Our Community is 662,000 Strong. Join Us.
View Full Version : Sentra | 200SX (USDM FWD)
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13
  1. 1997 Sentra P1110 OBD code Help!!!!!!!!
  2. 2001 Sentra trunk doesn't open with remote
  3. turbo spec v
  4. 1997 Sentra door locks keep locking
  5. Need Information about Dashboard Lights
  6. 2001 Sentra gear selector doesn't light up
  7. New computer in 2001 Sentra beeps for a few seconds after car is tuned off
  8. Engine swap help for 88 nissan?
  9. P1122 / P1128 Diagnostic Procedure Help
  10. CRASH - is this why it wont start?
  11. free service manuals
  12. 2003 Sentra Power Steering Rack Replacement Cost
  13. Ignition problem
  14. 2004 Sentra radio won't work
  15. Unusual Engine Swap, is it possible and any tips?
  16. 2006 Sentra 1.8 Sepentine belt Replacement
  17. Check Engine Light? Symptoms?
  18. 2010 Nissan brakes failed leading to an accident
  19. timing chain
  20. throttle position sensor
  21. help with automatic transmission
  22. 2001 Sentra horn not working
  23. 2001 sentra bumper cover removel
  24. 2002 Senta Spec V misfiring
  25. 2003 nissan overdrive issue
  26. does spec v need back pressure?
  27. oil burning bad after new exhaust
  28. 1998 Sentra SE Problem
  29. Fuel Consumption Of 2007 Sentra
  30. 96 200SX No Fire
  31. 94 sentra dash lamps
  32. 2002 sentra will not start
  33. 03 Sentra not starting
  34. 2001 sentra timing belt & or chain
  35. brake pedal is funky
  36. Nissan Sentra Cold Start problem.
  37. 2001 Sentra back-up lights?
  38. 1997 - Help with belt
  39. 1985 Sentra timing belt failure/motor swap
  40. Radiator Fluid everywhere, no apparent leak anywhere?.?.?!
  41. p0171 & p0174 FIXED WOOOHOO. o wait.. p0420?
  42. p0171 & p0174, or was..
  43. oil sensor
  44. 1999 Sentra Inner Tie Rods
  45. Fuel Problem 1998 Nissan Sentra
  46. Replacing caliper knuckle bolts
  47. 1999 Sentra: Fixed blown out Spark Plug
  48. 1996 Sentra hesitation at 45-60 mph
  49. Help with 87 Sentra (Wiring Diagram)
  50. 2000 Sentra won't start
  51. 1996 Sentra: Fixed Shifter Stuck in Park
  52. Erratic Temp readings - b4 and after water pump replacement
  53. clutch adjustment
  54. 1995 Nissan Sentra Engine Rattle
  55. lower acceleretion and hesitation sentra 1985
  56. 2004 Sentra 1.8S-No brake lights?!?
  57. Urgent! Need help! about brake system. Please help me!
  58. Hiss from engine
  59. radiator on 93 SE
  60. what engine to swap into an 03 spec v
  61. 1988 Sentra XE Hatchback tranny problems.
  62. lock up converter for sentra?
  63. 96 Sentra trans will not shift when warm
  64. Speed senser
  65. Rpm at 65mph
  66. 2010 Navigation
  67. 2010 Navigation
  68. 2010 Navigation
  69. 2010 Navigation
  70. '84 sentra vaccum diag.
  71. '85 sentra 1.6 L carb diagram?
  72. 2003 sentra trans is slipping when car first started
  73. 07 Sentra 1.8s will not start consistently
  74. 05 1.8l no heat
  75. brake and check engine light flashing
  76. Starting issue
  77. 2001 Sentra service engine soon light is on
  78. Help with Air intake/Springs/Trunk Ideas 1.6
  79. I want my car to start!
  80. 1994 Nissan Sentra LE 1.6 4 door auto
  81. sentra 04 1.8 shuts off when stopped in traffic
  82. clutch adjustment
  83. 99 sentra lost electrical accessories
  84. '93 Sentra shifter question
  85. CVT Tranny Releability
  86. 2001 Nissan Sentra transmission Issue
  87. Which spark plugs do you recomend?
  88. B13 Sentra Wobbly Wheel?
  89. 2004 Nissan Sentra sometimes wont start first time when cold
  90. Help How to change power steering belt 96 sentra
  91. 04 sentra advanced timing
  92. Plans for my Sentra, I need opinions.
  93. Various problems with my 1992 Nissan Sentra XE (4 door)
  94. 1996 200sx 1.6, i need mod info~!!
  95. Blower only works on super high
  96. 2000 sx will not start
  97. How to get into ECM Diagnostics mode
  98. power steering pump question
  99. Sentra caliper paint
  100. Needs GA16DNE Workshop Manual
  101. Need Timing, new head gasket installed.
  102. 2004 Sentra rough start/SES light on question?
  103. 2006 Nissan Sentra, Carmax- 11500 (30k mi) (ripoff?)
  104. For Sale: Turbonetics Spec V turbo kit 04-05 $3400
  105. FS: Turbonetics Spec V turbo kit 04-05!! $3400
  106. 1.6 and 2.0 used in sentra
  107. changing a starter
  108. Power Window Master Switch
  109. Whining sound from Nissan Sentra engine
  110. inop gauges,2000-up
  111. Big problem with my transmission
  112. Lowering Springs Installed
  113. Whether car frame was damaged in an accident when it was hit on the rear bumper?
  114. Where is the oil filter?
  115. odometer and trip meter dont work
  116. change alternator in 95 nissan sentra
  117. rebuilt ECm
  118. 95 200sx when the car warms up smokes?
