+ABigcw dBJNyaWPKGpg4nT88QsoyU7agQ996GhA0LHDJNOfPJOVXfTNAM YPdMzkcKzYA44NYMmTttBbVOPTU089tXiKYurp4FhwMPnYTBdg NgnZgE66FdCRSw8+NZmMCRsB1DF76C/ysok97CRLXyV+MVb4kOtmHb/Z7uqElj3sZof+7NIPf/VjA2AGAYzNZclrmxl84GEMx1CaEznFntHqDzzwwMGa7p9AGwQG cqToavBEKTTo9TdYnA3YHGTPaZyj3d45+ZyNhjw/J3JuXZYD8XCZ8y6JPuQpBlZ0Dg+DQQ96OTYY9DbA+omy+Ji4QO Pm1dUE2ADIub5si83Az1cG3ySnFxr62+hGn+iCD50BxQMmN7WO 4yc+cqwvvvqTwQavXtJT5NNOFp8BFBmO6WDc9FXHPn3pKw3iSz zJZIc2uhkX46tOUGC/V0Adu1Lwg3by8VbY6bjy8qoZkz8Gg8EAY1ApLvKoy+AwWrvBBx KGy+VEF3Q2xhogv5Dw382B3wByanLfAIhjRQerE+gMgihkkGzy ak41CJb1OM5m8ADLoHutkT5000Y/egEFmzylo4cBZJOCt0ES2eiqnHzyycXD22fAwxbpjgcH9AQM/BX+AAbnQEWOQge2aacj3+SFdgAmk276sZWugKlPPyhIO9jOX1Y tyAY2wONf/NnAV+js8aYzYPEZHnTURzpAFp+QTU/+IFfpR362KniQQ1+05OKhqNd3h47ZFR6p6tH+CQApyfl+C2Y2c h5wcbABdxPk0iRKAw7H9WeoAcWDA/1UyKPRfN2GA90gMluE49w8eCDfoHCumQ9YZAEvZ2mjF/42dOqAGDC9pIMWb7zoRT/ygNjbfF4aN6j01Q54gIE/gIlmBs7kQOeJGF7SAe3s4gubvgGx+kQ1euENFPR1TEeTAqD1wd O9Alp+IJMt7HW1cJUQVfVzf5EJgif7yDMe+iRSZgJEP/3R8zl6xTGZ5NPDlqCxYcOG8oXUDx1+eKHNJDDZ8Jq7GowWsv8v Pc4FCDcZIrEbEE7LjFSv3czslzg5A6vdxzw8LPBUDygAR332aE 0KzuZYA25A1GkTDQDHQAICOucBML30SYoSIOlPhoKH/vqIHPI8dMDOJsU53gCMRkoh1XEFmu3SDntLbegAEXBs5NvzB3l k2JsQuRSzn0x6A4vB1wdfMkVZk4/9fvnhN3jSDFcmdhkT/LU7JpOe/EOOq5dgYbKmsIHN7AC+AFF/Eyd+x8sYs8sxOvqjoxf9RHhgNrFS+I1fxyoCM4BhHGWQOIQjYj wjOXJrilmLl2Jv+cilWLRxE8VBQEYm55Nj8EPPiQYbaMnHw7GB RwcM+tJHHd3QGyx9OR5QyCLX22HsedjDHlZ32AYFT7zwNwliKx 0CZjxEQ3Quo+giS5SikxKQAB2ZeK9du7ZsJB+dqwq/ApwbMgABbn4gG/+3vOUtpefhhx8+NymBBYD0pSvQ8q+ND9iLf8aPbBt5/Ez30BnbRGF2aNPXGPClOsBEI3orAo5zvPTPZKLzWAG4tF2CP5y lcKISR3MSAGg30PJiUUIdGg7hIE4FCI5S79wAciCwKhkINIDLw Qpg4w2AjkVRKYyHG/oCjYhjdcHAA7I9XSLXINKdPICxSaPoSh886SySiXDagUUbMIjs bCFD2nJSt2TmXKqElv104A85NoCItPR2jH8iNd0Al73408seD/oCM4DnCkQ+Wu0mBv/wBT7sQYufwk4FPb34WK7MR+TTxeaKqC+7TGjn/G3CbZcALq/M+8PpSkDN8QrHcYx9LoscY3ABDpA5FnjUacMLbQCnzcAZMI5F7 5Jt4AzYhz/84Xo0rh+5IgveeMhJ5Z3qRFppDh6iNb7kG2C8HAMZHdwUkuOnR ZlsBh5Q8MEPYKVfIrLITx65fJBfGgM+2wED6AAdsOzxQm9Thw4 ggUl7rkIAyS580epHJ/5BS0+y6eecDQCPH3oTkR/4TDt+eOOjj4K/ccrVSDu6sVpGK02H9McAGCCFowEOoBxzHkcq6hIZ0GsP8DiXI0 VDg6Cd84ENwFJEMPmnD6Vs6G5M0KAFRANnkf60006r6Bkefnlh QJ/3vOeVbt1vFUsO+cAA1PrTDTjp7FIrQlllMFGACw8RyrEI7MM09 FYAijz2WAo0QeiOjv58APCAoQ1I8HMOsKKjyIgHcAEcXmjoqZ5 fMvHoQF98TLqkP3ThR33J119+yx6668+H5OIJ/HxAJjv5X19lYiIwYxkdIHO4wkHzS9rS3j9PhFKHn72tz+cDH/hAfSXSYAKQG0k3RkBtME2eV7/61fVAwaNlg4WvAUMjRxU9pRf0BXog1U+x37RpU10RrEF7oALUQ GGAXQny8lDf3kwAdX2dc8wGbQqQiNxAA2R4KoAIcHQQWW0miMk BgLZcEUw6upsU7j0AU38bUNJRf7bb+BO9Y/zIZZO9IMBGBV3Sk4mJwAYngOMgA8M5nG8A+wNdXtr8R1u/iFIBq7b+hk6b5T/R5uCDDx48/vGPr0GxTg2oLoHyT99RsxTo5Xc3mPRxLqoBsWUzdUBnk0cDFHq DLp3JwNPJgBt8UU9ebNCVAJJesTU2ZY8udjhWkn865jf88cqNm fr4wR5otemXNjyB2BVnx25JEg+6iuLa9AN4k84xu6QJxsVkxos