Program keyless remote-Need instructionstslater 08-09-2003, 02:49 PM Hello everyone; I just bought a 2001 4Runner LTD. It came with only one remote & I'd like to buy an additional one. I was checking listings on ebay & some come with programming instructions and some do not. Don't totally trust their claims & would feel better if I had instructions from another source. My remote has 3 buttons on the front (lock, unlock & rear window) with a red panic button on the back. The FCC ID # is HYQ1512Y. Thanks in advance for any all help.:wink: daffy_duck-010 04-17-2004, 05:19 PM The dealer was happy to give it to me so here is the procedure. let me know if it works. (Camry 02 and 03) 1. Driver door open and unlocked. Key out of the ignition 2. Insert the key and remove 2 times in 5 sec. 3. Close and open driver door 2 times in 40 sec. 4. Insert the key and remove it again from ignition. 5. Close and open driver door 2 times in 40 sec. 6. Insert the key in ignition, 7. Close the door, 8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”) 9. Remove the key 10. Power lock will cycle to confirm 11. For add or rewrite mode within 40 sec of the confirmation, A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds. B. within 3 sec press “Lock” button for more than 1 sec and release. C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice. 4Runner Instructions I have a 1999 4Runner and I followed the directions above (which I've copied below) with one exception. In step 8 -- I held the lock button instead of the unlock button in order for the directions to work. Step 1 - open drivers side door and get in your vehicle. Step 2 - put key completely into ignition,then pull out. Step 3- with door open, lock and unlock 5 times on door console (ten clicks total). Step 4 - close door then open door. Step 5 - lock and unlock 5 times on door console (ten clicks total). Step 6 - put key completely into ignition then turn to the on position then pull key out (you will now hear the door locks lock then unlock a couple of times) Step 7 - now quickly press the lock and unlock buttons at the same time only for about a second. Step 8 - then quickly press the lock button for just a second. Step 9 - exit car and close the door After you do this you should hear a beep then your lights will flash. This will indicate that your remote is programmed to your vehicle. forerunner_fixer 04-26-2004, 07:40 PM hey i have a 98 four runner sr5 it has eletric door locks and i got remotes off of ebay . when i looked uner the drivers seat it has a s1000 vip alarm system from toyota it has no green button on the box and i cant find anything any where to program the remotes i brought i have tried the listed reprograming instructions but i cant get it to work. help!!!!! Brian R. 04-26-2004, 09:32 PM Green button may be inside a small hole. FourKix 05-05-2004, 10:13 PM I purchased a 03' Toyota Keyless transmitter but I can not program or find the instructions for programing the transmitter. The dealer wants to charge me $80 for programming (No Way) Actualy they said "$140 for remote, $80 to program remote, and another $60 for key". That was $280 for ONE new remote and key! Belive me, I told them they were out of their mind to charge that much. I wanted 2 keys made but I was not going to paid over $500 for a set of keys. I now have the new parts but I need help with programming. Can someone please help? Thanks in advance for your reply! :smile: FourKix 05-05-2004, 10:54 PM I purchased a 03' Toyota Keyless transmitter but I can not program or find the instructions for programing the transmitter. The dealer wants to charge me $80 for programming (No Way) Actualy they said "$140 for remote, $80 to program remote, and another $60 for key". That was $280 for ONE new remote and key! Belive me, I told them they were out of their mind to charge that much. I wanted 2 keys made but I was not going to paid over $500 for a set of keys. I now have the new parts but I need help with programming. Can someone please help? Thanks in advance for your reply! :smile: :iceslolan Hey everyone, I solved my own issue (I like it when I can do that). If anyone needs codes for 95' - 03' Toyota Avalon, Camery, Celica, Corolla, Echo, 4Runner, Highlander, Matrix, Prius, Rav4, Sequoia, Sienna, or Solara I have most of these (they all use 1 of 4 different codes). I will try and post all 4 codes some time but not tonight. It's late and there is to much info to list. Maybe I will just post info on my personal web site and give you all the link. I have a hard copy at the moment. If you need remotes, check here: http://cgi6.