how to program remote?
Vasilyzhuk
03-31-2004, 07:39 PM
does anyone know how to program the remote for 2001 i30??????
spotco2
06-08-2004, 12:52 AM
Here is a link to the programming procedure
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=33723&item=2479233773
LockNTross
06-11-2004, 06:53 PM
The 1996 re-programing for the keyless entry works like this:
To enter the ID code, follow this procedure.
Close and lock all doors.
Insert and remove the key from the ignition more than six times within 10 seconds . (The hazard warning lamp will then flash twice.)
At this time, the original ID codes are eliminated.
ID code entry:
Turn ignition key to "ACC" position.
Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered).
At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock knob.
Push lock button on the additional new remote controller once.
This ID code entry enable state and setting mode remain until the driver's door is opened. NOTE:
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
ID code entry:
rlarn
07-05-2004, 09:05 PM
Do the same instructions apply to a 1998 Infiniti I30? I have one remote but would like to purchase another one. Thanks!
ZmanAZ
08-10-2004, 02:36 PM
Same instructions should apply on most late model Nissan / Infiniti products.
This is from the 2002 Altima shop manual:
Programming Instructions from the Nissan/Infiniti Factory Shop Manual
First, for entering "Setting mode": (1) Close and lock all doors. (2) Insert
and remove the key from the ignition more than six times within 10 seconds.
(The hazard warning lamp will then flash twice.) At this time, the original
ID code entry: (3) Turn ignition key to "ACC" position. (4) Push lock
code can be entered). At this time, the new ID code is entered. (The hazard
Additional ID code entry (5) If you need to activate additional remote
(6) Push lock button on the additional new remote controller once. (7) This
ID code “entry enable state” and setting mode remain until the driver's door
is opened.
NOTE
Some people may find it tricky to get the system into "setting mode"...if you
don't get it at first, keep trying.
controller. If the same ID code that exists in the memory is input, the hazard
warning lamps will flash twice but the entry will be ignored. Entry of
ignored. Any ID codes entered after termination of the "setting mode" will
If you still are having difficulty, try changing the battery...just open the back
remote. Also, keep in mind
that your local dealer may program it for free or for a small charge. Be sure
you bought the correct remote that applies to your car...and of course, be
sure you car is equipped with keyless entry and the “brain” computer is
functioning properly. Thank You!
is opened.
NOTE
spotco2
09-01-2004, 02:01 AM
There are 9 different programming procedures for Infinity.....
Here is the correct procedure for I30 & I35
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=33723&item=7911969091