dbLIp6WevTAyAGcx5Si6pnN4vcUq/bv4xMKELMLRnIEPrcixK4Y9OtHBp3G+//eZ+D+hyPNstYwGrNoMqqrmZA04PYQASkA0mfviKvHSQG/qS0IMf/OBqAzIDbhKgm2+L8/l10ffq9mygGztja3hlj8dVHQNy+tI1Y6AeOLWRwxcKGnXo+hMo/Yqo+zMxAI7B9n3w9eu35rjvwAwYB6dwuss/oLl0iigGRbR0oyR39d6EqCvvCzhFZeA75JBDam+ZSwohcgOxBy FuvEQ5tHgAMCCLWAqQmaTRKzotds+WPi/H88+3hrc+4TWfh/7GQ3u20ESW9vnBJnInEsAxfin2GRi8RMz8Lk3EtP4KeIoBEHVF SdHWasPHPvaxQfc/SiqKuqnzbWI3VOvWrZu73MqjRWSX2je84Q11k+RSbCIAL75SjQ x2CVuiP0vFMxM8wIx6/fP5suafp8/8fQPwfI8s4twlXZRwZ3/KKacMPvGJT9RlXtR1OXeZzB5w3Xi9+MUvHrzyla+sX3BIIzyuB XigdMPjg4kGXi4tBTE51nQvK5Fhc0OTQTaJosO2XF0WYfrVdpk fVa+2wzUkaAC+hg5biNwgAdj69evrUaw1V7npiSeeWBFSlARM9 aKnNVw/QXr6059e7zpII4AUyEVnLw3l/2i4iXG37g5em23vvfceTE9Pz+WJQDtuwI2fTLJ+2pX6pdo3AG+ jJw2Q6Ad0PhYOhEceeWT98sJLPNIES2BeKvLrEK9kym2lAHJZe bBo6l0EqwyisDTDHbmbG8Dcf//9qy8+uRs3aXJp3kYTVnT3BuBtGD4gElEVS2fAbH1T3guYfqUhp xVx3ch5XRJYjzrqqKLTV2S2xqkv4IvKHjufccYZtbpgWU3ubBk KqFOGHdkiZ9z3E/UgYykHI+C1QmDFIV+rly5YDZD/Wt8EOuAFVg8x1GsHcBHVu8TeR7C6oIjmaKQQG7qneG4KRVorDv mcapYDl9KelcqrAXgRIwdkAGxlQLT0+z03aoAZ0EoTPFAQgT28 kPMCsvTAEpmUA/gB1w2bKOx1Se//BsSWxzzBc2PofYlXvepVi9B2++7SUohFjK+8VFQMkAHUeq/oa+0XEC2PeWqGFrhFW4AFcJd/7R5WeNHHexD6eQf3mGOOqRs6E8RDDTdt0gjvA1uaI7efSixC/e2qSwPwIoYTAAFTviuiuuQDsTfD5L/AaGkMgEVhl3y0gB1aH+D7+Mc/XjdzgGkVw4OKl7/85fWuAH7yZTd+ViDyWNlNYiv/88DY/az+f6qN9xEQAyZgyW2t3dpEVpFWBPUQwvu4WUZSp59UQorhlyW Amhdd8LJyAdBu2qxSALF3CR772MdWmmHi4NHKFR5oOfA2IkFEB brjjz++Hum6vAOqt7n8mtcDiuluzfbZz352gRH4AFo/kVXaIVUQseXUViw8vDjiiCNqaU2ObC3YZsJIW4DY1kr3XstMV5 ojFueBRFQPIURUkRdwPfpVRFo3YlIDy2XogRWIrecCMlBKQ/xA1Q2faA703ptwDvxArE/kJaIvTuvtq1eLwIscT2DqR0NA9QK7f84in9UmogKkJ2mA6lhOL B+2dGZpTD/1IrEoO9u9oSYKW33A4ylPeUo9Qk7aQK7SIvAVA9du4q7ww6L+9 vNRALWKYBnMioSX0r3/K+J6Gicqo1GXXNevLkRTKxSWyXyBR97rxs2NoKd36IE3AM5+UQ pvh51aBF6iQRUZLXFlL8cVWd2gyW+tEYuqAAmsls48PjYJvKyu 3a8zRGJ5tAcfwO3mzaRoEXfhgWoAXtgv21Tr0i9SArR1Xw8ufG 8BuK0JW1UQmbV74uYhB8ADsb6isGO/6BCVpRwt7114SBqAF/bLomoBEnAtgwGg85QAEEAdA7Moa5PzArmbQeCVM8uV0eElKrfU IZ688r4B+Mr+2OazRN8+4ABZCgC0/fqcZ68NrQ0fOXOAv82KbacM2mLiVg4skF1dEU0VQEQvTXDzBpD Os++DGH1uBgNkoBXBA3o0rSzsgQbgeX4BIlvK/PPUL7S3ugB8oqcbODdnVhMUYNTWB2+O+zLUpb5/vJC8VjehP+rc0sAHSIDjeH7EVA+IWyr6uBnz3QOPiEVfoJYKaF P64NwSn1a/9R5o68Bb8BWgJf+cD+R06YPSsadnHma48fJQQhrgOKBNv7ZfOg 80AG/2JQDaAraA0zKY36yJqtq8ZGOfSBw6NH7M6dfFHiv76qNUwiPiV obngQbgzb4NcO2lAfJX7zC4MbOs5b+Dymf9K9n8cxSpQYo3zzZ u3FiPkf2Kwgs5lr98WkoED+BD3/ZL44EtJ3RLw39FcQFeERUwgfBtb3tbvcLoEbF3ef2qGIhf9rKX FUD7qYVIDezqANebZs7xzORYUc5YIcr+L4SsEIWHrSawufSLnP kSPFADr73Hweedd15FaF/HUfSRQnhq5uf0ou9s91KOc2+S6ddAPJyRawDu+TURFeA8FXPZ9 7ZYbuYA248xPS0TZdEDJnp0+rhpE329yO5DJADcyvA80ADc8y2 AJlomYgKvOm0AKxIDZt7v1d2ar03kRef9XsD1awolPOuk/VlSD7QcuOfOrNmqSnRNhFWn3Q8sgRNQlfyWzVM3b5GhzwvqgKt kXyftz5J6YOIBHHDZW0nwAAI4AVFa4OZMuiCdUAfYNsVqBeD6J oSXcfzg0q8wrFpYStOuj62V4Xhg4lMIYJQmuPz7OiTQWXXwM3Y vpftAtZ+2AzUQB8j2PgXl/89ZIwZYYJZaWAPOY2XDhraV4Xhg4j0LsFYQfMrJ/xB27vdqvtlg7ff1r3997UVnbYqI6ljktVbsiZulNzmvD+9lfbg