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewSellersOtherItems&userid=mykeyless&include=0&since=-1&sort=3&rows=50 I bought mine from this person and it was new and all original Toyota keyless remote at a fraction of the dealer price and worked great! He will also send you programming information. Take Care Everyone! :sunglasse toyavalon 06-22-2004, 02:14 AM Do you still want to post the code? I have the same proplem as you did and still can not program my remote. thanks for your time. Hien 2000Avalon 08-12-2004, 02:35 PM I have the same challenges! My 2000 Avalon remote needs programming as well. After buying a new battery and remote still does not work, the dealer suggested I purchase another remote ($80) and have them program it (another $24.50). They are crazy! Some one, anyone with instructions for programming ...HELP ME PLEASE ! :)- my email is: iprazgd@yahoo.com albertnpat 09-13-2004, 12:08 AM Hi I am need of some help if anyone has the keyless programming instructions for a 1999 Camry. Please contact me, I just returned from Iraq and I am in need to program a new remote. you can reach me at alberto.sierra@us.army.mil thanks Brian R. 09-13-2004, 12:21 AM Here is a way for programming a remote for a 2000 Avalon. This method should work for 2001 Avalon also. Key out Driver door open and unlocked Insert key into ignition and pull out Lock then unlock the power locks from the master switch 5 times Close and then open the driver's door Lock then unlock the power locks from the master switch 5 times Insert the key into the ignition and turn to ON then OFF, then remove key Locks should cycle - If they don't repeat Press both the LOCK and UNLOCK buttons on the remote simultaneously for 1 second Immediately after letting go of the two buttons, press the LOCK button for 2 seconds The locks should then cycle once. If they cycle twice, try again. Close the driver door 2octops 09-13-2004, 12:38 AM Hi I am need of some help if anyone has the keyless programming instructions for a 1999 Camry. Please contact me, I just returned from Iraq and I am in need to program a new remote. you can reach me at alberto.sierra@us.army.mil thanks This is an oddball.... Remove key from switch Disconnect electrical connector from door mirror adjustment switch Jump pins 2&10 in connector Door locks will cycle Press a button on remote Door locks will cycle If you have another remote, press any button on it door locks will cycle Remove jumper Entering programming mode erases all previously programmed remotes A maximum of 2 remotes can be programmed to a car. Brian R. 09-13-2004, 12:40 AM For an addition to daffy_duck-010 post, his 4Runner instructions will also work for '99 - '03 4Runners, '00 - '01 Camrys, '01 - '03 Sequoias, '99 - '03 Siennas, and '99 - '03 Solaras. His '02 and '03 Camry instructions will also work for '02 and '03 Avalons, '00 - '03 Celicas, '03 - '04 Corollas, '00 - '03 Echos, '01 - '03 Highlanders, '03 Matrix, '01 - '03 Prius, and '01 - '03 Rav4s. Brian R. 09-13-2004, 12:47 AM Hello everyone; I just bought a 2001 4Runner LTD. It came with only one remote & I'd like to buy an additional one. I was checking listings on ebay & some come with programming instructions and some do not. Don't totally trust their claims & would feel better if I had instructions from another source. My remote has 3 buttons on the front (lock, unlock & rear window) with a red panic button on the back. The FCC ID # is HYQ1512Y. Thanks in advance for any all help.:wink: Follow daffy_duck-010 post for his 1999 4Runner - should work for yours also. Brian R. 09-13-2004, 01:14 AM Here's a confirmatory link for daffy_duck-010's post: http://www.geocities.com/toyota_speed2003/keyless_entry.html navydave 11-10-2004, 04:57 PM Thanks, Brian R. I just tried your instructions and it does work for a 2001 Avalon. It's amazing how simple it is yet the dealer wanted $50 to do it. sg1021 11-12-2004, 02:02 PM http://files.automotiveforums.com/gallery/watermark.php?file=/500/87736spamcratej.JPG No spam allowed Hypsi87 nflmvp 02-21-2005, 02:12 AM Can anyone help me with programming instructions for a 2001 Toyota Sienna keyless remote? I see some programming instructions for other Toyotas but I don't know if any of them will work on a 2001 Sienna. Any information would be greatly apreciated. Thanks! Steve Onblsht 02-21-2005, 06:36 AM Do you have the RS3200 system (remote has LED light on top) or the factory system (no light on remote)? 