Old 08-12-2007, 07:33 PM
justav6 justav6 is offline
ebtcm module help
I am on need of some info on the ebtcm module . i had my abs scanned by a dealership and was told the electronic brake trac control mudule was bad. the price i was given to replace it was $ 1,800. i found one elsewhere for $120 and figured that was a better way to go. I have no idea where the ebtcm is located or how to go about changing it. there seems to be very little info anywhere online about it. if anyone could help me out with some info it would help me out a bunch. $1,680 worth. ( : as always greatly appreciated
Old 08-12-2007, 07:51 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: ebtcm module help
What year is your Grand Prix?
This recently discussed thread may help. See link below. Most likely it will be the module at the ABS modulator/motorpack under the hood where the electrical connector is. Something like four screws hold it on.
Click here
Timeslip 08/12/06
AF Community Guidelines
Old 08-12-2007, 11:33 PM
thanks for the link. not suse if that info for a 97 is the same as mine 2000 gtp. i assume ebtcm is just a bcmwith trac control? looks like thats in the driver dash. ????????
Old 08-13-2007, 01:08 AM
BNaylor's Avatar
It is applicable and the same. The EBTCM is not located in the dash like older ABS systems. That is where the confusion lies. The EBTCM module for '97 - '03 Grand Prixs is integrated into the ABS modulator located under the brake master cylinder. It is a Bosch 5.3 ABS system. See link below which will give you an idea where the module is located. Scroll down to the illustration.
Click here
Like most other late-model ABS systems, the Bosch 5.3 system is a four-wheel, nonintegral (add-on) ABS system. The Electronic Brake/Traction Control Module (EBTCM) and Brake Pressure Modulator Valve (BPMV) assembly are combined into one unit. The unit also includes a pump and relays for the pump motor and solenoids. The EBTCM or BPMV can both be replaced separately, but neither component is considered serviceable. So if an ABS solenoid valve, the pump or a relay fails, the whole BPMV assembly must be replaced.
ABS Pump with EBTCM module - (2000 - 2001 Grand Prix}
Timeslip 08/12/06
Old 08-13-2007, 04:58 PM
thanks for the great help as always. i think im on my way. can i use a module from any car with a 5.3 system like a newer grand prix or bonneville, or are they different?
Old 08-13-2007, 09:57 PM
BNaylor's Avatar
I not 100% sure or whether that is a good idea. But there should be a GM part number on the front of that pump/ebtcm module. Look for a number that says for example 18023760. Alot of GM cars even if different platforms use the same parts but it is better to verify it will work. Good luck.
Timeslip 08/12/06
Old 08-17-2007, 03:08 PM
i thank you for the help! i just finished replacing the module and it works like a charm . no more lights! only thing is the spongy pedal from disconnecting the brake lines. from what i found online after replacing the abs pump the brakes must be bled with a vaccum bleeder. do i need to have this done somewhere or is it possible for me to bleed them without some fancy tool?
Old 08-17-2007, 06:27 PM
BNaylor's Avatar
Thanks for the feedback. I'm glad we finally got this mystery solved. Personally, I would take it to a Pro as long as they do not charge too much. I know of a few instances where the ABS pump can be bled using gravity similar to the same method when you replace brake pads and/or caliper but it is time consuming and may not work 100%.
Timeslip 08/12/06
