98 Ford Contour 2.0L 4 cyl
tsgray69
09-01-2005, 03:58 PM
I have a 98 Ford Contour 2.0L 4 cyl. I'm changing the timing belt, which broke, so I have to start from scratch. I can find the alignment for the top back cam gear and the lower crank, but how do I align the front cam gear, do I base it on the back, make sure the cam shafts are in the correct position under the V.C., using the slots at the driver side end of the cams or what?? If anyone could help, it would be very appreciated!!! And if I'll need any special tools?
Thanks in advance, Scott
hobco
09-01-2005, 04:08 PM
you are correct. get a piece of steel that is the same size of the slots andslide it in. it is off set so it will only go one way and rest on the valve cover surface of the head. and by the way i think that is an interferance engine. most likely bent some valves
pre98zetec
09-01-2005, 04:44 PM
you are correct. get a piece of steel that is the same size of the slots andslide it in. it is off set so it will only go one way and rest on the valve cover surface of the head. and by the way i think that is an interferance engine. most likely bent some valvesWrong.
Zetec is a non-interference motor. Belt breaks- replace it.
I know mine is a pre-98 (non VCT) but heres how I do it
First make sure piston 1 and 4 are TDC, (top dead center). You can check this by taking the valve cover off, and spark plugs. and sticking a screw driver in the #1 piston to see if it is TDC, if its not you can either crank the car till it is or you can take a rachet are turn the crank pulley to rotate the pistons, ONLY DO THIS CLOCKWISE.
Next, since the belts off you can adjust the cams. This seems hard and tricky- but its truley easy. One you have them lined up put the peice of metal in the cams to lock them and put the belt on.
your best bet is look at a manual for the car, it will tell you how to replace it step by step. I can't help you much because changing my timing belt and changing your timing belt are two different things, they are totally different.
EDIT: heres a how to I found, should prove to be very useful to you
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=zetecmaint&Number=746298&Forum=zetecmaint&Words=post%2098%20&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=739483&Search=true#Post746298
knockerccd
10-28-2005, 10:46 PM
If you have the Zetec engine...the one with the VCT(Variable Camshaft Timing) system, it's almost mandatory that you will have to read the Ford TSB(technical service bulletin) number 98-9-8 thoroughly! It is very thorough concerning proper timing belt replacement procedure while it's explaining replacing the VCT Solenoid. Other Ford TSB's related to the issue are 00-3-7, 99-25-4 and 03-15-14.
For those new to what TSB's are-they are simply pieces of information released from the manufacturer concerning proper replacement procedures and unique and helpful pieces of information specific to a particular make and model...even engine size of a vehicle. You can learn alot from them. I have.
Regarding any special tools...you will need an e-20(reverse torx) socket to loosen the exhaust camshaft sprocket from the camshaft after the oil plug cover is removed from the exhaust camshaft sprocket(this is an special oil & spring filled sprocket!). I don't have the e-20(reverse torx) socket, so I sufficed by using the snuggest fitting 12pt. socket(use standard not metric...standard fits ever so slightly better)-I forget the exact standard 12pt. size...so you'll have to test fit over the e-20 torx camshaft sprocket bolt head to get the best fit.
Also purchase an 24mm open end wrench to hold the lugs ground onto
both of the camshafts to keep them from turning while you loosen the
sprocket bolts one at a time. Ford TSB 98-9-8 shows where these lugs are located or you can see them yourself once you get the valve cover off.
I'm subscribed to this thread so if anyone needs any more help just post! And I'll get back asap.
p.s. Sk8tr is right it's an non-interferance engine...no bent valves! :p sorry Hobco :uhoh:
zx2srdotnet
10-28-2005, 11:01 PM
why read it?
i know many of people that have done the belt and not read it
~manuel~
10-29-2005, 04:39 AM
i believe he is trying to replace the timing belt only.so he will not have to loosen any cam sprocket from the cam.i suggest purchasing a manual such as haynes as they tend to have pretty good illustrations. there are indeed special tools that are necessary to align the the cams.and there is also a special crank alignment tool which basically looks like a special bolt which threads into the side of the block near the exhaust and acts as a "stop" in order to get #1 at true TDC compression.although this is not a necessary tool, you do need some sort of cam alignment tool.and i just finished my training on "servicing OHC engines" for FORD. according to the service information the only belt driven ford engine that is an "interference" engine is the Zetec found in the SVT version.and all OHC chain driven engines are interference engines.but this info doesnt account for the belt driven SHO's and markets other than North America.