2octops 02-22-2005, 12:15 AM Spotco2 on a very popular auction site has all of the Toyota programming procedures in his store, but I do not want to post a link for fear of being banned :( 2octops 02-22-2005, 12:19 AM Can anyone help me with programming instructions for a 2001 Toyota Sienna keyless remote? I see some programming instructions for other Toyotas but I don't know if any of them will work on a 2001 Sienna. Any information would be greatly apreciated. Thanks! Steve Spotco2 on a very popular auction site has all of the Toyota programming procedures in his store, but I do not want to post a link for fear of being banned :( dwooz 02-24-2005, 09:36 AM I am in need of instructions to program a remote entry for a 1996 4runner.......can I use the same instructions as the ones listed for a 1999?? thanks, david nflmvp 03-07-2005, 09:45 AM Can anyone help me with programming instructions for a 2001 Toyota Sienna keyless remote? I see some programming instructions for other Toyotas but I don't know if any of them will work on a 2001 Sienna. Any information would be greatly apreciated. Thanks! Steve Thanks for the responses. I found a OEM remote w/programming instructions on ebay for $17 INCLUDING S&H. That's about 88% cheaper than what the dealership wants to scam out of me. Hhuerbin 03-29-2005, 03:09 PM I thank you for the programming instructions for my 99 4runner. I ordered a new transmitter off Ebay and saved close to $200 from my local dealer. However my problem now is that if I lock the vehicle w/ the transmitter and open the door w/ a key the alarm goes off. Is this normal? How do I program the security system to recognize both the remote and key? C_Haf 03-30-2005, 07:28 PM Is there a way to de-program a remote. It now works for two 1999 4runners in the area. I tried to remove the battery but that did not de-program the remote. Is that some thing that removing the battery on one of the cars will solve or is it in the remote it self. fishepa 04-14-2005, 06:35 PM I have a 2004 4Runner and I have tried all the instructions on here and none of them have worked. Does anyone know of any instructions that actually work? Thanks fishepa 04-15-2005, 12:16 PM Nevermind, I found some that work. JDeL 05-26-2005, 09:53 AM [QUOTE=daffy_duck-010]The dealer was happy to give it to me so here is the procedure. let me know if it works. (Camry 02 and 03) 1. Driver door open and unlocked. Key out of the ignition 2. Insert the key and remove 2 times in 5 sec. 3. Close and open driver door 2 times in 40 sec. 4. Insert the key and remove it again from ignition. 5. Close and open driver door 2 times in 40 sec. 6. Insert the key in ignition, 7. Close the door, 8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”) 9. Remove the key 10. Power lock will cycle to confirm 11. For add or rewrite mode within 40 sec of the confirmation, A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds. B. within 3 sec press “Lock” button for more than 1 sec and release. C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice. 4Runner Instructions I have a 2000 4Runner and I followed the directions above and it worked flawlessly! Thanks to you folks I saved a good amount of money X 2. Mine and my wife's. Both remotes batteries died at roughly the same time. Again, Thanks so much for the instructions! Jim in Lexington, Kentucky atombob 06-01-2005, 03:15 PM Here's a confirmatory link for daffy_duck-010's post: http://www.geocities.com/toyota_speed2003/keyless_entry.html I just went there to help a buddy program his remotes and noticed they updated and moved the site to here: Toyota Security System Programming and Installation instructions (http://toyotasecurity.buypartsonline.biz) Great site, thanks all for the help. :) Madan 08-16-2005, 01:30 PM Hi Brian, I am looking for 1999 Toyata Camry LE Remote Programming Instructions. I would appreciate your help in this regard. Thanks very much in advance. Madan Here's a confirmatory link for daffy_duck-010's post: http://www.geocities.com/toyota_speed2003/keyless_entry.html Ranga 12-02-2005, 08:16 PM I have a 97 Camry LE and I need the programming instructions. I bought (2) BAB237131-022 REMOTES ,from a local workshop, but there are no instructions. Someone suggested that I try locating the ECU under the seat. There is no ECU under the seat. Thanks :iceslolan Hey everyone, I solved my own issue (I like it when I can do that). If anyone needs codes for 95' - 03' Toyota Avalon, Camery, Celica, Corolla, Echo, 4Runner, Highlander, Matrix, Prius, Rav4, Sequoia, Sienna, or Solara I have most of these (they all use 1 of 4 different codes). I will try and post all 4 codes some time but not tonight. It's late and there is to much info to list. Maybe I will just post info on my personal web site and give you all the link. I have a hard copy at the moment. If you need remotes, check here: http://cgi6.