Dry Ice For Paintless Dent Removal!!!!
ImportRacer03
05-22-2002, 10:44 PM
Hey, wtup everyone? My question is probably hella stupid, but i figured I would ask. I heard that you can use dry ice for paintless dent removal. If that is true than right on. I have a few dents down my driver side door, and in the hot hot summer if you take dry ice and run it across the dent, the heat and coldness will expand and pop the dent out? Anyone else heard of this? Thanks for the feedback! L8tz!
93speed
05-23-2002, 07:41 AM
Might wanna post in the exterior/bodykits/lighting section. Somebody without a civic might know the answer.
nw h-town
05-23-2002, 08:04 AM
This was taken from www.DryIceInfo.com
-- DENTS & HAIL DAMAGE
Dry Ice will condense metal and thereby shrink small dents on your car. Place the Dry Ice on the inside of the dent if possible. Use heavy gloves and press flat sheet against dent. If it is not possible to get on the inside concave part of the dent, then using heavy gloves hold the Dry Ice so a corner can fit into the bottom lowest part of the cratered dent. Hold the Dry Ice until the metal is frosted at least 2 inches beyond the dent. Let the metal warm up (in the sun is the best) and repeat the procedure. Sometimes the dent will pop out perfectly. More often it will not be possible to get a flat smooth finish, but the dent will be reduced noticeably. Creased metal will still show the crease line but the dent will be far less pronounced. I have not seen any paint damage, but I'm sure if the paint is not strongly adhered, it could peel away.
I don't know if this atualy works... I've heard tht it only works on steel panels... but hell I don't see what it's gonna hurt to try.
dreemkill
05-23-2002, 11:04 AM
hmm, i should try that on my car...i have some dents on my hood and drivers side fender...
http://dreemkill.mine.nu/galleries/wreck/images/P1010005.jpg
liquid8
05-23-2002, 02:19 PM
maybe if you just pour like 300 lbs of it on your front end it will take it out. lol
Jemru
05-23-2002, 02:31 PM
lol!!:D :D :D
sparq
05-23-2002, 02:33 PM
Justin, dude that was hilarious... you can have all my parts though :D
dreemkill
05-23-2002, 10:05 PM
at this point, i can do nothing more than have good spirits about it...........i appreciate all you're offering nickypoo :) ill just have to walk to syracuse to get it....or take the hood off, and drive it w/o one....and duct tape the valve cover shut.... lol
33
