Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 10-18-2001, 06:47 PM
NismoPC's Avatar
NismoPC NismoPC is offline
OIL on Spark Plugs. Its that bad?
OK. This goes to George especially.
I exchanged the BKR6E-11's today for the BKR6E's. Tonight I decided to pull the Autolites out and replace them with the NGK's. All four Autolite plugs had what seemed to be fresh oil sitting on the threads. The electrode and tip are clean and dry, but the oil is on the threaded part.
I do not believe this to be an issue and feel that it might have something to do with the superbly built Autolite plugs that I had in there.
Anyhow, just to make me feel good about this, please let me know that it was because the Autolites SUCK! and I should have had the NGK's in there in the first place. And that it had something to do with the amount of spark generating from the plug was not great enough or the plug was not getting hot enough or something like that.
By the way, the car idles beautifully now and acceleration seems smoother. What was I thinking when I bought the Autolites you ask? I have no fukn' clue.
Brandon
'96 G20 - modified
Old 10-18-2001, 07:47 PM
P10DET's Avatar
P10DET P10DET is offline
Was it just on the threads, or was it on the electrode and insulator as well?
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 10-18-2001, 09:07 PM
NismoPC's Avatar
The insulator and electrode were dry and clean. Only on the threads near where it would seat against the block.
There was no oil in the 4 plug canals or near the rocker cover gasket. So that's good.
Brandon
'96 G20 - modified
Old 10-18-2001, 09:44 PM
P10DET's Avatar
That's strange, but I have seen that before. I've ignored it.
It may be that you have some oil seeping from somewhere, but if so, then the engine is totally burning it.
Install the new plugs and pull them after about 500 or 1,000 miles and see how they look I guess.
George Roffe
Houston, Texas USA
00 328i
Old 10-18-2001, 09:54 PM
NismoPC's Avatar
OK. Here is what I just found out. Did some research on the Autolites. Damn idiots at the auto parts store. But then again I trusted them to give me the right stuff. So Damn me too!
The Autolites that were given to me and I installed the car were Part # 3923. All websites even Autolites site shows the part # 3924 NOT 3923. I was given the wrong freakin' plugs. They have been in there since I installed the '91 intake cam a few months ago.
Argh! I feel like finding that guy and.....
I will assume that the oil on the plugs came from not sparking properly due to wrong spark plug!
George, thanks. I'll check them in about 500-1000 miles and see what happens.
Brandon
'96 G20 - modified
Old 10-18-2001, 11:09 PM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Speaking of that...whats the correct torque for the plugs to go back in? And what plugs would you recommend?
If the torque isnt exact, will that affect your performance?
-Brian Jones
I got a snake man
Old 10-19-2001, 07:47 AM
NismoPC's Avatar
I can answer you there now that I have more to go on.
Go here:
http://www.automotiveforums.com/vbulletin/t9089.html
As for torque, I can not recall, but believe it to be 18-24 lb/ft.
George, can you help out there!
Brandon
'96 G20 - modified
Having 3.5L spark plugs in a 2.7L engine. Benjamin_2002 Intrepid 1 02-28-2011 05:19 PM
Spark Plugs, coils, wires??? ktrap Grand Prix 1 02-11-2011 01:38 PM
E150 5.4L Spark Plug Replacement leroge Econoline 1 04-19-2010 08:19 PM
spark plug analysis keilerstag Cutlass Series 1 06-29-2009 08:25 AM
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