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewSellersOtherItems&userid=mykeyless&include=0&since=-1&sort=3&rows=50 I bought mine from this person and it was new and all original Toyota keyless remote at a fraction of the dealer price and worked great! He will also send you programming information. Take Care Everyone! :sunglasse 2octops 12-03-2005, 01:58 AM I have a 97 Camry LE and I need the programming instructions. I bought (2) BAB237131-022 REMOTES ,from a local workshop, but there are no instructions. Someone suggested that I try locating the ECU under the seat. There is no ECU under the seat. Thanks I have all of the procedures for about every vehicle on the road. Please send me an e-mail at dougcorley@hotmail.com for more info. 2octops 12-03-2005, 01:59 AM I have a 97 Camry LE and I need the programming instructions. I bought (2) BAB237131-022 REMOTES ,from a local workshop, but there are no instructions. Someone suggested that I try locating the ECU under the seat. There is no ECU under the seat. Thanks The procedure for the ECU under the seat is not the correct one for a 97-99 Camry. Ranga 12-04-2005, 04:13 PM The procedure for the ECU under the seat is not the correct one for a 97-99 Camry. Does anyone know what the procedure is? I looked for the purple wire in the mirror switch, but it was not there, I tried the procedures given for the 2002 camry, but they dont work. Please help. Thanks, Ranga. Onblsht 12-04-2005, 06:50 PM Ranga, The 97-99 Camry "purple wire" instructions are for the factory GQ43VT7T remote. If you have the BAB237131-022 remote for the dealer or port installed system, the instructions are different. Are you sure you have the correct remote for the car? bzman 12-30-2005, 09:44 AM Hey, I know it's been a while since you offered to post toyota transmitter reprogram codes, but I have a 1997 Avalon and just bought two new transmitters from wireless and the program instructions deal with resetting the security ECM and I have spent 2+ hours tearing apart the dash to no avail. I tried jumping the light warning module in the trunk with no luck. So, if you could post the procedure for my avalon it would be great. Thank you :iceslolan Hey everyone, I solved my own issue (I like it when I can do that). If anyone needs codes for 95' - 03' Toyota Avalon, Camery, Celica, Corolla, Echo, 4Runner, Highlander, Matrix, Prius, Rav4, Sequoia, Sienna, or Solara I have most of these (they all use 1 of 4 different codes). I will try and post all 4 codes some time but not tonight. It's late and there is to much info to list. Maybe I will just post info on my personal web site and give you all the link. I have a hard copy at the moment. If you need remotes, check here: http://cgi6.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewSellersOtherItems&userid=mykeyless&include=0&since=-1&sort=3&rows=50 I bought mine from this person and it was new and all original Toyota keyless remote at a fraction of the dealer price and worked great! He will also send you programming information. Take Care Everyone! :sunglasse Chris P 10-05-2006, 05:51 AM Hi folks not sure If I am doing this right. First time - anyway I need the programing instructions for the remote entry for my 2000 Avalon. I have read the instructions posted. Only problem is that My car is in Australia and only has one button on the remote labelled "Doors". I am hoping it is an older or different version of something delivered in the US. Failing that if there are any Aussie readers who could help I would be greatful nhatkientanh 03-06-2007, 01:06 PM Is there a way to de-program a remote. It now works for two 1999 4runners in the area. I tried to remove the battery but that did not de-program the remote. Is that some thing that removing the battery on one of the cars will solve or is it in the remote it self. In step 8 of JDEL section. You need to switch ignition ON and OFF for 5 times to erase all registered codes. becerrda 05-20-2007, 05:21 PM The dealer was happy to give it to me so here is the procedure. let me know if it works. (Camry 02 and 03) 1. Driver door open and unlocked. Key out of the ignition 2. Insert the key and remove 2 times in 5 sec. 3. Close and open driver door 2 times in 40 sec. 4. Insert the key and remove it again from ignition. 5. Close and open driver door 2 times in 40 sec. 6. Insert the key in ignition, 7. Close the door, 8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”) 9. Remove the key 10. Power lock will cycle to confirm 11. For add or rewrite mode within 40 sec of the confirmation, A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds. B. within 3 sec press “Lock” button for more than 1 sec and release. C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice. 4Runner Instructions I have a 1999 4Runner and I followed the directions above (which I've copied below) with one exception. In step 8 -- I held the lock button instead of the unlock button in order for the directions to work. Step 1 - open drivers side door and get in your