Bdzig7XOd+B91AploKYIqPn063f2QEhi9kwvEflHh+2RWH4BT3 ruh++yTpbJ8bA/A/c7Nryzatxv6EBvu8cSnENwr/wXQ5zznOXMpgpTBTZl1XXmtf6TilxGKdx7cqPkSOwD77ZqP++k TmiJsf4bugYkHcG6y5l/u5cU++e8zqGhys2dE3Nh95CMfqRs3P8AEYmCWK+eXGPP5DX0kJ 1RAA3AHzoUK0EoXAtzc7ImyHlb4doOfAvkmsB9dzszMVFS2cqG 0SLyQV5e+buIBvJBLgRZgRVGb8+wB2zKZtWBR2sdH8j/d1IvAaFpZHg+038Qt4GeADWhFXAUos6nzsro1YzdywGzVQgoRm gXYtqoheKABeAGnAq80wdtkvq7jp/BSAzd1edqGBlitBUs10GT5DMsG5AUcO4SqBuDOqQFj/Au8PjxiCc2HSbykk//qLreVTgCypTdphCd1AW94AXArw/dAA3Dn4zwa5m5fzvEREt/v9WQNYC2xJfLmHxV6kGH5zE+H8i8CvCcBuECsAHorw/VAA3DnXwAGSODz0ekTTjihUgOPl4EQSOW3gOyGzY2alEIE9hYa munu4YdXKP2rADmyyNwAPFzw4t5WITonAFp+RWGN1/d+RVF5rXcbbJ7Micbe9fXug8fPHmhYeQB+7034iJ/vnu25555z704MfwgnW0IDcG/8RVbv+9qkB/5NlrQgN2k7dj/olA/75TGg28uR/X9jfa0NS0FE4hZ9e44d4uHEvwsR3yZvlS6IqqKtvBd4PZHzQb5 99923nsz5vZx6v84Qff1OzoqF5TSR3JJaUoh2MxcPD2ffIvBmv 8qDgdjmv2l6OUcUBsyAG2AB18s6gGrvxR5fZZdaAL3oiwaAG3i HA9o+1wbgzd4AODdmwOcmLG+UAad66YF0Qj5sbVikFplnN7+Rl hff5cBZseg7uh0PxwMNwD2/iqqiLRB7+8x/hReFgdMqA+D6+rrXL0VXKxDeVPM42VfWfYzasbYWfXuOHeJhW0 brnJsUwd5NmcfEUocsrfnIiZUJwBaNFQD17m9+sdFfSw6AG4jL VUP9M7EABlYAAzybG7P169fX8pg1X8tmac+POaUWUgrAzQs9Xq WUfmjDs+W+Q8Xr/zGfyBQC0ERXEdWxiPu6172uou4TnvCEWucFTEC1bGZ14X3ve18 9zNBPqjHdpRQeOQM5HjZLZy3q/h/Ghloxkc86gUxUVaws+B8Vis9HeVHd/63wFM7ymPVdqwtyYnX+sfeHPvShwXvf+956kKGfCC7ytrVf3lj eMrEpBNABnH915QmaaGqVQergps2TNlH4Wc96Vv3y2FM5n4ryE vsll1xS4PVo+bDDDqt3IVr0XV7gRtrEpBAA6zKvBGxWFURbgPV PB/3CeEP3Y00R2qqC1MFP7eW70gxrvV7c8WNPUdsmzbDy0KJvILW8 +4kBMFACsT0gA6O1XcVNmzfPvNurXjogtfCvY/1cSD/rvfoCs833IKQUburcwCUlWd7ha9ImBsAZ6txsAax3fqUKlswsn 0khdtlllwKlF3Y8tADevFrpTTPvOvglBvBKO5zLkVsZjQcmCsA iqEu91MFHSS644II6t7Kg+Km8J3DeMhN5pQsiMrDKd32tR8SVG 3sS94IXvKC+wjOaoWtSeWBiViECXhFYeuDfAYicgOiDJR7/qpfrPvGJTyxgO99pp50KsJzlBk9E9pX2pz71qYPddttNdSsj9M BERWC5qvzW2q6813quaLz//vtXxPVo+J3vfOfg7LPPnlvPdVM33a35vuhFLxq86U1vqlRj9er VlV7kZnCE4zfxorcrAGeVQbRNkaOKmsBmKQyApQOir3TAi+geF bspO/zwwwevfe1rByeffHLdwCU/lmLkJXeRGujxaGX0HliR68CAGpB6ndHDBrmqAqzSAMC1ROZmzS 8k/BTIQ4jzzz+/IqqP8L31rW8tYFoyk0Z4Yd2/FcArqw6itZs9L6/Lj/fZZ5/B2rVrK50gz4RoZXQeWJEA7r934MbKzZi1WfkqkFlVEHFFSwADd ptlM0tj6IHVslmetlkDBl4vrnthx4qEYuVBqkEOIPvfGf43RiY Rvjke3TBOruQVmUIAp0irWNLyMMFTMmAFpgAqUTq06Ka7fNYL6 9IHH+QTeaUKbuZEauD1qFix2iACe+/Xa5NecsdboYMSWXXS/iy7B1YkgAETgOxFXClDXswJgOWtubwH2PqIpjaAtUwmnxWFRWO PiY866qj6HoQojk60N0lEb1FbupGoa7QySZZ95JrA8sCKBHBAy gL5r7TA2q2HEXJiUdQNmxsta7vogdc+6UdeSrc05jds+Eg5vBf hx5x77bVXRVzRGUj18zP6/hO3Bt7Rz6IVmQNLCUTITZs21fsIIiegejLm/QVgBWBRdvXmJS99gNt7C9ICYE4k1ZZoDagzMzODgw8+uEYn68A BsT3aBt7Rg5cGKwbAQBbQAZk3wt7xjndUCiB9AE7AlVLIVwE4D ypEUfmsOu8xSAXytXVO0F9fMgBTBPdyu8ngn7fIgeXNJgQdpBb oWxm9B1ZMCgG0Ip+9zX/MlLfKdQEW2KQBQOYckAFNH2BDF9ABoTfQPCJ2jJ/VBumEY8WasHLiiSfWK5fqLZ8Be4u+5Zqx+LNiInCiL6+56Xr3u 99dN1uenslLgVeRxzpHD2yip0gsbbBEBujALeWQM0tDTARR2Ys 