wipers stop in upright position
I have a 2000 regal and the wipers stop in a upright postion. They work fine but stop in a upright position.
It snowed the other night and I think snow got under the wipers. How do I correct this problem? |
Re: wipers stop in upright position
hello if the problem started after the snow its possible wipers were froozen to windshield.when they went to move it bent the wiper linkage.if the problem was there before the snow then it sounds like they were misaligned.ck linkage for being bent.if all is ok take wipers off,turn wipers on/off so they are in park position,install wipers so they are down where they are supossed to be good luck hope this helps
The problem started after there was snow.How do I fix the linkage?
A common problem with the wipers stopping straight up not at the park position is a metal tab at the wiper motor assembly that gets bent out of shape due to the weight of the snow. Acts as part of a wiper park sensor. It should be a 90 degree or square form. You'll have to remove the wipers and the plastic trim to get at it.
sorry no picks but if you open hood look up at firewall there will be a cover between wipers.remove cover(usually plastic with 6 screws & push clips)then you will see linkage ck for being bent good luck
BTW wiper arms have a nut holding them. remove & carefully wiggle (DONT PRY ON WSHIELD!! |
Next time, use your scraper and brush to clear the windshield, NOT the wipers.
Raise the hood. Remove the wiper arms. If the plastic cowl trim is assembled in two pieces (some models are) you will only have to remove the left (driver side) wiper arm. Remove the rubber cowl seal, then the screws and/or push pin fasteners holding the cowl cover. Remove the cowl trim/cover. You should then be able to see the wiper motor cover: ![]() Remove the push pin fastener holding the cover, then remove the cover. This should reveal the wiper motor, linkage, and plastic wiper stop cam cover: ![]() Lift off the black plastic stop cam cover to reveal the stop mechanism and cam. You will probably see the metal stop tab in a condition similar to that pointed out by the arrow: ![]() Closer inspection should reveal something like this (the blue piece is the stop tab): ![]() Using chain nosed pliers (most people errantly call them "needle-nosed", but true needle nosed pliers are actually quite different) straighten the stop tab so that it is perpendicular to the wiper cam: ![]() Make sure the area is clear of obstructions, turn on the ignition, and operate the wiper motor and allow it to park while observing the mechanism. Once the wiper motor reverses to park the wipers, you'll see the action of the cam and stop tab. If you bent the tab too far, it will probably clear itself when the motor begins to run. If the motor parks and stops correctly, apply some lubricant (white lithium grease) to the cam and mechanism and test them again. ![]() Install the plastic cover, and reassemble the motor cover, cowl cover, and wiper arm. Remember to install the rubber cowl seal. Lastly, find your ice scraper and snow brush, or acquire new ones. Instruct all the drivers of the vehicle to use them, or start saving your money for parts. The tab can be bent and straightened two or three times before it finally breaks off, which will involve a lot more repair work.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide Last edited by Blue Bowtie; 12-27-2008 at 08:40 AM. |
Does this apply to pontiac grand prix also? Or is it different? Original message states it's for 2000 regal.
Yes! They are identical in their operation and components.
Thanks, just got done fixing it. Was an easy fix! And spent $0!!!
is this repair something that is easy to do? i don't have any experience repairing anything on my car. bulb replacements, wipers, etc. not sure how easy it will be to screw something up.
Yes it is an easy fix. Just look at the pictures in the post and then remove the cowling at the base of the windshield to reach the wiper motor area. Bend the tab back into place and replace what you removed. The hardest thing will be to get the wiper blade arm on the driver's side.
that's good to know.
will there be any adjustments that i need to make considering i have a 98 regal? |
No! The same procedure will work on your car! They are the same design.