vehicle. Step 2 - put key completely into ignition,then pull out. Step 3- with door open, lock and unlock 5 times on door console (ten clicks total). Step 4 - close door then open door. Step 5 - lock and unlock 5 times on door console (ten clicks total). Step 6 - put key completely into ignition then turn to the on position then pull key out (you will now hear the door locks lock then unlock a couple of times) Step 7 - now quickly press the lock and unlock buttons at the same time only for about a second. Step 8 - then quickly press the lock button for just a second. Step 9 - exit car and close the door After you do this you should hear a beep then your lights will flash. This will indicate that your remote is programmed to your vehicle. I just used this programming on a new (free) remote and it worked. Thanks for posting this so long ago HelpSearch 05-31-2007, 10:11 PM Here's a confirmatory link for daffy_duck-010's post: http://www.geocities.com/toyota_speed2003/keyless_entry.html Hi Brian, Do you have the page for the 2001 4runner? can you please help? Onblsht 05-31-2007, 10:46 PM The 2001 4Runner with remote FCC # HYQ1512Y uses the same instructions as the 1999 4Runner in the above post. Brian R. 05-31-2007, 11:24 PM becerrda 06-01-2007, 10:12 AM Hi Brian, Do you have the page for the 2001 4runner? can you please help? the remote i used came from a total 2004 4runner. it worked after a couple of attempts. But i clicked on the unlock and lock a total of 12 times. HelpSearch 06-01-2007, 09:51 PM Does anyone know the battery type that goes on these remote control. I bought CR2016 which seemed to fit but still did not work. The light was not on when pressed. originalkeyless.com personel told me to use CR2025 but it is too thick to fit. i have tried to reprogram but did not work i think due to the remote control battery issue. What is the right battery for this remote? becerrda 06-06-2007, 10:42 PM Does anyone know the battery type that goes on these remote control. I bought CR2016 which seemed to fit but still did not work. The light was not on when pressed. originalkeyless.com personel told me to use CR2025 but it is too thick to fit. i have tried to reprogram but did not work i think due to the remote control battery issue. What is the right battery for this remote? opened my remote panasonic cr2016 3v MWSchafer 07-22-2007, 05:36 PM Previous programs for 2000 Camry keyless remote don't work. The following program is the right one. 1. Start with key out of the ignition, driver door is open (all others closed), and driver door is unlocked. Insert key into the ignition (don’t turn it) and pull it out Perform these steps within 40 seconds: a. Using the power lock switch on the driver’s door, perform 5 lock/unlock cycles with lock. Use an even pace and try to go about one cycle per second. 1 cycle = 1 lock and 1 unlock) b. Close, then open driver’s door. Perform these steps within 40 seconds: a. Using the power lock switch on the driver’s door, perform 5 lock/unlock cycles starting with lock. Use an even pace and try to go about one cycle per second. (1 cycle = 1 lock and 1unlock) b. Insert the key in the ignition cylinder. c. Turn the ignition to ON (as far as you can without cranking the engine) then back to OFF. d. Turn the ignition to ON (as far as you can without cranking the engine) then back to OFF. e. Remove the key from the ignition. Within 3 seconds, the power door locks should cycle automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point. Perform these steps within 40 seconds: a. Press the lock and unlock buttons on the transmitter simultaneously for 1 second. b. Immediately after letting go of the lock and unlock buttons, hit the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once indicating successful programming. If the door locks don’t cycle, or cycle twice, repeat steps a and b-your remote has not been accepted. c. Repeat steps a and b in step 6 for each new and existing transmitter. 7. Close driver door. AUTOSALESCOSTARICA 07-26-2007, 12:26 AM Hi, can anyone tell me how to program a keyless entry remote for a corolla 1998? thanks Brian R. 07-26-2007, 10:10 PM Read the previous posts in this thread. Particularly post #41 dcbus 08-14-2007, 06:29 PM I have a 2002 Rav4, purchased 2 remotes from ebay, and attempted to program the remotes with the below instructions but step #10 didn't happen... Any ideas? Do I have to do the "confirmation" or "prohibition" step in #8? What do those mean? 1. Driver door open and unlocked. Key out of the ignition 2. Insert the key and remove 2 times in 5 sec. 3. Close and open driver door 2 times in 40 sec. 4. Insert the key and remove it again from ignition. 