Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Nissan
> Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
96 i30t need to fix speedodmeter
No 3rd or 4th gear - MAXIMA 00
cefiro 98 remote not working
1999 nissan maxima
2001 maxima revs up and down in park?
Maxima - I30 Headlights
Which oxygen sensor to replace?
Windshield wipers stopping
I30 catalytic converter question
anybody selling a cold air intake for a 3.0 maxima?
94' Maxima won't start - NATS??
We Help you save money by doing the job your self ..http://www.diyorg.com
1998 Nissan Maxima Not Cranking
2000 Maxima p0740 code; about how much to have fixed?
99 Nissan Maxima locked diff or not
Need help with P0100/P0325 codes
'99 Maxima engine light
2001 maxima 5spd rebuild info?
what should i get for my 2009 Maxima
3 Codes Which Sensor could it be?
06-Maxima won't start. Please help good people!
96 Maxima - Occasionally dies while driving
Location of egr valve?
03 maxima won't start
A/C Smell
Looking for mechanic for my 96 maxi
2002 Maxima spare tire size
Uneven cranking, rough start, then ok.
I30 problem
1985 Nissan Maxima - 3.0 Liter V6 - Many issues - Need HELP!
Trouble with car jerking
95 maxima surges
Rear rotor removal
97 nissan maxima don't start
97 nissan maxima
Fuel filter; I-30
Untraceable Current Draw on 96 i30
Headlights for 95 nissan maxima GXE 4dr sedan manual
Changed battery on I 30 after it died and does not start
3.5L engine
1999 Nissan Maxima SE upgrade help please
About to buy an '02 I35... I have questions..
Tbl with 2002 Nissan Maima CEL!
2001 Sounds?
2000 Door Accuator replacing??
96 Maxima - rough idle only when first started and cold
Car Starting problem
Interested in buying 96 Maxima...opinions??
'94 Maxima - Display lights out
1996 Infiniti I30 starts but won't stay on!!!
2001 infiniti i30t coolant is spraying
Noise after repair
1995 Nissan Maxima starter
Which maxima did I get
charging help
1999 infiniti i30 remote
Can I add AUX input on 06 Max sl
light black soot on rear bumper
Whirring under hood when ignition turned on.
95 Maxima no spark no start. Cranks fine
1991 Maxima rattling/thumping
What's this sound like to you (video)? Tranny?
2006 Maxima Timing Chain Tensioner Issue
04 maxima po726-po345 limp mode loses 3rd gear any help apreciated
01' Infiniti I30 blown radiator
Air Conditioner
Rear Shock Replacement
2001 Nissan Maxima A/C Issues
engine quits after throttle snap 2000 Maxima
Snap ring/Drum assy-reverse clutch
engine misfire on Maxima 99
00 Maxima Dies after 45 min of driving
1995 Nissan Maxima Won't Start
1992 Nissan Maxima
My car got stolen, then recovered but guy still has my key
Short ram air intake for 2002 Nissan Maxima?
question about aftermarket vtc sprockets for a 92 maxima
Knock sensor
Noise when reversing after car idle for few hrs
95 Maxima coolant leak
'96 maxima driver door won't open
04 Maxima Radio Bezel Removal
Dome light question
day time running switch
04 maxima sl fuel smell in car
Thinking about buying a 97 Maxima
01 Cefiro VQ30DE - Gearbox Problem?
03 Maxima ground strap
92 Nissan se maxima making motor noise
92 maxima power lock problem
92 maxima se problems starting
1996 crank shaft/s-belt need serious help!!!
94 maxima no fire on 2/4/6
93 Maxima Runs rough...Help Please
Weird Little noise at 2K RPM when Throttle Released
01 Maxima OBD II plug location?
'01 no start, batt ok,starter ok,batt term ok
car dies and starts right back up
Does a red (not burgandy) 02-03 maxima exist?
Need some advice.. Maxima newbie..
V6 Max Water Pump
Headlight Haze
whirling noise from pass side of engine
2004 maxima rattles on acceleration
Throttle Position Sensor/Throttle Body
Accelerator sticking in reverse on 2006 Maxima
Low whining when going in reverse... transmission?
nissan 89 maxima
04 Nissan Maxima coil packs
thermostat issue
Lower Radiator Support problem - RUSTING
Need to remove backseat side back rests on 2004 I35
95-99 Maxima Battery Cables
Climate Control Lighting
1996 I30t Wont Start..... Help
'96 Infiniti I30 will not start!
Panel illumination Nissan Maxima
Windows & Locks
2004 Maxima Bucking
'01 Max cruise control problem...
