Our Community is 662,000 Strong. Join Us.
View Full Version : '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
  1. 93 DX - Random hesitation/power loss until wide open throttle
  2. hear knock sound from inside car!
  3. Main Relay ??
  4. Blown Head Gasket question
  5. 93 civic shifter problem
  6. Number of labor hours for a job
  7. misfire/spudder
  8. 94 civic dx hatch getting jdm b16a obd0 engine
  9. 93 civic idling problem & carbon monoxide!
  10. 95 civic ex auto trans probs
  11. Canadian 95 Civic Cx D15b7 to D16y8 Swap
  12. 95 civic ex brake light problem
  13. 93 ex coupe only starts when it wants to
  14. won't start when it rains. Please help.
  15. Rear Wheel Bearing
  16. 93 civic broken valve cover
  17. A/C Compressor Clutch Resistance
  18. wife's car wont start
  19. 95 civic EX brake light problem
  20. b16a to b18c4 swap???
  21. b18c Typr R
  22. 1995 Honda Civic Motor Oil Choice!?
  23. tranny
  24. 93 civic rack and pinion questions
  25. Question about air conditioning.
  26. need help (beginner)
  27. what the heckkk, help me out...
  28. 95 EX Air Conditioning Questions
  29. 94 gsr into 92 cx
  30. 93 civic hatch wont go past 30mph??????
  31. front clicking noise. wheel??
  32. rust repar
  33. 92 civic lx
  34. 2007 honda civic k23 vtec problems
  35. I need a top end(d16z6)
  36. Motor swap and now my car wont even go past 25mph
  37. Coilover install Now Car shakes under Accel.
  38. AC Clutch will not engage
  39. 95 civic b series need help.
  40. 95 civic automatic to manual swap ignition prob.
  41. 91 B18A1 swap into a 95 D15B7 Civic Questions
  42. a/c blows cold then warm,why?
  43. a/c blows cold then warm,why?
  44. Looking to purchase new Window Seal
  45. Low compression?
  46. Civic Eg D16z6 head y7 block mini me
  47. Civic Eg D16z6 head y7 block mini me
  48. Civic Eg D16z6 head y7 block mini me
  49. 95 Civic EX Idle Problems. Help ASAP!
  50. Which wheel bearing to purchase?
  51. 1993 civic dx brake light on dash on
  52. at a loss on my 95 civic ex
  53. 95 air conditiner problem
  54. power steering leak
  55. 95 Ex Idle problem?
  56. 95 Civic EX Muffler Question
  57. 92-95 hb cx needs new motor and tranny
  58. 92 civic hatch cluster kit
  59. 94 Honda Civic 1.5 5-speed
  60. Blown Head Gasket 94 EX
  61. quality of timing belts
  62. 95 Civic EX No Start
  63. 95 civic no spark
  64. Shifting gears problem
  65. Loose steering wheel and problems when doing a complete turn
  66. civic vx noise, cant figure it out what is it, help!
  67. HELP ME! swaping d15b7 for d16z6 what do i need?
  68. 95 Civic/ Headlight turns off randomly.
  69. D15y8
  70. Civic vaccum leak or bad engine swap?
  71. A D16z6 head on a d15b2 block...but a9 pistons??
  72. Dash lights intermittent '93 Accord
  73. fuel problems...
  74. 93 civic sedan
  75. 95 wont start
  76. ls vtec project
  77. 93 ex coupe runs for 20 seconds
  78. 93 civic engine swap
  79. b16 into 5g cx hatch
  80. Need second opinion on spark issue
  81. 92 honda civic dx grinding noise in engine
  82. Please Help!!!!!!!!!!!!!
  83. 94-95 civic swap
  84. B16 bottom end with B18 non vtec head?????
  85. check out my civic 4x4
  86. AEM air intake
  87. Need help with overheating engine please
  88. 95 civic air conditioning issues
  89. P14 ECU (Prelude Si '92-'95) in a D16A9
  90. Need help on my civic ex 95
  91. 93 civic noise after tune up/brake job
  92. New Idle problem install of throttle body Spacer
  93. 95 Civic LX trailing arm bushing replacement
  94. 1995 civic lx
  95. need help on d16z5 swap to a 95 civic
  96. Hybrid Water Leak
  97. paint color
  98. please help me! 95 civic ex
  99. Coolent leak
  100. 94 Civic with constant high pitch humming in front end....
  101. hella overheating prob
  102. my 95 civic lx
  103. where can i fnd t?
  104. Puzzling Brake Issue
  105. mini me swap idle problem
  106. Cruise vacuum line on 90s Civics
  107. Honda Civic Hybrid
  108. 95 civic idles rough only when warm.
  109. Which Civic should i buy
  110. 95 civic injectors not firing
  111. 89 Civic with 93 D15B dies when warm.
  112. How to change dsitributor
  113. 94 honda cranks but wont start help please
  114. 95 civic cx engine swap
  115. Air conditioning recharge
  116. Just bought a 95 Civic Sedan
  117. Valve Cover Gasket Problems
  118. 93 civic dx engine size
  119. d16a6/d16z6 minime trouble
  120. 92-95 custom hatch cargo cover
  121. Intermittent wiper in a CX hatch
  122. Honda civic motor swap
  123. 92 Civic Hatchback Problems Help Please
  124. 92 ex timing belt not lining up at TDC (cam pulley/crank pulley)
  125. 93 civic weird idle surge need help
  126. Projector head light with HID
  127. 92 civic sputtering problems
  128. IATS Help?????
  129. 1992 civic w/b18b1 swap.
