Glossary of terms
kafkacell
04-29-2011, 03:27 PM
AAC. Auxiliary air control.
AAP. Auxiliary accelerator pump.
AAC. Auto adjusting suspension.
AAV. Anti-afterburn valve.
ABDC. After bottom dead centre.
ABV. Anti-backfire valve.
ABSV. Air bypass solenoid valve.
A/C. Air conditioner.
AC. Alternate current.
ACC. Air conditioner compressor clutch.
ACT. Air charge temperature. Temperature of the atmospheric air as it goes into the engie.
A/F. Air / Fuel ratio.
AFC. Air flow control.
AT. Automatic transmission.
A/T. Automatic transaxle. Also "Automatic Transmission" in some texts.
ATF. Automatic transmission fluid.
ATX. Automatic transaxle.
B+. Battery positive terminal.
BAT. Battery.
BPS. Back pressure sensor.
BOO. Brake on/off.
BVT. Backpressure variable transducer.
Cº. Degrees Celsius.
CANP. Canister purge solenoid.
CCC. Computer command control.
CCRM. Constant control relay module.
CCW. Counter clock wise.
CDI. Capacitor discharge ignition.
CEL. Check engine light. See MIL.
CV. Constant velocity.
CWM. Cold wheather modulator.
DC. Direct current.
DI. Distributor ignition.
DICS. Dual intake control solenoid.
DIS. Distributorless ignition system.
DLC. Data link connector.
DPFE. Delta differential pressure feedback EGR.
DRL. Daytime running lights.
DTC. Diagnostic trouble codes.
DVM. Digital volt meter.
EAI. Electronic control ignition.
EATC. Electronic automatic temperature control.
EDF. Electronic drive fan.
ECA. Electronic control assembly.
ECT. Engine coolant temperature.
ECU. Electronic control unit.
EEC. Electronic engine control.
EGO. Exhaust gas oxygen.
EGR. Exhaust gas recirculation.
EI. Electronic ignition.
EOBD. European onboard diagnostics.
ER. Engine running.
EVAP. Evaporative emissions control system. Usually referred to as the "carbon canister".
EVP. EGR valve position sensor.
EVR. Electronic vacuum regulator. External voltage regulator.
Fº. Degrees Fahrenheit.
FF. Flexible fuel.
FP. Fuel pump.
FTSB. Front tower strut bar.
GVWR. Gross vehicle weight rating.
HEDF. High speed electronic drive fan.
HO2S. Heated oxygen sensor.
HSC. High swirl combustion.
IAC. Idle air control.
IAR. Integral alternator regulator.
IAT. Intake air temperature.
ICM. Ignition control module.
IDM. Ignition diagnostic monitor.
ISC. Idle speed control.
KDS. Kickdown switch.
KOEO. Key on engine off.
KOER. Key on engine running.
LH. Left hand.
LIM. Lower Intake Manifold.
LPG. Liquified petroleum gas.
LUS. Lock up clutch solenoid.
MAF. Mass air flow.
MAP. Manifold absolute pressure.
MIL. Malfunction indication light. See CEL.
MLP. Manual lever position.
MT. Manual transmission.
NDS. Neutral drive switch.
Nm. Newtons meter.
OBD. Onboard diagnostics.
OBD II. Onboard diagnostics with extended capabilities to monitor emission controls as well.
OEM. Original equipment manufacturer.
PCM. Powertrain control module.
PCV. Positive crankcase ventilation.
PFE. Pressure feedback EGR. Is a conventional ported EGR valve with a back pressure sensing tube attached to it. The valve is used in conjunction with a pressure transducer which supplies pressure feedback to the EEC-IV processor.
PIP. Profile ignition pickup. Profile ignition pulse.
PSPS. Power steering pressure switch.
PULSE AIR. See THERMACTOR II.
RH. Right hand.
RPM. Revolutions per minute.
SHO. Super high output.
SPOUT. Spark output.
TCC. Torque converter clutch.
TDC. Top dead center. Refers to the highest point in the cylinder that each piston reaches as it travels up and down when the crankshaft turns.
TFI. Thick film integrated.
THAC. Thacometer.
THERMACTOR. Exhaust air injection.
THERMACTOR II. Exhaust air injection using pulses of air present in the exhaust to pull fresh air into the exhaust manifold.
TPS. Throttle position sensor.
TVS. Temperature vacuum switch.
UIM. Upper Intake Manifold.
VECI. Vehicle emissions control information.
VIN. Vehicle identification number.
VREF. Voltage of reference.
VSS. Vehicle speed sensor.
WD40. Water displacement 40th formula.
WOT. Wide open throttle
Hope this help.
BAT. Battery.
BOO. Brake on/off.
DC. Direct current.
ER. Engine running.
FF. Flexible fuel.
FP. Fuel pump.
LH. Left hand.
MAF. Mass air flow.
Nm. Newtons meter.
RH. Right hand.
THAC. Thacometer.
Hope this help.