Swine70
02-28-2007, 06:30 PM
for some reason i can't make a new thread...
anyways.
mother inlaws car died, it's a 1999 (se model i believe) mechanic said timing belt/chain and that it caused 2 bent valves. it's the inline 4cyl. motor. is it worth the $750-$850 that he is wanting to charge her? she can't offered to get a new or even used car right now.
i thought this was a "non-interference" engine. are there 2 4 cyl. engines?
Jason43
02-28-2007, 10:12 PM
Sounds like your mechanic is either raping you or is clueless. Either way, I'd get a second opinion.
Swine70
02-28-2007, 10:36 PM
indeed.
i'm gonna have to get over there and see what has been done i guess.
and it's an Lx model
beyondloadedSE
03-01-2007, 12:13 AM
only one 4 cylinder used in the contour. And yes, it is a non-interference engine. Id take it somewhere else.
mh1205
06-15-2007, 10:29 PM
hi,
i am in the process of changing timing belt also on 1998 contour se 2.0 dohc vct. i had a tb go bad due to shredded worn guide pulley. i have replaced the cam positioner sensor, waterpump, 2 idler pulley's, tensioner pulley, and belt. set everything tdc and stalled, belt jumped before i got to the neighbors driveway. made tension adj. as told on the bracket and so on. compression is 100-110 on all 4. what is making this belt jump. and where can i find this vct silenoid it does not show it in the haynes. thx for any help.
mh1205
1998 contour se 2.0 vct dohc
1998 contour se 2.0 ztec dohc
4thmessenger
07-21-2008, 09:36 PM
I just changed out a shredded timing belt on 99 contour due to bottom idler siezed up. Got it back together and started first time and idles good. Under load it runs erratically and logs 0340, 1380, 1381, 1383 - the whole show. TSB 03-15-14 suggests that the wrong oil or filter can cause this and I do not know how the car ran prior to the shredded belt. Going to change the oil and put on the FL 2005 filter. Any suggestions?
Rich Maupin
08-18-2008, 11:56 AM
p.s. Sk8tr is right it's an non-interferance engine...no bent valves! :p sorry Hobco :uhoh:I am new to this site, could you please direct me to more information about the VCT unit specifically on how to eithor fix it or replace it. My e-mail is maupin.rc@pg.com. Thanks Car is a 99 contour with vct 2.o liter
hammerdn5
05-05-2009, 01:42 PM
does anyone know where to find technical service bulletin 98-9-8, online. I'm having this problem and am looking for some info on this..
jwitte596
05-03-2010, 01:24 PM
I just got done tearing the motor down and I am now ready to reassemble the motor, but I have no torque specs for this motor. I got the 2.0 Zetec VCT motor, its in a 1997 contour but I am pretty sure after doing some research that the motor is a 1998. I also am clueless as how to time this motor??? Can someone help please?? Thanks!!!!
braddog
06-29-2011, 08:12 AM
OKAY in all of the posts I have found NONE of them actually say HOW to remove the camshaft. They all talk about the belt and gear.
The problem I have is that I have removed all of the cap bolts but the cam still will not lift out of the head. There is a piece that is wrapped around the front of the cam that has the VCT solenoid attached to it.
I removed a 6mm bolt from the front of the head but it still will not budge.
How does it come out?????
danielleNJay
07-29-2011, 09:23 PM
I have 98 Ford contour . It is idling rough , and cutting off when it is idling. You have to keep your foot on the gas to keep it running. We have replaced the alternator, plugs wires, battery, timing belt ,fuel filter ,and pulleys . Please someone help me.
Dano1956
08-10-2011, 11:02 PM
Did the problem start after changing the timing belt?
I just changed the timing belt on a 99 Contour 2.0L DOHC engine. I did it the too quick way and somehow ended up having the exhaust camshaft 1 or 2 sprocket teeth advanced.
It ran fine above idle with plenty of power but had problems just as you described above, occasionally I'd get a check engine light as well.
I had to take it all apart again and do it the right way....now it runs fine.:cool:
The engine had stalled on the freeway due to the lower idler pulley being cracked which resulted in a loose timing belt.
Dan :cool:
sic777
12-19-2011, 02:37 PM
hi, im having trouble with the vct on my 98 ford contour lx hybrid. It is making a excessivly load noise and car reads no oil even though i did an oil change and its not leaking oil. any thoughts on how to fix this problem would be helpful.