5. Close and open driver door 2 times in 40 sec. 6. Insert the key in ignition, 7. Close the door, 8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”) 9. Remove the key 10. Power lock will cycle to confirm 11. For add or rewrite mode within 40 sec of the confirmation, A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds. B. within 3 sec press “Lock” button for more than 1 sec and release. C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice. sanek 09-06-2007, 09:20 PM The dealer was happy to give it to me so here is the procedure. let me know if it works. (Camry 02 and 03) 1. Driver door open and unlocked. Key out of the ignition 2. Insert the key and remove 2 times in 5 sec. 3. Close and open driver door 2 times in 40 sec. 4. Insert the key and remove it again from ignition. 5. Close and open driver door 2 times in 40 sec. 6. Insert the key in ignition, 7. Close the door, 8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”) 9. Remove the key 10. Power lock will cycle to confirm 11. For add or rewrite mode within 40 sec of the confirmation, A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds. B. within 3 sec press “Lock” button for more than 1 sec and release. C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice. 4Runner Instructions I have a 1999 4Runner and I followed the directions above (which I've copied below) with one exception. In step 8 -- I held the lock button instead of the unlock button in order for the directions to work. Step 1 - open drivers side door and get in your vehicle. Step 2 - put key completely into ignition,then pull out. Step 3- with door open, lock and unlock 5 times on door console (ten clicks total). Step 4 - close door then open door. Step 5 - lock and unlock 5 times on door console (ten clicks total). Step 6 - put key completely into ignition then turn to the on position then pull key out (you will now hear the door locks lock then unlock a couple of times) Step 7 - now quickly press the lock and unlock buttons at the same time only for about a second. Step 8 - then quickly press the lock button for just a second. Step 9 - exit car and close the door After you do this you should hear a beep then your lights will flash. This will indicate that your remote is programmed to your vehicle. i tried this procedure to program 2000 4runner and it wouldnt work, and when i press lock and unlock ten times it keeps locking weaker and weaker. do you know if your instructions work for my car thanx luivarca 09-21-2007, 06:45 PM hi. i have a corolla LE 98, i just bought the keyless entry remote. does anyone knows how to program it? thanks Tamarina 09-28-2007, 09:54 AM Hi Everybody..I have a 1995 Toyota Corolla. I just broke the keyless remote and now bought a new one. The new one does not have the programming instructions with it. Dealer is asking for $96 to program it. Can someone help me with the programming instructions? Details - Part# 08191-00860 FCC # BAB237131-013. Thanks!! Tammy Onblsht 09-30-2007, 01:41 AM The instructions for the BAB237131-013 remotes are the same used for the RS3000 system with BAB237131-022 remotes. Tamarina 09-30-2007, 01:22 PM The instructions for the BAB237131-013 remotes are the same used for the RS3000 system with BAB237131-022 remotes. Hi OnBlsht..do you have instructions for it? netsfan549 10-02-2007, 10:51 AM question... My car came with Toyota Alarm but i lost remote can this alarm remote work? thanks http://www.keylessremotesforless.com/images/Toyota_GQ43VT14T_4B_Hold.jpg Onblsht 10-02-2007, 04:29 PM No, the GQ43VT14T remote was never used on a 4Runner. -stev=o 10-03-2007, 02:56 PM i tried this procedure to program 2000 4runner and it wouldnt work, and when i press lock and unlock ten times it keeps locking weaker and weaker. do you know if your instructions work for my car thanx I ran into this problem. My issue was that the door closed/open sensor was busted because at some point, my metal seatbelt latch got caught between the door, and the frame/sensor, and I closed the door (thus smashing the sensor behind the rubber housing on the door frame). I got around it by snagging the working sensor out of the passenger side. effe0525 10-16-2007, 09:12 PM Hi, my 2002 Corolla uses the BAB237131-022 remote, I picked up a replacement on Ebay (matching model #) and need programming help. Any assistance would be appreciated. Thanks in advance. luivarca 11-17-2007, 02:09 AM To Program A Rs3000 Toyota Alarm For Corolla 98-00. 1 - Put The The Key In The Ignition "on" Position With Only The Driver's Door Open. 2 - Reach The Rs3000 Module Under The Driver's Seat. 3 - Press And Hold For 5 Seconds The Little Green Button On Left Side Of The Module (side Door), Until The Alarm's Led Stay Without Flashing. 