| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
How to Lower a 1/24 Rx7
Aoshima & Fujimi kits have massively high ride height.
These show a way of lowering these kits to achieve a substantial drop. On a real car maybe equates to about 2 inches. You can adjust to how you would like it. Should apply to other kits also. 1/24 Aoshima FD3s RX7. ![]() ![]() FRONT: simply remove the spacer from the top suspension A-arm glue the spacer to the lower suspension arm. ![]() ![]() ![]() REAR: remove around two coils from the suspension to cater for the drop remove the chassis mounts so the subframe can sit flat ![]() to go further. reshape the hub to allow for a further drop in ride height. ![]() ![]() ![]() Thats all for the Aoshima FD3s Rx7. FUJIMI 1/24 FD3s RX7 ![]() ![]() FRONT: remove the mounting pin from the top of the suspension dampers. remove 1 coil from the spring. ![]() ![]() make two spacers for the lower suspension arms. ![]() ![]() increase the size of the hole in the mounting position. ![]() ![]() (some cars will require slight reshaping of the upper side mounts when the body lowers.) Usually with different bonnet. ![]() You can mount the body under the second tab instead of between the two mounting positions. it should rest nicely on the rails. ![]() ![]() REAR: trim the tab from the inner portion of the rear disk rotor. this allows the axle to sit lower. disk will be slightly off centre but hardly noticable. ![]() ![]() ![]() Thats all for the Fujimi FD3s Rx7. Hope this helps Russ. |
Re: How to Lower a 1/24 Rx7
Great information! Thanks for sharing your way of lowering ride height.
