1998 Saturn SL2 flickering dash panal lights
sixwongs
09-14-2008, 06:45 PM
I just noticed mydash panal lights have
been flickering.
Does this mean something
is loose?
I turned the car on and it was dead then itook the key out and the lights came on, the car started.
NOt sure if there is a loose connection some where or maybe the starter going bad?
Thanks
RC1488
09-15-2008, 12:30 AM
Check the dimmer switch. It may be a bad contact there. If not, you may need to remove the cluster and inspect the connections on the back.
drew300
09-18-2008, 01:03 PM
Also, check your battery connections.
I had the dash light flicker, and it was the neg of the battery lose.
But it started fine
