View Full Version : SC/SL/SW
Pages :
[ 1]
2 3 4 5 6 7 8 9 10 11 12 13 14
- Saturn Headlights Question!
- Manual Transmission Problem
- 1993 Saturn Sl1
- Dash lights flickering on a '00 SL-2; won't start...
- Compound for holding on parts related to cargo netting
- Misfire cylinder 1
- Begun engine removal
- 97 SL2 Problem with cold start
- 2000 Saturn SC2 computer won't reset
- 2000 Saturn SC2 Keyless Remote
- 92 Power window motor
- Problems! Problems! Problems!
- 1998 SL2 Won't start after Garmin use
- Ignition Lock Cylinder
- new here and have some saturn questions
- water pump
- 2000 saturn hard shift
- Saturn Rings
- 99 sc2 p0410 wont go away and poor acceleration
- OBDII code issues
- 1st and reverse only, 5 speed Manual 97 SL
- SC2 Saturn Wont Start - Help!
- 1999 Saturn SL2 Noise from right side wheelwheel to right
- sqeaking sound
- 97 SL2 won't shift into first or second
- Need help identifying part.
- '97 SC2 transmitter board needed
- Mechanic says battery has low voltage
- '98 SL2 w/ 199,000 mi. Wont Start. One click when key turned to Start
- Emergency Brake Handle slipping, won't hold
- 2001 SL won't start irradic
- whats needed to remove front seats
- 2002 Saturn SC2 No Fire after engine dies
- Jet engine noise
- 1997 Saturn sc 2 coupe wierd starting/shifting problem
- 93 Saturn sl2
- White smoke "on load"
- 1998 SL2 "Sputter"
- my 1998 sc2 saturn wnt start... it will crank til the battery goes dead but it doesnt get any fire from the coil backs. i need help...
- 97 Saturn SC1
- Failed Inspection, Computer can't connect
- Fixer-upper 95 SL thoughts anyone?
- Where To Buy?
- Rear wheel bearings- how to tell which side is going?
- 2001 Saturn SL Engine Bucking, Unreponsive Gas Pedal, Erratic Idle
- I need to up date my stereo
- 99 SL2 Clutch wearing out
- Stereo Help!
- 99, Saturn SL1, sound while driving
- lose of power 0n my 93 sl2
- 2000 SW2 wheel bearing
- SC2 was rained on... now no Radio/Odometer
- 1999 Saturn SL- DOHC Cruise Control?
- A/C compressor noise
- 1999 Saturn SL2 just started making clunk type sound
- Oil aound spark plug
- 99,Saturn SL1, Day lights are off
- 1999 Saturn SC2 motor.
- Saturn SC2 Won't Start
- 1999 SC2 Psgr Window
- 98 saturn sl stalling at lights, blowing white smoke
- IAT circuit problems
- warning bell wont turn off?
- 98 Smoked Side Marker LIghts
- My Saturn SL2 Won't Turn On After Changing the Battery
- highway vibration
- 2001 SL1 manual transmission shifting problem after braking
- 1991 saturn
- Meters freezing
- put a 2002 motor in my 94 sc1 1.9 sohc
- '00 SL2 bearing/hub replacement?
- 1994 SW Clutch trouble
- 1995 SL1 acceleration hesitation
- 99 SC2 Heater Core
- 97 SC 1 trouble code
- My SW-2 cooling systems troubles, need advice...?
- adding cruise control
- 1999 SL2, dohc Oil burn issue
- 99 SL 1 performance brakes?
- general question about the 95 sl2 with 2.2 motor
- car wont start
- Trouble starting
- 96 SL2-possible wiring harness prob?
- Another head swap thread...
- SL1 won't turn over
- Any collision experts?
- Lug nut caps won't come off a flat!!! -Saturn SC 1
- 2002 Saturn SL Brake Lights don't work
- 97 Saturn sc2 Hood interchange
- 96 SL2 manual dowload.
- 2000 Saturn SC2 running horrible!!
- 99,Saturn SL1,1 shoe pad wearing
- 98 sw2
- 97' SL "rumbling" idle sohc
- Looking for a better engine.
- Car overheats when in heavy traffic
- P0442 and now P0440
- 93 SL2 Intermittant engine miss
- 01 SL "buzzing" noise coming from PS pump?
- 02 Saturn 1.9 DOHC Coupe Unknowns??
- Selling conditions on DriverSide
- 1997 wippers
- engine trouble
- Drove car w/o oil I think
- Wideband 02 upgrade
- Manuel transmission troubles
- 94 SC2 "Service Engine Soon"
- 97 SL2 Automatic Trans, will not shift into overdrive
- Car wont start - manual
- SW2 runs rough
- 1998 Saturn SL2 no crank
- 98 sl1 code p0327
- Coolant Leak
- poor shifting manual
- REM wire touched my ground wire.. how can i fix the issue?