86PRPNPY42Q85rVq44bOMJnon5Sih7c/IPLBiIrCoF1B5cubLkR5WAKrcV0RNu7Ry5asAAA+pSURBVD3Qi sTWb7UDsvRBnbfM9BOVFZHYyz1yaT+L949eMhGsL1sTBmBR/41vfGP9/GhkI9YEX8kDKwbAtAZim1cd/QgTSJM2ALDLPPAqQAuYnqoBrShrhWHjxo0VYaUMXsbRLlLrix6 IPbF7/vOfX1EaL6kHHh5gkO3xs5vBVkbvgRWVQgAnMF100UWDl770pQV e51ICwLIyERCjTdohbRBRAd7DCH20ofUlHS/2uHEDYP1EdstoBx10UN34hdZwAbsbvMc97nGVY49+CCdbgxUTg UVewAMwDyCybKYecKUDgGazXgvUNvXyWhFZPiuPzQ2ftEDE9YN N/axU4Ce6nnvuuZVq+K+b+iuZFKK3VQ83ia2M1gMr6uN+wCVqAqy UwJdz1HkSJ4JagQAqAHQMwMAqsspl3ZzJhRVpgL4mBWB7EIIei NXh5yYPHR4mjBs3QBeFyRHRWxmtB8Y6AgNLQAtUr3jFKwqs3t/1VphXIAFNGxBbLfD0zbFoqVilwEMkFrkBD7iBMTd46oDbhMDTz Z6VBm+yuWEEaiC2lzPb0Lcyeg+MdQQGYNFW8UDBI2Prs/JTl3HAlfsCrE//i7KiY9Z+gduxG7wsjeGnHzp70VlUTzuwSzfQyZuBW7pAF6CWf4 v+5GlvZbQeGOubOKABJpHVCgLQ+kYvkAEPYHnF0bcdPG2TqwK6 CGupDDDlvFYqgNUNHGACpYiKjzx4tvvFsXb1SlIDDzbIBG66iO 4mg7fW6GFytDJaD4x1CsE1wCcNEH1FVGACMOBzSbe05ZJvjfaD H/xggVeElEIAMFDaAxt6oAd2y3ByXvkyACcySzXwBmjyAFcfDzmO OOKI4k+vpCiOWxmdB8YawMBjEwmtw8pHARrIABKIgNDDBzdZls NEWTdfF154YYFXWuG/zftsFHrnQO31SOmHqA3gNsD2vgTeAAy4aOW8Hm6QRR8At29l9B 4YawADkQK8fi1h/dVL6F5eByKAFJEdSxkOPfTQAp+0Adg8tBBdgV4qAogiOaDmyV1 +kaFOFDYRRPg85XNsggTYGbKWPsQTo92PdQ7MNUAq2gGg6Hr00 UcPnva0pw0e85jHFNCAE4BT0NsA0BKYmzQ/F/JLYxEVH6kEwKJLtCXDRJE2iOAmDzqrHWvWrKn3KIC4lfHywEhW IQAnl+FEUnWJuH0XubSn3s2Z93PluoDppkrakJLLOno3eW7AvM ew++67F1CtPCSnBmY0IjUZjgNg0RmtByKe1OkPzAF85LX96D2w rAAGAFHx0ksvrUuy/BKAbQGq437Jub1oaSnLZd2HSfTxYCKRMbT6O7ZJMRRP2/bYY48CtJs+gJROaLc+7FzUzroxOb6+7qN/gG1S4JfJVEzbn5F7YFlTCJdnj2jPOuusipy+gGMVQc4KQAFJ3y uiaiK2ejdw6C6++OL6/xVyX1FSdEYnciZS6hue6hR5rlyYLqIvektpbhA92LD5P3FSByV RvT85qqH9GQsPLGsEBiYA8ZEQqwHA9JrXvKYALMqJhi7xKZbD3 GTNdjdiLusicKK2yAv01oF968G6rsiaSI5HQNefAHiI4FIG8gB YGkIf30OTdvgau5tGbXiET/Rq+/HxwLKuQgCXJ1g777xzRT2/OwNOgPFSjZ+9u4x7hKse0OSwAa5fBPvBpZsql3+0gOb1x1NPPb VWKY455piaEJbHgJxM/RXRNJsc2ARIMblEdysO5LphlEY08MZD47lf1hQCmOSYorAXyE8 77bRaGcgTMi5KSuBLOuilF8Cm3lquaHnGGWfUb+I8EbP57/IitDfHfHQajQcU1nnxUS9yi+5AKvKKykCrBKRSCysW9DMx+jeI Rdj+jJ0Hhgpg0Q44EgXtgQZ4AFmeKReVPoiYXtIRnd1w5ZVIaY YIio8lMHtbwHfZZZcVKAHWjZ1v+UoFrOc69oKOyO4GTvQHZKAG TvrRJRFaXu2/1XtMbGJoV8hrZTw9sCwAzpMzAPZrYm98uWnyoEEB0pmZmYHvlY mOwBmAApgS4C4EJsAOCH3DTF4MoCKpm0THnsZ5TwKALb+ZNCaJ FQg3c6KvVyrdDAK4HJlseXB0KUXan7HywFABHEsTiaUDxx13XA FJxAWuLIu5CZMqAKgbKikD4AB9btxMBLwCqkRIUbwPejz8h81z zjmnfjvnoYeUAKC9A2HCuFmz9y6wAtDedxClW1k5HlgWAAOhfN QSmugLiEAnb3UjJSICI0ABoujn2F7+ikaeDGTSAfWZFFydKK0P 3m7CHHuilpvC97znPYMDDjigPg1l2U3URis6AzweeCaSr5whnG xNhw5goLABjEu7S7moB9Cepsk3PenygMPm1UkgAlJ7/WwKAIvYQGxFArCBzxY5QClCA7B0JLJNGF+l9AFrH6r28MOWvvq hb2VleWDo68AAogCjXNPL55bAgEzKYJ3Xd3zloHkYAUwAaNVAn RRCEZ1FSsBHb93XOYAnzUCjAG4/rQB2S2QiuWU6+bD25Mrq6UfP6FyM2p+x9sCyRGAeAJjjjz++1n/zIMELNS7xzuWkWSUAYJFWFBaVE42BVR+0bvi8ZgnoViKs+cqjR drkyImuGQGgxtvHTLxuacUhk2m//farlQprzPinL5mA3kAdL47XfugROJd2799a+wUON3DqRTv5MdA