no ac in rear just recharged
big white bufflo
06-01-2010, 09:17 PM
my wifes 2002 winstar ac pump went bad i replaced the pump and the accumilator per the auto parts store took it to dealer for recharge now it has no cool in rear ac any ideas will be helpful
tomj76
06-03-2010, 09:11 PM
The first thing to check is the temperature of the lines in and out of the rear evaporator. You can do this from underneath the vehicle. If the outlet line is not cool (i.e. 5-10 degC, 40-50 deg F), then your problem is likely with the a/c charge or the expansion valve on the rear evaporator.
Did the dealership evacuate the system, and check to make sure it held vacuum? If not, then the issue might be water in the system.
If you can check the low side pressure and the termperature after the evaporator, you can look up the boiling point of the R-134A for the pressure on your low side. If the temperature is higher than the boiling point, then not enough refrigerant is flowing through the rear evaporator. This check can be done on the front evaporator too.
It's also possible that you have a problem with the blend door. If this is the case, then you're A/C will probably blow heated air. It's often traced to the selector switch on the dash.
big white bufflo
06-05-2010, 09:31 AM
dealer did all recharge work i did all the mechanical they say all pressure a ok but the pump likes to cycle on off alot the only thing i did not do is change the orficcould this be pluged and were is this orfic screen located
tomj76
06-08-2010, 03:12 PM
Compressor cycling is controled by a pressure sensing switch. It is located on the accumulator/dryer. Usually frequent cycling is noticed when the charge is low. A restricted orphic would probably cause lower than expected pressure, and corresponding low temperature. With low pressure you should also notice a lower than normal temperature (even icing) after the restricted orphice.
The rear a/c uses an expansion valve instead of a fixed orphice. The expansion valuve is controlled by a temperature sensing bulb mounted on the cold side of the valve. It's temperature should always be about 2 degC or 36 degF during operation.
big white bufflo
06-21-2010, 06:47 PM
were is the orfice tube located on this 2002 windstar
