1.6 swap to sr20det
10_sec_sentra
12-23-2002, 09:52 PM
i am lookin to swap from my 1.6 engine to a sr20det i was just wondering if it is possible to do so or would be easier to swap to a sr20de and just build that up
turbo2nr
12-24-2002, 10:01 AM
they sell ff sr20det motors from japan,
they should fit in, i cant rember what car has it exactly, but it has been done,
i say go with the sr20det not the sr20de it will be much easier to work!
good luck
1
b13seriesser
01-16-2003, 12:27 AM
id reccomend picking up an SE-R. Overall you would save a hell of alot of money. The det is bolt-in to the SE-R. SR20SE Comes stock in the SE-R as well as a 5-speed manual Tranny. Better suspension too and the 91-94s are all 2-door =D
98sentraGTiR
06-02-2003, 11:20 PM
Theres 2 options if your wanting an SR20DET motor the GTiR or blue bird both i believe are from the pulsar except the GTiR was called a sunny. I personally like the GTiR better than the BB, it packs a 227 bhp with half bar the BB is around 205 bhp and only $3-5 hundred cheaper. they can be found anywhere from as low as $2000 or to 3000. its pretty much a basic drop in, theres ways people fabricate the engine bay for more room but its not needed, ive heard from a mechanic that if you go ahead and drop a SR20DET in anything besides the 240sx it will fail visual check beacause of no o2 sensor. just make sure if you buy a GTiR or BB, you should get a complete package dont go by pieces, your going to need the block, head, manifolds, turbo, intercooler and piping, complete harness, all sensors, ecu, transmission, and motor mounts
intergafan1000
06-08-2003, 01:52 PM
it could be possibal. after all look at all the hnoda guys swapping vtechs on the cars.
Honda_punk18
06-21-2003, 06:50 PM
nothing wrong with a little VTech fella's :dogpile:
TurboB15sentra
06-21-2003, 09:01 PM
Here's what you need to do a 1.6-2.0 swap..
SR20DE or DET
91-99 SR20DE FWD tranny (95-97 prefferably)
4 SR20DE engine mounts from a 91-94 SE-R
91-94 SE-R engine crossmember
91-94 SE-R engine wiring harness
91-94 SE-R SR20DE FWD axles
91-94 SR20DE radiator
Then you will need the obvious stuff- downpipe, intercooler piping, intercooler, recirculation valve, exhaust.. etc..
Travis
TurboB15sentra
06-21-2003, 09:08 PM
That's why Nissan made the SR16VE, SR20VE and SR16VE-N1. Those are Nissan's Variable Valve Lift (VTEC) engines.
carrrnuttt
06-22-2003, 02:37 AM
Don't forget the first production motor with BOTH variable-lift timing AND a turbo stock, the SR20VET. 276HP, baby...
The stats are as follows:
SR16VE - 173HP to 197HP
SR20VE - 187HP to 204HP
SR20VET - 276HP
Not too shabby.
TurboB15sentra
06-22-2003, 08:13 AM
yeah.. forgot about the VET.. ;)
What's realy cool.. is when you take the SR16VE or the N1 (if you're lucky enough to find one), and stroke it to a 2 liter using the SR20DE or VE internals! The 16 cams actually produce a better overall powerband than the 20V and the regular SR20VE. I think the best is around 200whp with just intake, header and exhaust on a stroked SR16VE with N1 cams
Travis
rabidpanda
06-25-2003, 12:59 PM
Can a SR20VET be put into a '99 Sentra SE?
Also can someone give me a link to engine/tranny retailers for this specific model?
I currently run a SR20DE with an auto :(
I'd rather be able to swap a V6 into my car, but haven't heard any stories about this happening. I have heard on the other hand about Miatas getting SBV8s stuffed in them so was figuring there has to be a way for me to have a V6 in my mostly roomier engine bay. :biggrin:
TurboB15sentra
06-25-2003, 02:02 PM
To be honest.. you're realy wasting your time getting a VET. It will cost you about 4K for one.. and for that kind of money.. you can get a DET and make way more power per dollar. However, I can get all of these engines.. www.forcedinductionracing.com I don't have the VE or VET listed.. but if you want to contact me, I can get pricing for them as well.
Travis
rabidpanda
06-25-2003, 02:03 PM
I can't afford it now but I do want to know what my options are with my car.
EDIT**********
Was wondering what the HP difference was from VET to DET?
sr20de4evr
06-25-2003, 10:22 PM
EDIT**********
about 50-60hp, but I believe they have very similar tq #'s
DET - 210hp
VET - 270hp
these numbers are just off the top of my head, with a little research you can find out more exact figures
