Fuel Trim banks
DrivenByDemons
05-09-2010, 09:30 PM
Hey all, I'm still troubleshooting misfires in an 02 windstar. Seems to only happen under hard acceleration. The van idles great and revs good with no load on it. I decided to try and interpret some readings from a OBDII scantool to see what I could find. I can see the misfire counter increase in the freeze frame data and the long term fuel trim on a few banks is through the roof @ 50% and higher. I noticed there are 4 fuel banks giving readings but don't understand how to split these banks in to cyl #'s. I have pending codes P0302 and P0306. Fuel pressure is on the list for tomorrow but I'd really like to get to understand these PID readings better.
tomj76
05-17-2010, 12:33 PM
You may find the documents on this webpage to be helpful:
http://www.motorcraftservice.com/vdirs/retail/default.asp?pageid=diag_theory_retail&gutsid=diagsheet&menuIndex1=16
DrivenByDemons
05-17-2010, 12:35 PM
Thanks, I actually found those after I posted this. That OBD scanner is a great tool once you know how to use it.