Serv. Eng. "mystery"
FS 1995 Nussan Maxima owners manual
rear strut mount issues on 2001 infiniti i30
05 maxima brake problem
need ignition coil and tune up advice
My GLE Maxima needs serious work :(
Help!!!
Strut & Shock Mounts
Help with Suspension for 2000 I30
Fuel Filter Replacement in a 2001 Maxima
Strut problem
Nissan Cefiro - Idling/driving rpm problem
P0455 and P1448 Codes, please help.
Front Wheel is coming off
Electronic engine mounts
95 maxima code p0443
95 maxima , passanger window don't go up
86 nissan maxima idling issue - please help
Couple of Problems
More info
noise /vibration 30/40 mph
Help w/ 2000 Maxima...
99infiniti i30
HELP Car overheating
Service Manual for Nissan Maxima 2000 GLE
Stumble when accelerating
I have no idea
fuse boxes
door pannel removel
Mechanic screwed my car and now unable to fix
Cefiro '89 Air Flow Meter Wiring
2K Maxima Engine Light On but no code found
Engine Whinning
Battery and Brake Light On, Replaced Alternator Last Saturday? (Nissan Maxima 97 GLE)
2000 Maxima Reverse Wire Location
87 Maxima lack of power
Had battery charged now won't crank!
Gas Smell in Cabin
radio when on makes a strange sound
engine makes screaching noise at startup and stalls
95 maxima timing chain
Need a new rim for 2001 20th anniversary max
1992 Maxima automatic transmission problem
Electrical problems.
93 Maxima, not starting
Replacing rusty rocker panels?
Rattling Noise When Accelarating Maxima
Air Bag light Blinking
Lights Dim
1995 Nissan Maxima V6 Runs/Dies
2004 Nissan Maxima Fog light fuse
2001 Maxima rear brake rotor removal
95 maxima car alarm randomly goes off
95 max fuel pump relay location
95 max battery getting drained
97 maxima front noise
1999 I30 Chugging and stalling
96 Maxima - Keyless door lock- Windows go down?
96 Maxima, Hard Starting WHY??????
What makes a maxima a maxima
1998 maxima front and rear speakers
97 maxima radio plays sound but no light
advice on 2000 maxima...
1989 Cefiro
windows go down no key no command..
LoLOMGWTFBBQS!
Service Engine Soon light came on
Brake and +- light on infiniti 01 i30 (91k miles)
Balljoints
2000 Infiniti I30 front end noise
CV Boot
Looking for '97 Maxima interior parts.
1996 Maxima runs rough and stalls
How good are ceramic brakes?
96-00* Max Questionable?
96 GLE/Front-end collison/Remote entry not working
INFINITI or Maxima rear lip Spoiler for I35?
air conditioning problem
First Drive: 2009 Nissan Maxima
Acceleration whistle: '03 Maxima
1995 max cranks but won't start
Passenger side key code
my Maxima Car (middle east)
All brake lights dont work- 96 max
Your opinion about this idea please!!!!!! And any tips you would like to give me.?
Alternator Output
99 I-30 with lots of miles--Please Help
No Engine Light
impossible to remove cd player
Whining Sound
max probs
Changing brakes soon, what kind would you recommend?
Should I do this with my 98 Maxima?
95 maxima DTC 0407, hard to start, kicks back
Metal noise when bump (sometimes)
out of control window
Change oil and brake
Transmission Filter
Is this true?
How do you know when to check...???
96 Nissan Maxima code p0734
How to suit up '00 Maxima
2000 Nissan Maxima w/ 77K miles for $5,500 a good deal?
Brake Guide Pins - 99 Maxima
89-94 VG30E Maxima...Performance Parts?
No Eletrical power till Engine Starts
95 Maxima slow and no power
Help With Several Check Engine Codes - WEIRD!
96 Infiniti I30 Pulling
OEM Car alarm keeps going off
'98 Maxima Giving problems
Metallic Popping Noise on Sharp Turns
jumper wires get hot and spark
Fuel Light
Metal noise when turning sharply to the right
Rough idle in gear 99 maxima
2009 Maxima
97' Maxima woes...
'98 Maxima rough idle, hard starting.
99 maxima engine starts for a second or 2 then shuts off
Headlights Stolen!
Locking or non-locking differential
MAF sensor question - 2000 Maxima
Problem with windows and locks
2003 Maxima GLE parts car... many parts for sale
Bad Front Engine Mount?
Car Is Making Weird Noises
Automotive Network, Inc., Copyright ©2012
