Old 01-04-2010, 06:42 AM
GritMaster GritMaster is offline
'88 K1500 Won't Start
Kind of an odd situation.
Tried to start my truck up and it Cranked for almost 1/4 of a second then everything died and I lost all electrical. got the battery load tested and it checked out A-ok, alternator is brand new. Tried jumping it and no luck... but after i reset the positive connection to the battery I regained electrical. went to try and crank it over again and same result. Maybe im just not thinking outside of the box... but im completely stumped on what's causing this... Any ideas?
RIP Andy "Hypsi87" Filson... We'll miss ya mate
Originally Posted by nissanstreetz
For about 700 dollars you can have about 80 horespower at the wheels and about 70 torque.
Old 01-04-2010, 10:26 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: '88 K1500 Won't Start
If you are losing electrical check all battery cable ends and grounds.
Got add on cable ends?
If so they are a good place to start.
MT
Old 01-04-2010, 02:49 PM
Checked them all and everything seems good. I get full electrical everywhere until I try to start the ignition and then I lose everything. Resetting the positive connection on the battery allows me to get back all the electrical until i try and fire it up again. seems like a switch is overloading or something
Old 01-04-2010, 02:58 PM
intimadatorsquizz intimadatorsquizz is offline
There should be 2 positive battery cables going to your battery. In between them is a lead spacer and they were know to corrode a lot. Take the bolts out and check or replace the long bolt and the spacer. Also check the positive treminal on the battery to make sure it's not loose.
Old 01-04-2010, 04:57 PM
spunbearings's Avatar
spunbearings spunbearings is offline
I had a problem like this on my 89 vette, it turned out the actual lead terminal inside the battery was broke and moved around inside the battery housing. It would only get an intermittent connection.
Old 01-04-2010, 05:11 PM
MT-2500's Avatar
AF - Advisor
It is losing power some place.
If resetting /R&R positive cabel helps that is the place to look first.
Get a 12 volt test light and check for 12 volt power from batterty and then ends and back to ign switch and positive on starter.
One some positive from starter runs threw a stud and fuse links on firewall.
Does headlights quit when starter quits?
If so there is a power lose some place.
MT
Old 01-04-2010, 11:01 PM
777stickman 777stickman is offline
Sometimes batt cables can look real good. But corrosion can get under the rubber covering that the eye cannot see. From your post I would replace both Pos & Neg batt cables and go from there.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-05-2010, 03:07 AM
Everything electrical cuts out after i try to crank. Head lights, gauges, windows, cabin lights, horn, Hazard lights etc. going out tomorrow to fiddle some more and see where the current stops flowing, or if it does.
When i tested initially i was still getting current to the alternator, didn't check for anything at the starter that time though.
Thanks for all your ideas so far
Truck's dead almost 40 miles from where I live. makes working on it a pain
Old 01-06-2010, 10:47 AM
Bob B Bob B is offline
Hi,
My 97 did exactly this loosing electrical and wiggling the cable would temporarily fix it.
I finally took the positive cables off the battery bolt and fully cleaned the ends,
Been fine for two years now.
Bob B