Bo1wYWNSLqI7VaQPOrFAkQnOlCQCEPnRiBQIvPN0w4gHMAWNcD +wib4ponrVmy24itHSFjgBMH7q0Mn4eGPqTOAMPCH4xIZK63AO EOsACTFEViIAOjQ0IRVdbQCgNQC93dQNo3VZxLK3Qx0TxzjAAu lnbsftklBIABszearPaIfpnrdh7xlYpTjnllEo1jjzyyBZ5y3v j+2foAI7p1liBDAABLgAG5tw8oRHxtAGtnFTp0wIiUIvCiaLav ZAjjxXd8TQZRGWTwXpvABx98Nff8trll19ey270ogs+cnN9bPi 3Mp4eGHoKEbPlqVYf+tEXiFzmgcwx8IqQ9qKpy7qUICC3155Lf h9Y6kVmqxuJ5KI9AHpYod02v3hiJxonN/Y1Hr99s+Q2fwLN79vOR++Bod/EMRHQ/KrYOwwAldwUcF3C1QGqIgIm+gIk0Dq3GuEcbcCoHm+RU9QEQo+ oLcXhg7foi8aXKT2o0JcsOijOTRh9gNYN3kJAL+L2Z+w8MPQ7E +DwQMGNlqgKgJbHAMy5aJobr3gnUdo5MOkDhOgA1CbSAm2W1ER bEZs8EwNA8SYXsN/+9rdXrosnufjhbY+Hm0t6SR3waGVleGBoOTAQAAgQyTG9AyE/FTUDyLgIXdZg9Us7cCna1QMwMDoXdQFRUa+gMTHQpA3tbPdqpp UH/33IMlkeF+OPD9kmg2gNwNPT06VDMW1/xtoDQwEwIImIucS7mXIsKoquaXPshsy5mzs0wKceEIEvG0Ci7Q NcW1Yf9NGmvz1Q20wGERstsHqQcsghh1Q6oY+oa4J5zK0ffvq0 Mp4e6MbxSjcyQwEwAMg/3UxZWRDVANByGZAGWI5d7kVm7UCrbwDsmL7Z0AAZIEsXFDQiqU mQyOs4qUnq8HDDhrelsqzzis5nnnlmLcn5XrCndXi2MloPdON1 JaBuSZuhAJgwYANQL5j7xQQgAy7AumSLxraA0nqtaKjdHlABM4 BOdAZe9SaIiIpnAAzU2hOF8dbuPEC2dGZi+caZK4PXOkXldevW 1TvA+Q+dW3JYq19aD2wtULckdSgABhYTCEDd3QMR4AAagImQIq F6kRKtSIg2N1NWHeSqQAlwWZFAG9Dj5xhPvIBeUYevfaKxY5PB RFKy5kwvj619MNBewadF4XLFkv3ZVqBuSZGhAFi0BC4pg8s2MN jUzU8PPF0DdKABVk/F0KizguAxMvCJzG6ytAExGYCrH5ACMDrn9s5tichkA63HxKK3t 9nUOaanNepEXxOwAXhLkLnq+mEBdUtShwLgCAMCUQ2gAA9gAEy um+OADSizEgF4IiggWYLTF8g8kJBeWFHIhHCefFif8LUHbPLwV qQcXpT3Ir3o7t0M67708Vg5tOS1smUPLDdIt6xJ9y8frqpxsW3 AA4RA5lfE3vTyCwmrAQowAgngoAMwQPZ6pNQBKKUToiJQo0fjz TR9LHmJ0KK7vb5kKkCoiNA254As+gL6M5/5zMGBBx5YPLST5R2ITCpyWvQtF/L5Vt1IXUE9mr9DATC7AQuoLI89+clPLjCdfvrpBVKAQpMbK6Z7 6yxfzJFWiNzT09MVJa0hSyEAEOhEWpPB3moCXjZtZNpMEOlB8m MrHW4URVq6SRfk1X68mdWJ0QzB6KV2vht7oG7JS0MBMGEiHxDZ u2xbewU6HzUBoPhMu3O0VgOAVFQGfMd+YSw6ir7atQGoOuAUqQ HVpmjD0z7n/pm3/yq06667llwRlnzgn6SykoG6pXFalnchAiSpAAD7OJ/lKyDK5V+EdcMGiCKpcwBziVeA3/qtmzCAR2NT+seArQ+g20Te1atX1xM4PBXg3p7ThO0RqDVwC/wZWgSeLwtYgdMNlPcYgNCvhL0GCcSiKVAlP3Z5Vw+c9qKxvXpF +qFO5M5E0A7A+AS83i7znQngRQe89iu9dDasfCOWYBCWLQJHV8 DLpX/Dhg31MRK5rKgp9wVYoHSOTuR1I2cFIXRyaHyAsb8BsD4mgbzWR/qOPfbYotFmzG0rKfo2oAY5C++XLQITLzcFPJHYUpjo6KbKx/m8iyDf1QaA6ERRABaxARNYgTipg3M8ARoonevjHOCtLgS4idQL u2H0tQ2oixuDZQUwkAGoAoRu1HxeytM3N1qWutyoSROA1q+VAd kGiDY8nNsnmkobgNe5yO1nRWvXrq0XdtAp2sahNKAu7SgsK4AX Uh3AfMrJryIANKmDGzYphfVjERVIgRt4FbTJd0XXAFi976tZJs NbfcpygrgBNV4f7n7Zc+CFzAHK+Zd4QHSDJ1KLxr4a6cmZr7sD stRBH9HaDWFSDI+I/STIx1IC3mFF4QbShUZzeevGAsCJnguZHhDae08i7xa7SfOTem+ 6WY0AdF+olIp4JdK5PoAesAfIC8m5qroG1KvyzmjbxgLAV+eCg DBAtwdGKYHj3LRZKpNja7MFwPbzI/xCMhtQF/LKeNeNPYCBT3ogTQgguTTgTf4L5IpzBa00ZCHgNqCWi7aLP2MP 4HgZQIFWAU7HOdcm4gK6G7vQdHXjsfRQGrU/w/DAyFchtsaoABat4/55i6Zb48Htl2ZFAJj7WzTdfkG4LZaNHYBbRN2W4Zy8viMDcAPq 5IFtGBYPHcANqMMYtsYzHlgSADeQxp1tv9weuEYAbkBd7uFp8q 7OAwsCuAH16tzW2psHmgeaB5oHmgcm3QP/BfEo/mXdgTRSAAAAAElFTkSuQmCChere's a link to a blow up of the trans. http://www.bulkpart.com/2/category/AXOD.html