4 - Press Any Button On The Remote For 1 Sec. 5 - When You Hear The Beep And See The Lights Flashing, Take The Key Out Of The Ignition. 6 - Enjoy Your Alarm. Please Feel Free To Ask Any Question. Also Have Keyless Instalation 4 Elantra And Mitsubishi. Good Luck!!!!!! tinamarie1014 04-16-2008, 01:55 PM Here's a confirmatory link for daffy_duck-010's post: http://www.geocities.com/toyota_speed2003/keyless_entry.html thanks so much for all your info...i have a 2001 solara that i bought used and it only came with one remote and my dad does security at a car dealership and the owner gave me a second remote that matched exactly...the only thing wrong was the batteries were dead but then it worked as good as new... xavier1117 05-12-2008, 09:21 AM how would i go about reprogramming a keyless remote for a 98 dodge intrepid? Maztech 08-01-2008, 12:54 AM Hey I need some help I have a 2006 corolla and when i lock tthe doors the car won't beep or when i unlock it and it used to befor i had my ecureplaced if anyone knows how to reprogram it so it will beep plaese let me know or if it is something i have to take to the dealership thanks Spaniel1 08-13-2008, 03:19 PM Hello everyone; I just bought a 2001 4Runner LTD. It came with only one remote & I'd like to buy an additional one. I was checking listings on ebay & some come with programming instructions and some do not. Don't totally trust their claims & would feel better if I had instructions from another source. My remote has 3 buttons on the front (lock, unlock & rear window) with a red panic button on the back. The FCC ID # is HYQ1512Y. Thanks in advance for any all help.:wink: I have lost the only keyless remote for my 2004 4Runner. I thought I had the number from the back written dow. Is there another way to buy a remote without the number? Norman Kipp alpine43@frontiernet.net eng2trk 08-17-2008, 02:21 PM Hello, I need help with the programming of my keyless remote. I have a '99 4runner limited and have tried a couple of the instructions from here, but they don't seem to work. Can anyone help. Thanks! thejimmy64 08-24-2008, 12:28 AM what about a 2001 dodge dakota? anyone know how to program for that? please and thank you. bloodline206 09-27-2008, 12:07 AM To Program A Rs3000 Toyota Alarm For Corolla 98-00. 1 - Put The The Key In The Ignition "on" Position With Only The Driver's Door Open. 2 - Reach The Rs3000 Module Under The Driver's Seat. 3 - Press And Hold For 5 Seconds The Little Green Button On Left Side Of The Module (side Door), Until The Alarm's Led Stay Without Flashing. 4 - Press Any Button On The Remote For 1 Sec. 5 - When You Hear The Beep And See The Lights Flashing, Take The Key Out Of The Ignition. 6 - Enjoy Your Alarm. Please Feel Free To Ask Any Question. Also Have Keyless Instalation 4 Elantra And Mitsubishi. Good Luck!!!!!! [/quote] [/quote] I had a question :rolleyes: where exactly is the green button? I looked underneath the car but there is the hole and in that hole there is this yellow plastic thing that have bunch of wires in it running left and right. Please tell me where I can find the green button?:runaround: :confused: bloodline206 09-27-2008, 12:43 AM I'm really can't find the green button under the driver seat. :banghead: Please can you tell me where specifically underneath the driver seat on a Toyota Corolla 98-01.:rolleyes: 010175 10-15-2008, 11:03 PM I need help. I just bought a 2000 4 runner and dont know if it is keyless. How would I find out befor I buy a keyless remote? Thanks Dave Onblsht 10-16-2008, 08:42 PM Depends on which remote system you have. Factory or DEALER/PORT installed? (RS3000) lost&confused 01-16-2009, 01:07 PM Hello! I am so confused... i have a '98 Camry and have been using a BAB237131-022 keyless remote for about two years. It suddenly stopped working so I assumed it was the battery and bought a new one from an auto parts store. I can't figure out how to program it, and the dealer wants $50 to do so- any ideas?? jstarnes 02-28-2009, 03:58 PM I need the programing instructions for a 1997 Toyota 4Runner. Will these work or something different???? nmusti63 05-21-2009, 09:43 AM Hi all, I just purchased a 2000 RAV4 for my son, it has power locks and windows. Previous owner did not have a keyless remote. How can I find out if his car has that option and if so can I buy an after market remote on eBay? I would greatly appreciate an email response nmusti@aol.com Thanks! caru 05-23-2009, 12:49 PM instructions worked (after some practice) for a 2005 Camry XLE thanx a LOT for the post!!! was able to save some for really needed parts. lca_316 05-26-2009, 01:23 PM I have genuine TOYOTA remotes, and I am trying to programm one of them for 03 4runner LTD. Can any one help with instructions please! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
