Ignition switch removal
My 2001 Alero's ignition switch key cylinder looks to be bad, I am unable to turn the key from the off position. I have everything removed with the exception of the shift lock cable. I have depressed the lock tab as discribed on another thread in this forum, with no success. I am wondering if the key has to be in the on position before the cable can be pulled out. Any one know or have some helpful guidance?
Also, if the key cylinder is bad and cannot be turned to the on position. Is there a way to remove the lock cylinder without destroying the switch module? Thanks Bullshark |
Re: Ignition switch removal
I finally was able to remove the ignition switch assembly by bending a bracket down at the center console. I then removed the switch assemly along with the locking cable.
The cable was locked into the switch assembly and could not be removed by pressing the release cable button shown above. I then seperated the switch assembly by prying the lock tabs open around the center of the switch assembly. I was then obvious that the cable was locked into position when the key was in the off position. see below: With the switch now seperated I was able to rotate the switch mechanisim to the on position and easily remove the cable. Now, the next question is how do I get the lock cylinder out of the front ignition assembly without damaging it. Any ideas?? Bullshark |
I was then able to salvage the ignition switch ( $100 item at O'Reilly's) and purchased a new lock cylinder. The Passlock connector could now be easily removed from the ignition switch housing shown below Reassembled the ignition switch in the dash and was back in business. Thanks guys.... I couldn't have done this without all your help. .....![]() Bullshark |