If you call sonax they should at least be able to provide you with a number that trans usa can use.
12Ounce
07-17-2013, 10:41 AM
It always concerns me that in using some local "Joe-Blow Tranny Repair" ... you have no idea what worn parts he is willing to reuse; if stopping and ordering more parts will "keep him from finishing the job" .. in the time he has allowed.
mdare35
07-17-2013, 10:54 AM
Yea that piston o-ring seems like something that definitely should be replaced but no one seems to list it separately. I'll email them direct see if they have or can get it. If not I'll let you know and you can check your records. Thanks a lot!
mdare35
07-31-2013, 08:53 AM
Got all the parts in yesterday. Tonight I'll probably just gather all the needed tools and supplies and then try Thursday night to git-r-dun. I'll try and take pics to document.
mdare35
08-02-2013, 10:32 PM
Well fudge, the new pin was about 1/8" longer and I stuck it in as is and when I put it in any forward gear it goes nowhere. Tomorrow I'll pull it back off and shorten it and hopefully have some forward motion.
Also interesting is my pin didn't have any o-rings on it. Just the 2 e-clips which were both still intact. There was a notch worn into the coned surface. I have a few pics but just signed up for a photo account and will post when that gets approved.
Pics of new pin next to old and new pin broken.
mdare35
08-03-2013, 06:35 PM
Well I took it apart and apparently the pop I heard while tightening the cover bolts last night was the new pin breaking! Took the old pin and polished a notch on the conical part of the nose thinking maybe that was getting stuck in the hole I assume it goes into. Put it back together and very little difference in the 1-2 shift bump. Maybe a little better in that before it wouldn't bump below about 1500-2000 rpm before now maybe you can go up to 2500. But that may just be wishful thinking on my part. Since my e-clip wasn't broken I'm thinking my problem may be a solenoid rather than this servo. I may take and get the tranny back flushed to see if that helps but I hate to waste the money if I then have to turn around and dump all the fluid to get to the solenoid. I think I'm going to google some more and see if I can find other possible solutions. One I saw earlier today was someone had a 1-2 bump that was fixed by the replacing TPS even thought there weren't any codes....seems a bit fishy...
mdare35
08-03-2013, 07:15 PM
Here's some instruction on how to change the shift solenoid, I might try this next
http://www.automotivehelper.com/topic955631.htm
mdare35
08-08-2013, 07:00 AM
Well went to Jiffy Lube yesterday, had them do their transmission flush and now it's shifting normally!
