Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 10-28-2007, 04:47 PM
Hydrolixer Hydrolixer is offline
Install POD air filter on non turbo skyline R33
Hi guys, i'm new to this site, and I've got a R33 Series 1 (non turbo)
my mates say i should get pod air filter to get the sounds.. is that true?
and with a series 1 does the pod fit? if so could i get some directions on how to put one in please? thanks very much guys
Old 10-31-2007, 02:40 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: Install POD air filter on non turbo skyline R33
Unbolt the stock air flow meter from your air filter box. Buy an adaptor to fit the pod filter to the air flow meter and you should be set.
If you want an awesome sound, I would suggest getting a full kit from unifilter.com.au
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
Old 10-31-2007, 07:10 PM
Hi, thank you, but installing a pod will give me the air intake sound?
Old 11-12-2007, 08:51 PM
mmcleo11's Avatar
Yes, it will give you a good intake noise. A paper pod filter will not give as much noise as a foam filter on a non turbo motor.
N14 Pulsar
The workhorse...
Twin turbo 5.7L LS1
Old 11-18-2007, 12:44 AM
Hey i've got the pod installed, but it seems there are no sound from the intake, I do not know why? It's installed correctly because i've had a mechanic look at it, and he said he would have done the same to it but he doesn't know why either..?
Old 11-26-2007, 03:41 AM
mmcleo11's Avatar
That is odd.
I would consider getting a set of extractors and a 2.5" exhaust fitted, which will let the motor breath a bit better and it will suck in a lot more air.
N14 Pulsar
The workhorse...
Twin turbo 5.7L LS1