  130. ecu p30 a010 information
  131. 93civic with mini me swap pleae help????
  132. 94 civic ex not cranking
  133. car pulls to the right...
  134. Cruise control into a civic CX
  135. vtec tranny
  136. Replaced timing belt now no spark
  137. 94 civic dx rythmic pulse
  138. Mechanic said it was a puzzler...... sputter, loss power, check engine light
  139. changed tie rod wheel still shake
  140. 1995 4dr civic 5spd..tie rod
  141. Using tin foil for blown fuse?
  142. 92 2.4l honda civil EX ALARM on DASH
  143. 92 civic dx will not start
  144. 1991 civic, rough idle, jumpy rpm, extreme coolant leak..
  145. Can you raise the compression ratio on a d15b7
  146. '95 DOHC ZC engine idling erratically
  147. need info on engine
  148. 95 civic,with TEC dist.no spark,help
  149. im about to do a engine swap
  150. need info on wich engine swap?
  151. speedometer problem
  152. Engine cranks but won't turn.. I don't understand?
  153. Brakes still squeaking
  154. 1995 Civic coupe door swap
  155. where is the main relay and where do i check the ecu
  156. my engine wont start
  157. 94 civic coupe b16b
  158. Civic 93CX Swap Zc started and stop ... help please...
  159. 95 Civic EX
  160. My reverse keeps grinding!!!!
  161. keeping a/c
  162. 1995 Civic Surge Problem Not FITV or IACV
  163. 93 hatch cx/non v-tec to a 96 1.6 v-tec problem
  164. vehicle speed sensor? help!!!
  165. 95 civic 5speed -tach hook up
  166. Fix My Car!!!!!
  167. 94 civic lx 5 spd problem
  168. 95 5speed swap??
  169. Can I swap a D15B7 for B18A1
  170. What engine is a cheap swap with potential
  171. civic thermostat replaced but engine is still over heating
  172. 94 honda civic
  173. 94 honda civic
  174. 93 Lx Speedometer/Odometer don't work
  175. Intermittent Wipers don't work until pushing key into the ignition switch.
  176. Auto tranny
  177. I have a real gas problem
  178. 94 hatch with 98 integra dash
  179. Suggestions on what to fill my transmission with?, GSR 5speed
  180. No vtec???
  181. B18b swap needed info
  182. hardly running sohc VTEC
  183. 1992 CX Starts and quits after 2 minutes, anyone????
  184. Speedometer stopped working
  185. 1993 Honda Civic Vibration in front end at lower speeds
  186. P28 chip auto trans issues
  187. idk whats wrong...
  188. rad overflow bottle issues...
  189. Indian Civic Hybrid Review
  190. 94 civic LX does not start
  191. which header will fit ls/b18b1 ???
  192. No Acceleration
  193. Hesitation Troubles?
  194. Speedo problem on 94 Civic
  195. Switching LS motor from 92 HB to 95 EX
  196. 95 honda civic tranny problem
  197. 3 rear main seal failures in 1 year
  198. Short Shifter bracket for an eg?
  199. P30 ecu with code 36
  200. 93 DX speedometer problems
  201. d16 headers on a d15 motor
  202. Windows won't roll down
  203. Hatch on Hatch action
  204. Stripped steering wheel thread
  205. Need advice on anti-theft pedal locks.
  206. 1993 civic stater problems
  207. d16z6 keeps throwing an engine code 15
  208. B20 and i want more power
  209. thinking of buying a 1995 civic plz tell me if its worth it
  210. 93 civic busted power steering tank/pump
  211. HELP! Locktronics on a CIVIC
  212. 95 civic wont start
  213. B16 swap tach problems PLEASE HELP...
  214. civic misses at idle`
  215. high idle gas smell
  216. wont rev up!
  217. 94 civic LX stutters
  218. 94' Civic Overheating
  219. 1st gear wants to pop out...only 1st
  220. Rear brake drum and general brake question
  221. 93' civic problems
  222. Dampness on front passenger floor
  223. Stock 95 civic hatchback 4 sale in san diego
  224. Spring Frustration
  225. 95 honda civic ex v-tec
  226. del sol running on 3 cylinders
  227. Are these mounts all I need?, (97 GSR b18c1 into 94 civic hatch)
  228. 02 Sensor
  229. JDM EG From Germany
  230. ECU Problem
  231. Just bought 92 civic
  232. Turn signal doesn't work
  233. CR-VTEC "the right way"
  234. question re Auto Tranny fluid
  235. Engine swap question
  236. is a SOHC ZC worth fixing up?
  237. Spark Plugs Problem.
  238. My Civic 94 EX does not start......please help.
  239. Wtf Tranny Dipstick Is Bent
  240. 92 Civic wont start
  241. 93 5speed need a motor please help
  242. 93 civic 5speed need motor
  243. B16A SiR II Tranny
  244. B20 cylinder walls thicker than H22's?
  245. 92 si ecu code 22? and
  246. Brake enhancements
  247. 92 cx with d16y8 obd1
  248. 95 civic Must push gas pedal??
  249. FRONT END CORE SUPPORT DMG!? HELP! =O pix!!
  250. Help In Buying A Civic