I did this after thinking that my transmission issue wasn't that the solenoid wasn't working but that it was getting stuck until pressure built up enough and the bam it slammed into gear.
So I'll drive it a while and report back later on whether it's still going good or not.
Thanks for everyone's input!
scubacat
08-08-2013, 08:01 AM
Wow, they actually did it! Half the time they take your money and never even do the service. Congrats on your easy fix!! I'd definitely let a shop do that for me. It's not THAT much money and way too much of a pain and mess to even attempt to flush that system myself.
mdare35
08-08-2013, 11:41 AM
They actually make you sign a waiver if it's been more than 60K Miles since you had the tranny flush done, in case it stirs up crap and causes problems or leaks.
But so far after about two lightly harsh shifts right after the change it's back to the normal smooth ones like 2-3 ad 3-OD. Down shifts were always ok.
I'll keep my fingers crossed.
Now I just need to get the new rear drums/shoes adjusted so they quit clunking when stopping. I don't think I've ever had rear drums that were so sensitive or just wouldn't seem to adjust quickly. Then again the main ones I've worked on were in a '78 Fiesta and they had a ratcheting adjuster not a little star screw and pretty much the first backup you did you could hear the ratchet adjust the full amount they needed in one shot.
scubacat
08-08-2013, 04:09 PM
It's probably moot, but I'd have had a transmission shop drop the pan as well and check for any sort of excessive debris. That's what I did when I thought mine was on the fritz. For $150, they dropped the pan, cleaned it in the parts washer, changed the filter, and flushed out the fluid with new fully synthetic fluid. And they actually know me now for when I really need something done.
Nevertheless, I'd just check the level next time you pull in for gas. I'm wary of those Jiffy Lube teenagers messing something up!
kevink1955
08-08-2013, 09:40 PM
On a trip, 800 miles from home my 96 started surgeing like it was falling out of OD momenterly but it continued even with the OD locked out.
I did the cooler line flush/fluid change in the motel parking using full synthetic Mercon and the problem went away completly. Have driven about another 60,000 miles since then with no problems. Have done the flush/fluid change once since them and a drop the pan filter replacment once and it's still running fine at 150,000 miles.
Never thought a fluid change could make such a differnce but it did, these things are hard on fluid and I think the synthetic Mercon is well worth the money.
By the way the old fluid (prior to the motel lot change) was clean and had about 40,000 miles on it with a filter change when it was installed but it was non synthetic.
scubacat
08-09-2013, 10:53 AM
I think minivans are hard on transmissions in general just by design.
Curious - how did you do a transmission flush in a parking lot?!
northern piper
08-09-2013, 11:51 AM
just a quick point on the brake clunk.. check out the shoes.I've had 2 delaminate from the backing plate that would make a heck of a racket. Don't just pull the drum off, see if the friction material is actually attached to the backing plate
mdare35
08-09-2013, 12:00 PM
I'm going to fool with the brakes again this weekend. The shoes are brand new so if they are already de-laminating I'll be surprised but then again maybe not. I'm probably going to try your arcing trick and adjust the shoes out till they have just a touch of drag. I had adjusted a previous set too much a while back and man those drums got hot! So this time I was just going to let them adjust themselves, but either they aren't adjusting, and yes I lubed the backing plates and the adjustment screw threads, or it just does it so little each time it take a lot more back up stops than I've done so far. Wish me luck!
mdare35
08-10-2013, 02:33 PM
Kind of hate to go on about drums on this thread but oh well...
I bought new adjusters, put them in and adjusted to give slight drag yet still have the noise. I does it when I pull the e-brake too. I'm thinking like this thread that the drums are not round.
http://www.automotiveforums.com/vbulletin/showthread.php?t=963383
I wish I'd saved the old drums and could put them on to compare!
northern piper
08-10-2013, 06:46 PM
the other thing you can do is purposely adjust the shoes so that they don't push into the drum at all. (So when the wheel is on, if you spin the wheel it'll rotate several times 4-5). Then understand that the self adjusters will adjust. As the fronts do the bulk of the braking the shoes may just settle in a bit easier. With aftermarket parts that aren't super true sometimes you'll get bad, non-round drums and shoes which don't match up too well either.
Another thing is, assuming that with the shoes adjusted just as they are, if you can spin the wheel about a full turn or maybe 3/4, you can leave them that way. They'll get hot but after 10 miles or so the drum/shoes will be more congruent.
If you back the adjusters off as indicated above, just be careful and make sure that you have a few reverse/forward driving periods to help the adjusters-adjust.
mdare35
08-11-2013, 04:26 PM
The wear on the shoes, all 4, looked just right. Looked like the shoe arc was slightly smaller than the drums and that the wear was in the middle 80% and 10% on each end wasn't rubbing. Was thinking I'd tossed the old drums but found where I put them and tried them. All thumping/clunking went away so I'm going to assume that the new shoes were just out of round. Took old shoe back to Advance Auto and they gave me a refund.
However on the way there the O/D off light started flashing and the message center said Check Transmission. And it wasn't going into OD, just third. It's still shifting smoothly. I check tranny fluid when I got home and it seems low so I'm going to stop in Jiffy Lube tomorrow and have them top it off. I glanced at the 1-2 servo cover and noticed a drop of fluid on the junction to the tranny so I may need to check the tightness of those bolts. Always somethin'...
kevink1955
08-11-2013, 07:43 PM
By the Wiswind method, remove a cooler line and put it in a can. Start the engine and while the old fluid is being pumped out keep pouring fresh fluid in. Once you get to about 10 quarts you have exchanged most of the old fluid.