  119. Looking for info on the VCT system
  120. A/C problem
  121. Canadian Nissan owner: Warranty question
  122. 1997 engine swap
  123. need help....
  124. 03 Sentra GXE Fuel Pump Assembly
  125. Oil light on with full engine oil
  126. '08 Sentra rim sway-what fits?
  127. grinding??
  128. shock installation wowes
  129. what body style is my car
  130. 2002 Nissan Sentra Noise Advice
  131. Head gasket/timing advice
  132. Do all 95 1.6 Sentra's come with the NVTCS?
  133. revs high then back to normal.
  134. B13??
  135. Can anyone provide advice?
  136. Quick Question
  137. blue smoke and a sputter at start up
  138. 2001 Sentra ECM Replacement, What to do?
  139. Sentra 2006 Bearing change
  140. Please help, stumped.
  141. 2008 Sentra
  142. Nissan Sentra intermittent reving while driving.
  143. Exhaust Opinion...
  144. Sporadic Charging Dummy Light - Loose Connection?
  145. fuel gauge not working 2006 sentra
  146. Fuel Pump Relay Location 95 Sentra???????
  147. 1993 Sentra 1.6 Surging
  148. car lock
  149. ** 2006 sentra transmission service **
  150. Upgrading my '93 Sentra XE
  151. Need info. can anyone help?
  152. Front Cranksahft Seal
  153. Dead in the water
  154. ebay turbo spec v
  155. 93 Sentra 1.6 misfiring
  156. New to the site
  157. 2003 Sentra SpecV Brakes
  158. motor and trany swap
  159. 97 Sentra Electrical problem
  160. 2002 Nissan Sentra GXE No heat
  161. se-r spec crankshaft sensor
  162. SR20DE Turbo Manifold
  163. 94 SE-R steering problem
  164. Nissan Newbie
  165. Hoe do i restart computer
  166. Will these tires work?
  167. fans dont turn on.
  168. Fuel Pressure Test Port
  169. Re: Steering problems
  170. nissan sentra
  171. Cooling Problem
  172. 01 sentra air/fuel sensor
  173. 14 inch tires on 204 sentra
  174. Replaced MAF sensor and ODB code still comes out as P0171
  175. 08 Sentra: Good buy?
  176. Want To Wire Alternator To The Battery
  177. '03 GXE Axle Nut Size??
  178. '03 GXE Front Wheel Bearing Question
  179. 89 sentra removing radio
  180. Ignition timing and Distributor Question.
  181. Posting for a friend...couple questions to people who know their SR20's
  182. 2004 Sentra timing belt replacement?
  183. 95 200sx se-r dash lights not working?
  184. oil leak
  185. abs on '05 sentra se 1.8
  186. Help failed smog check, 99 1.6 Sentra
  187. no crank no start.
  188. code
  189. 90 sentra cooling fan not working......
  190. 02 Sentra Speakers
  191. Help, loose hose 99 Sentra, Pictures inside.
  192. Best place to pick up some brake parts
  193. 87 Sentra
  194. ...educate me?
  195. 2001 Sentra jerking problem
  196. 93 sentra problems
  197. Car dies when on idle in the morning.
  198. how do i improve horsepower on 2007 Sentra 2.0?
  199. vacuum hose diagram,00 sentra 1.8
  200. Power Window Relay Help
  201. Cruise Control Not Holding Speed
  202. 2008 Sentra - Larger Oil Filter ???
  203. WTF! My 2000 Sentra Did NOT Pass Smog
  204. Power door lock - defroster - interior lights, Not working =(
  205. car makes white smoke but not overheating
  206. Need help reattaching the side mirror
  207. 96 200SX SE Auto Timing Belt issues
  208. 2003 spec v head bolt torque value
  209. 04 Sentra right front rattle/noise
  210. Wtf?
  211. 99 Sentra engine rotates but will not start
  212. Did Nissan offer a NISMO edition of 2003 Spec V
  213. whistle sound when turn on and off
  214. hydraulic lifters
  215. 93 Sentra charging issues
  216. Flashing O/D light
  217. 96 common a/c problem=??
  218. cut the 96 cat converter=??
  219. Turbo?
  220. Inside Door handle bent
  221. Is this true?
  222. 2006 Sentra Radio Help Sirius Radio Hook Up?
  223. Sentra project
  224. 2004 sentra se-r spec v stalling help!!!
  225. Pilot Bearing Repair - Shop or home mechanic?
  226. Overheating!!!
  227. Window freaking out!!!
  228. 2002 nissan sentra gxe key won't turn in ignition
  229. How can you figure out what CAT is going out?
  230. HELP!!! Sentra 2001 ECU Problems
  231. Gutless 97 GXE, can't figure it out
  232. Gas Grade Question
  233. nissan sentra hard starting
  234. Cruise Control
  235. turbo sentra?
  236. Front end vibration
  237. 91 sentra AT shift issues
  238. Revs Drop and Engine Stalls Out???
  239. An Absolutely Hilarious Story!!!!!!
  240. clutch issues after a 4 wheel replacement and front end alignment
  241. 97gxeMT 1'st gear wont work
  242. Engine Squeal!!!!!
  243. New Sentra SE R torque peak...
  244. Cam gears reverse thread?
  245. 87 Sentra Q:
  246. 92 Sentra Govenor Gear?
  247. head swap?
  248. Wtf!!
  249. Headgasket issues perhaps?
  250. Knocking in front suspension