- Sw2 looses electrical power and stalls
- 1999 SL1 Rear Defroster Not Working
- 1999 SL2 won't start
- Front Wheel Hub Bearing 2001 Sl2
- Stalling
- need more horses
- 99 saturn sl goes wide open
- 95-SL Door Locks gone wild
- 98 sc2 bogging/ not running right
- 2000 sc1 rpms keep sticking
- 99 SATURN SC2 1.9 DOHC Ideal Oil Pressure??
- 1998 saturn SL2 idle speed changes low, high, back to low
- Loss of Brake pedal when backing up
- 98 1.9 dohc engine pics needed please
- 97 SL2 Not getting power
- Fuel Line Disconnected!!!???
- 97 SW2 won't idel
- 97 sl1 starting
- 96 sl shifting trouble.
- What is Engine Trouble code 53?
- 98 SC1 fuel gauge
- '98 sc2 Low coolant light/Coolant overflow blow
- 97 Saturn won't accelerate
- 92 SL2 or 94 Cavalier?
- My 1994 SL won't turn over
- translate to a standard plug
- 99 SL1 Transmission sound
- 92 sc1 hard start runs after warm
- Sc1
- saturn heads
- motors swaps for power and play room
- 2000 SL1 Random Misfire PO300B
- My Sick SC1
- Head gasket. Question
- Code P0405 Exhaust Gas Recirculation Sensor A Circuit Low
- 2002 SL1 error codes P0128 and P0341
- Code P0118 Temperature Circuit High Output
- Ignition Coil Wont Fire
- 1999 saturn sc2 3dr idles low wont start unless gased down to 3000 rpm for
- 95 sc2 interference engine?
- 99 SL2 Speedometer 20mph faster than car
- Electrical Issue for 1997 Saturn SW2
- 01 SC1 Bad Wheel Bearing?
- 96 SC1 EGR Valve sticking?
- Catalytic Converter and Smog
- 95 SL! Loose Shifter!
- response to my first thread of curious
- curious
- 2002 sc2 info needed
- 02 Saturn SL2 won't start
- 95 saturn sl2 no start
- help with 97' SC turbo selection
- Codes P0301,P0507 2001 SL1 Help
- SC2 Steering Column Controls Loose
- Hole in intake manifold
- '01 SC1 won't start reliably
- Heater Core Help
- sc1 fogs up
- coolant low light
- window fogs
- 3rd gear '96 sc1 issues. the rest are fine. (wordy post)
- Sludge in Coolent Recovery Tank
- 1997 Saturn sl SOHC dies?
- Mileage
- Traction Control
- readiness monitors
- 1999 sl2
- DTC codes...
- p0711
- No Start on 93 SC2
- 1992 Sl Charging problems
- 00' SL2 Tempermental starting.
- P0410 code
- 94 SC2 Headlights out - Headlight switch?
- Crossed Jumper Cables...
- Running temp
- Air Pump
- 94 saturn sl1 hard hesitation
- Cars runs cool
- Brake Grinding
- Rear Hazard Flashers inop.
- 1997 SL2 Idle Cylinder Miss...
- 99 saturn Sl2 Front Brake Caliper
- service light (wrench icon)
- 94 Saturn heater fan
- P0133 Code
- 95 SL2 won't start
- 2001 Sl2 1.9 DOHC Burning Oil
- 1995 saturn stick wont start
- 2001 SL2 won't start
- 1996 Saturn will not start
- Egr
- 1997 SL wont start popping IGN3 fuse
- 98 sl2 1.9l dohc timing chain broken
- Timing Chain
- 1999 SC2 Shifting problem
- Installing Stereo/wiring 2000 sl
- 1994 SL won't start just click
- 2000 SL2 will not start
- 02 SC2 - Bogged down/suffocating - ideas welcomed
- losing power furthur up the tach
- Steering wheel / Rotor problem
- Parts Diagrams???
- 1992 SL good buy?
- 2001 saturn sl2 won't start
- 1997 SL serpentine belt
- Unidentified Strange Sound
- 1999 saturn intermittent start when hot
- Running now not later
- Coolant Leak 01 DOHC
- A/C clutch replacement
- Dex Cool Fool
- 1996 SL2 Won't Start - Electrical - Dash Lights Go Out
- Spit Sputter Die.....hard to restart
- 1997 sw2 won't start
- Crazy Security System/Radio Issue 99 Sl1???
- 1997 Saturn SL2-codes and what they mean
- Coolant fan issue..
- Turbine speed sensor
- Bad Starter - SL2
- 1999 sld automatic
- exhaust pipe diameter question
- Abs
- Coolant spitter
- how much trans fluid after i drain it?
- no horn?
- haha!!! just my luck!
- 1998 Saturn wont stay running
- '97 SL2 Clutch problems (go figure)
- 1997 SL1, High Altitude problems
- Need help asap!!!!!!
- 95 sc2 motor swap with 99 sc2?
Automotive Network, Inc., Copyright ©2012