A remote starter helps or you could have 2 people, it is hard to get the new in as fast as the old pumps out.
12Ounce
08-11-2013, 08:16 PM
BTW ... Ford outlines the "Wiswind method" in the Windstar shop manual. Hope he is still getting those royalty checks!
northern piper
08-15-2013, 06:26 AM
sorry for your news but at least it's a solid "find" for a problem. And no, the photo doesn't show up for me, just a text box that says attached thumbnail.
mdare35
08-15-2013, 08:44 AM
I deleted my previous attempt, not sure what it didn't like about that pic, wasn't even that large. And this one won't enlarge. Not sure what I'm doing wrong, no real big deal I guess. Anyway broke right where it necks down and has a hole drilled in it. I just wasn't paying attention to the fact that I had the 2 lower bolts in a lot further than the top 1 and it snapped. I heard it at the time but just thought it was something bound up that popped into place. But with this piston broken, no matter what forward gear I had it in, it would barely move at all if on a slight down grade.
GeoClark
11-17-2013, 02:43 AM
Thank You for this timely information!:smokin:
therussianmechanic
12-21-2013, 11:43 PM
Hey there guys. Not sure if this post is still active, but I've got a 2000 Taurus with the AX4 piece of shit in it. And it won't shift into second gear. Run in first and reverse, the clutch seems to engage to shift (like its in neutral) but just won't go over to second gear. Before it got this way, the tranny was slipping pretty rough, exactly how piper described it in his van in the original post on this thread. Any pointers or help out there??? I'm mechanically inclined, just need some pointers and ideas of what it may be???
GeoClark
12-22-2013, 11:07 AM
My transmission issue is a failure to shift into second gear - but it will slowly accelerate to about 70 kph then shift into overdrive at a throttle acceleration just above fast idle.
It will only slip and rev up if one tries to accelerate.
Iit would however act correctly if I used the shifter to start off in second then shift manually up to OD...
Last week I went to a transmission shop I had previously used for another vehicle several years ago.
They describe several issues with these transmissions - among which are cracked pistons. All he described to me were cracked internal parts but he never said he had ever dealt with the low servo.
I bought my '96 Windstar with this problem and I parked for the winter.
I will take it into this transmission shop in May since he said he will then remove the low servo cover and take a look.
This is not a repair I want to deal with since I do not have a hoist but I have found the UPGRADE kit at the vendors indicated in this post.
The transmission shop indicated to me that Taurus has problems along with the Windstars.
I would guess winter driving is the root cause. Are we not supposed to let the vehicle warm properly before engaging the transmission? (a childhood recollection!)
I feel this is definitely worth a few hundred :banghead:dollars for the 'look' and probable servo replacement.:banghead:
northern piper
12-22-2013, 12:37 PM
I agree, a look into what is beneath the servo cover would be worthwhile and likely yield some info. Stepping back, when my low servo went, I reasoned that without removing the transmission, the servo is pretty much the only thing that's serviceable, aside from the usual fluid/filter changes. So, not having anything to loose, I figured it was worth a shot. I did first speak to the Ford service guy who "assured" me that the servo wasn't my problem, but upon opening the servo cover as detailed in my initial posts indeed the servo piston "e" clip was the culprit.
While I do have the luxury of a lift, I'd suggest that this repair is doable on the ground, assuming that you've got the van up on ramps. Whether the van is on the ground or in the air, (and you're lying down or standing) the space where you need to reach doesn't change. It's a tight squeeze but there are no heavy duty fasteners that require lots of physical ummpf or anything. I'd attempt it on the ground for sure. Just get your parts first.
GeoClark
12-22-2013, 11:10 PM
Since I have the ramps and sufficient tools , I will order the kit and have a go at it in May.
I can always tow it to the transmission shop if needed.
Thanks a Lot , piper!.
parkerb
08-23-2016, 08:41 AM
piper, thank you for this write up. my '00 with 241k miles has 1-2 shifted poorly for a while. along with some body rust, the van is on it's last leg. i was curious, if the e clip is broke on mine, is there space available for the broke fragments to circulate out of that bore and into the rest of the trans? i'm considering this repair but i do not want it to snowball.
tia,
parker
tia,
parker
northern piper
08-23-2016, 08:47 AM
Hi Parker,
I believe that if the clip broke it could be drawn into the body of the transmission. As I said in my write-up, luckily I found all the pieces and was able to confirm that nothing was floating around in mine.. I hope you'd have the same luck!
It's not that bad a repair and I'd suggest it's certainly worth it to try. Just get the screws of 2 or 3 lengths so you can incrementally tighten the cap on once you're done. That's the toughest part of the job IMO.
Good luck!
Good luck!
12Ounce
08-23-2016, 02:02 PM
Ditto ... I had a very similar experience; recovered all pieces of the clip.
And "ditto" on the additional screws of longer lengths ... or some all-thread rod.
scubacat
08-26-2016, 06:35 PM
Definitely worth a try, but at 241K your transmission is almost certainly due for a rebuild. Obviously that depends if you're going to keep the van, but I just had it rebuilt on our 2002 (165K miles) and I have to tell you, it's like driving a whole new van. There wasn't really anything majorly wrong, although there was 1-2 shudder and an occasional flare (temporary "miss" or slip on 1-2) but just the amount of power it has now is impressive. The clutch packs, seals, etc. just get worn down after a while, especially in bigger vehicles like minivans. Simply dropping it off at a shop and picking it up 3 days later, the total cost was $1750, and that included a new torque converter, fluid, and a complete rebuild. If you get a good shop, they generally know these vans inside and out and do a really good job. Amazingly, they never even removed the axles from the wheel hubs!
If you're going to keep the van a few more years, you probably need a rebuild. Then again, if not, see if you can recover and replace that clip!
